    Where to insert text?
    8 Posts 3 Posters 922 Views 3 Watching
    • N Offline
      norwestie
      I used pm2 to autostart MM. Now I can’t get to the Pi desktop. I used pm2 stop mm then on the Pi command Q. MM disappeared for a few seconds but restarted right away. I rebooted and repeated but can’t get off MM
        sdetweil @norwestie
        @norwestie alt-spacebar, n
        to minimize, just like on windows.
        pm2’s job is to keep the defined process running
        pm2 stop all
        once u get to the desktop
        • N Offline
          norwestie
          Thank you, it worked!
          • N Offline
            norwestie
            But… now i installed a couple modules, checking everything but MM is stuck ‘loading’. All that shows is the clock and weather and the header for Jeopardy. Where is my error? Below is what I have:
                                    module: "weatherforecast",
                                    header: "Weather Forecast",
                                            locationID: "5760009", //ID from http://bulk.openweathermap.org/sample/city.list.$
                                            appid: "xxxxx"
                                    module: 'MMM-IPCam',
                                    position: 'top_left',
                                    invertColors: false,
                                    updateInterval : 10000,
                                    host: '192.168.50.8',
                                    port: 80,
                                    user: 'xxxxx',
                                    pass: 'xxxxx',
                                    module: "newsfeed",
                                    position: "bottom_bar",
                                            feeds: [
                                                            title: "New York Times",
                                                            url: "https://rss.nytimes.com/services/xml/rss/nyt/HomePage.xml"
                                            showSourceTitle: true,
                                            showPublishDate: true,
                                            broadcastNewsFeeds: true,
                                            broadcastNewsUpdates: true
            S lavolp3L 2 Replies Last reply Reply Quote 0
              sdetweil @norwestie
              @norwestie please use code marks around config info
              mark the text, and push the button above the editor like this </>
              • lavolp3L Offline
                lavolp3 Module Developer @norwestie
                @norwestie CHeck this out to get a feeling how to troubleshoot modules.
                There might be an error zou need to find somewhere
                https://gist.github.com/lavolp3/db7de8c0664ba95e8b9247ba685095fe
                How to troubleshoot modules
                MMM-soccer v2, MMM-AVStock
