    Where to insert text?
    8 Posts 3 Posters 1.3k Views 3 Watching
    • N
      norwestie
      I’m trying to add some 3rd party modules to my MM. Many require text to be added to the config.js file. I tried but broke the config. I removed what I had pasted in and all is working now. I searched for the protocols for modifying the config but can’t find an answer. With all the {, ( ), ', " }, etc I need help. Where would I insert the following in the config.js file:
      module: “MMM-quote-of-the-day”,
      position: “lower_third”,
      language: “en”,
      updateInterval: “1d”
        sdetweil @norwestie
        @norwestie read the link in my signature about adding moduled
        • N
          norwestie
          I used pm2 to autostart MM. Now I can’t get to the Pi desktop. I used pm2 stop mm then on the Pi command Q. MM disappeared for a few seconds but restarted right away. I rebooted and repeated but can’t get off MM
            sdetweil @norwestie
            @norwestie alt-spacebar, n
            to minimize, just like on windows.
            pm2’s job is to keep the defined process running
            pm2 stop all
            once u get to the desktop
            • N
              norwestie
              Thank you, it worked!
              • N
                norwestie
                But… now i installed a couple modules, checking everything but MM is stuck ‘loading’. All that shows is the clock and weather and the header for Jeopardy. Where is my error? Below is what I have:
                                        module: "weatherforecast",
                                        header: "Weather Forecast",
                                                locationID: "5760009", //ID from http://bulk.openweathermap.org/sample/city.list.$
                                                appid: "xxxxx"
                                        module: 'MMM-IPCam',
                                        position: 'top_left',
                                        invertColors: false,
                                        updateInterval : 10000,
                                        host: '192.168.50.8',
                                        port: 80,
                                        user: 'xxxxx',
                                        pass: 'xxxxx',
                                        module: "newsfeed",
                                        position: "bottom_bar",
                                                feeds: [
        title: "New York Times",
        url: "https://rss.nytimes.com/services/xml/rss/nyt/HomePage.xml"
                                                showSourceTitle: true,
                                                showPublishDate: true,
                                                broadcastNewsFeeds: true,
                                                broadcastNewsUpdates: true
                S lavolp3L 2 Replies Last reply
                  sdetweil @norwestie
                  @norwestie please use code marks around config info
                  mark the text, and push the button above the editor like this </>
                  • lavolp3L
                    lavolp3 Module Developer @norwestie
                    @norwestie CHeck this out to get a feeling how to troubleshoot modules.
                    There might be an error zou need to find somewhere
                    https://gist.github.com/lavolp3/db7de8c0664ba95e8b9247ba685095fe
                    How to troubleshoot modules
                    MMM-soccer v2, MMM-AVStock
