    Calendar Timezone Issues
    17 Posts 2 Posters 4.9k Views 2 Watching
      sdetweil @Jonsar
      @Jonsar my fault
      see here
      https://forum.magicmirror.builders/topic/13774/2-13-back-screen-translation-file-error-fix/2
        Jonsar @sdetweil
        @sdetweil Thank you for all your help. Unfortunately, it still has the timezone issue i.e. all times displayed UTC-4 (I’m in EDT). It appears that the times that are pulled from Outlook are not recognized as already in EDT and are being treated as UTC (hence the additional -4 hours). I’ll keep working on it.
          sdetweil @Jonsar
          @Jonsar can u share the ics file , email, same userid on gmail
          it is a text file, so if u have to change the event names, it just an editor required
          the ics spec says events with time ( T120000) (noon) MUST be in UTC
          events that say DATE-ONLY, are in local time.
          if there are NOT UTC, then they must supply a TZID= value
          Windows uses non-standard timezone values, and IF you make up your own that aren’t in the
          https://github.com/unicode-org/cldr/blob/master/common/supplemental/windowsZones.xml
          official list, then you will get random results…
          while a timezone MAY be defined IN the ics file, none of the ics handler libraries use it
          here is an event from Office 365, using a recognized windows timezone
          BEGIN:VEVENT
          DESCRIPTION:test new event 1
          UID:040000008200E00074C5B7101A82E0080000000070DE40F38786D601000000000000000
           010000000D2A9BA8A3668CA4ABB2CC6838268179F
          SUMMARY:test
          DTSTART;TZID=W. Europe Standard Time:20200910T090000
          DTEND;TZID=W. Europe Standard Time:20200910T093000
          CLASS:PUBLIC
          PRIORITY:5
          DTSTAMP:20200909T160350Z
          TRANSP:OPAQUE
          STATUS:CONFIRMED
          SEQUENCE:0
          X-MICROSOFT-CDO-APPT-SEQUENCE:0
          X-MICROSOFT-CDO-BUSYSTATUS:BUSY
          X-MICROSOFT-CDO-INTENDEDSTATUS:BUSY
          X-MICROSOFT-CDO-ALLDAYEVENT:FALSE
          X-MICROSOFT-CDO-IMPORTANCE:1
          X-MICROSOFT-CDO-INSTTYPE:0
          X-MICROSOFT-DONOTFORWARDMEETING:FALSE
          X-MICROSOFT-DISALLOW-COUNTER:FALSE
          END:VEVENT
          here is an owa event with just date (whole day event)
          BEGIN:VEVENT
          UID:040000008200E00074C5B7101A82E00800000000104D9270F49BD601000000000000000
           0100000001BDF375044B13F4EB90D0876F5F54174
          SUMMARY:some event name
          DTSTART;VALUE=DATE:20201012
          DTEND;VALUE=DATE:20201013
          CLASS:PUBLIC
          PRIORITY:5
          DTSTAMP:20201007T210922Z
          TRANSP:TRANSPARENT
          STATUS:CONFIRMED
          SEQUENCE:0
          X-MICROSOFT-CDO-BUSYSTATUS:FREE
          X-MICROSOFT-CDO-ALLDAYEVENT:TRUE
          END:VEVENT
            Jonsar @sdetweil
            @sdetweil The ics file is generated with Microsoft Exchange Server 2010.
            UID:55CA88B7-8EF2-4AB5-AD4E-557F33C33FBE
            SUMMARY: TEST
            DTSTART;TZID="(UTC-05:00) Eastern Time (US & Canada)":20201028T133000
            DTEND;TZID="(UTC-05:00) Eastern Time (US & Canada)":20201028T150000
            CLASS:PUBLIC
            PRIORITY:5
            DTSTAMP:20201015T165939Z
            TRANSP:OPAQUE
            STATUS:CONFIRMED
            SEQUENCE:0
            END:VEVENT
              sdetweil @Jonsar
              @Jonsar yeh, that is a challenge… its broken in both the parser and the magic mirror code that handles the cal entries
              I can get it ‘mostly’ right
              the problem is that TZ= has stuff we can’t process…
              “(UTC-05:00) Eastern Time (US & Canada)”
              we can get the offset, and look up some timezone with the SAME offset to get back to UTC
              except, the 1st entry America/Atikokan, doesn’t do Daylight savings,
              and the date conversion library appears to have a bug, saying Daylight savings in the US is in effect on Oct 28, 2020, even tho its NOT til Nov 1, 2020
              the rest of the text doesn’t match anything in the Windows timezone list.
              so, it will be 1 hour off for a while.
                @Jonsar I have found a solution and have submitted changes to the ics parser library
                https://github.com/jens-maus/node-ical/issues/32
                and will submit changes to MM to match.
                https://github.com/MichMich/MagicMirror/issues/2171
                if U are interested I could send u the test files, chat message me if u are interested.
                  Jonsar @sdetweil
                  @sdetweil Not sure what changed but the times are now displaying as starting 5 hours before they are supposed to.
                    sdetweil @Jonsar
                    @Jonsar do another git pull. Latest update accepted on friday
                      Jonsar @sdetweil
                      @sdetweil I’m still on the branch origin/develop and it says I’m up to date.
                        sdetweil @Jonsar
                        @Jonsar hm… show me a vevent entry please.
                          Jonsar @sdetweil
                          As you can see, this event is scheduled to begin at 10:00am but is actually displaying on the calendar as starting at 5:00am.
                          BEGIN:VEVENT
                          UID:00D4F0F7-BF5A-45C4-B92F-41B8C771E111
                          SUMMARY:TEST
                          DTSTART;TZID="(UTC-05:00) Eastern Time (US & Canada)":20201123T100000
                          DTEND;TZID="(UTC-05:00) Eastern Time (US & Canada)":20201123T103000
                          CLASS:PUBLIC
                          PRIORITY:5
                          DTSTAMP:20201122T204236Z
                          TRANSP:OPAQUE
                          STATUS:CONFIRMED
                          SEQUENCE:0
                          END:VEVENT
                            sdetweil @Jonsar
                            @Jonsar I don’t see that
                            only your vevent in ics file, tz set to us eastern
                            Sunday, November 22, 2020
                            10:50:31pm
                            NEXT EVENT
                            TEST Tomorrow at 10:00 AM
                            if u set debug in config.js this is what I see
                            	logLevel: ["INFO", "LOG", "WARN", "ERROR","DEBUG"],
                            this is what I see
                             start=Mon Nov 23 2020 10:00:00 GMT-0500 (Eastern Standard Time) end=Mon Nov 23 2020 10:30:00 GMT-0500 (Eastern Standard Time)
                            initial tz=(UTC-05:00) Eastern Time (US & Canada)
                            corrected TZ=America/New_York
                            corrected tz=America/New_York
                            start date/time=Mon Nov 23 2020 10:00:00 GMT-0500 (Eastern Standard Time)
                            start offset=-300
                            start date/time w tz =Mon Nov 23 2020 10:00:00 GMT-0500 (Eastern Standard Time)
                            event date=Mon Nov 23 2020 10:00:00 GMT-0500 (Eastern Standard Time)
                            event offset=-300 hour=10 event date=Mon Nov 23 2020 10:00:00 GMT-0500 (Eastern Standard Time)
                            adjustHours=0
                              Jonsar @sdetweil
                              @sdetweil You’re right. Was totally on my end. Didn’t realize I had a file that was preventing the upgrade. After upgrading, works like a charm. Thanks for your help as always.
                                sdetweil @Jonsar
                                @Jonsar cool, glad u found it, and it works as you expected!
                                Thanks for the fast feedback
