    iFrame with username and password
    5 Posts 4 Posters 2.3k Views 5 Watching
    • N
      Nox
      im trying to change the iframe module so it can handle password protected sites but it wont work
      any tips?
      /* Magic Mirror Config Sample
       * MIT Licensed.
      var config =
          port: 8080,
          language: "de",
          timeFormat: 24,
          units: "metric",
      		//MODUL
      				module: 'iFrame',
      				position: 'bottom_center',	// This can be any of the regions.
      							url: ["https://www.stundenplan24.de/20070498/vplan/"],  // as many URLs you want or you can just ["ENTER IN URL"] if single URL.
      							//updateInterval: 0.5 * 60 * 1000, // rotate URLs every 30 seconds
      							width: "100%", // Optional. Default: 100%
      							height: "100px" //Optional. Default: 100px
      /* global Module */
      /* Magic Mirror
       * Module: iFrame
       * By Ben Williams http://desertblade.com
       * MIT Licensed.
      Module.register("iFrame",{
      		// Default module config.
      		defaults: {
      				height:"300px",
      				width:"100%"
      	// Override dom generator.
      	getDom: function() {
      		var iframe = document.createElement("iframe");
              iframe.id="framer";
      		iframe.style = "border:0";
      		iframe.width = this.config.width;
      		iframe.height = this.config.height;
      		//iframe.src =  this.config.url;
              /*var iframeURL = this.config.url;
              var iframeID = "framer";
              var req = new XMLHttpRequest();
              req.open("POST",this.iframeURL,false, "username", "password");
              req.send();
              var iFrameWin =document.getElementbyID(this.iframeID);*/
              iFrameWin.src = "google.de";
              //this.iframeURL + "?extraParameters=true";
      		return iframe;
      • rudibaraniR
        rudibarani Project Sponsor
        Hi Nox,
        did you find a solution for this?
        Best,
        Phillip
          majdzik84
          Has anyone found a solution?
          • ChrisC
            Chris
            Good morning all,
            I also encounter this kind of problem. I would like to insert a frame of a Jeedom design representing the state of my connected objects throughout the house. But at the first connection I am supposed to enter the username and password as well as checked the box “register this computer”
            If I manage to get past this stage and the computer (finally the browser) is registered, I will be able to access this type of design later which will return all the information of the house to me:
            Could someone help me with this fix?
            Thanking you in advance,
            Regards,
              majdzik84
              Chris check this https://support.actiontiles.com/en/communities/12/topics/2916-logging-into-actiontiles-in-iframe-with-no-keyboard
              its work for me
