    Where to insert text?
    8 Posts 3 Posters 1.1k Views 3 Watching
      sdetweil @norwestie
      @norwestie read the link in my signature about adding moduled
      • N Offline
        norwestie
        I used pm2 to autostart MM. Now I can’t get to the Pi desktop. I used pm2 stop mm then on the Pi command Q. MM disappeared for a few seconds but restarted right away. I rebooted and repeated but can’t get off MM
          sdetweil @norwestie
          @norwestie alt-spacebar, n
          to minimize, just like on windows.
          pm2’s job is to keep the defined process running
          pm2 stop all
          once u get to the desktop
          • N Offline
            norwestie
            Thank you, it worked!
            • N Offline
              norwestie
              But… now i installed a couple modules, checking everything but MM is stuck ‘loading’. All that shows is the clock and weather and the header for Jeopardy. Where is my error? Below is what I have:
                                      module: "weatherforecast",
                                      header: "Weather Forecast",
                                              locationID: "5760009", //ID from http://bulk.openweathermap.org/sample/city.list.$
                                              appid: "xxxxx"
                                      module: 'MMM-IPCam',
                                      position: 'top_left',
                                      invertColors: false,
                                      updateInterval : 10000,
                                      host: '192.168.50.8',
                                      port: 80,
                                      user: 'xxxxx',
                                      pass: 'xxxxx',
                                      module: "newsfeed",
                                      position: "bottom_bar",
                                              feeds: [
                                                              title: "New York Times",
                                                              url: "https://rss.nytimes.com/services/xml/rss/nyt/HomePage.xml"
                                              showSourceTitle: true,
                                              showPublishDate: true,
                                              broadcastNewsFeeds: true,
                                              broadcastNewsUpdates: true
              S lavolp3L 2 Replies Last reply Reply Quote 0
                sdetweil @norwestie
                @norwestie please use code marks around config info
                mark the text, and push the button above the editor like this </>
                • lavolp3L Offline
                  lavolp3 Module Developer @norwestie
                  @norwestie CHeck this out to get a feeling how to troubleshoot modules.
                  There might be an error zou need to find somewhere
                  https://gist.github.com/lavolp3/db7de8c0664ba95e8b9247ba685095fe
                  How to troubleshoot modules
                  MMM-soccer v2, MMM-AVStock
