    Calendar Timezone Issues
    17 Posts 2 Posters 5.2k Views 2 Watching
      Jonsar @sdetweil
      @sdetweil Thank you for all your help. Unfortunately, it still has the timezone issue i.e. all times displayed UTC-4 (I’m in EDT). It appears that the times that are pulled from Outlook are not recognized as already in EDT and are being treated as UTC (hence the additional -4 hours). I’ll keep working on it.
        sdetweil @Jonsar
        @Jonsar can u share the ics file , email, same userid on gmail
        it is a text file, so if u have to change the event names, it just an editor required
        the ics spec says events with time ( T120000) (noon) MUST be in UTC
        events that say DATE-ONLY, are in local time.
        if there are NOT UTC, then they must supply a TZID= value
        Windows uses non-standard timezone values, and IF you make up your own that aren’t in the
        https://github.com/unicode-org/cldr/blob/master/common/supplemental/windowsZones.xml
        official list, then you will get random results…
        while a timezone MAY be defined IN the ics file, none of the ics handler libraries use it
        here is an event from Office 365, using a recognized windows timezone
        BEGIN:VEVENT
        DESCRIPTION:test new event 1
        UID:040000008200E00074C5B7101A82E0080000000070DE40F38786D601000000000000000
         010000000D2A9BA8A3668CA4ABB2CC6838268179F
        SUMMARY:test
        DTSTART;TZID=W. Europe Standard Time:20200910T090000
        DTEND;TZID=W. Europe Standard Time:20200910T093000
        CLASS:PUBLIC
        PRIORITY:5
        DTSTAMP:20200909T160350Z
        TRANSP:OPAQUE
        STATUS:CONFIRMED
        SEQUENCE:0
        X-MICROSOFT-CDO-APPT-SEQUENCE:0
        X-MICROSOFT-CDO-BUSYSTATUS:BUSY
        X-MICROSOFT-CDO-INTENDEDSTATUS:BUSY
        X-MICROSOFT-CDO-ALLDAYEVENT:FALSE
        X-MICROSOFT-CDO-IMPORTANCE:1
        X-MICROSOFT-CDO-INSTTYPE:0
        X-MICROSOFT-DONOTFORWARDMEETING:FALSE
        X-MICROSOFT-DISALLOW-COUNTER:FALSE
        END:VEVENT
        here is an owa event with just date (whole day event)
        BEGIN:VEVENT
        UID:040000008200E00074C5B7101A82E00800000000104D9270F49BD601000000000000000
         0100000001BDF375044B13F4EB90D0876F5F54174
        SUMMARY:some event name
        DTSTART;VALUE=DATE:20201012
        DTEND;VALUE=DATE:20201013
        CLASS:PUBLIC
        PRIORITY:5
        DTSTAMP:20201007T210922Z
        TRANSP:TRANSPARENT
        STATUS:CONFIRMED
        SEQUENCE:0
        X-MICROSOFT-CDO-BUSYSTATUS:FREE
        X-MICROSOFT-CDO-ALLDAYEVENT:TRUE
        END:VEVENT
          Jonsar @sdetweil
          @sdetweil The ics file is generated with Microsoft Exchange Server 2010.
          UID:55CA88B7-8EF2-4AB5-AD4E-557F33C33FBE
          SUMMARY: TEST
          DTSTART;TZID="(UTC-05:00) Eastern Time (US & Canada)":20201028T133000
          DTEND;TZID="(UTC-05:00) Eastern Time (US & Canada)":20201028T150000
          CLASS:PUBLIC
          PRIORITY:5
          DTSTAMP:20201015T165939Z
          TRANSP:OPAQUE
          STATUS:CONFIRMED
          SEQUENCE:0
          END:VEVENT
            sdetweil @Jonsar
            @Jonsar yeh, that is a challenge… its broken in both the parser and the magic mirror code that handles the cal entries
            I can get it ‘mostly’ right
            the problem is that TZ= has stuff we can’t process…
            “(UTC-05:00) Eastern Time (US & Canada)”
            we can get the offset, and look up some timezone with the SAME offset to get back to UTC
            except, the 1st entry America/Atikokan, doesn’t do Daylight savings,
            and the date conversion library appears to have a bug, saying Daylight savings in the US is in effect on Oct 28, 2020, even tho its NOT til Nov 1, 2020
            the rest of the text doesn’t match anything in the Windows timezone list.
            so, it will be 1 hour off for a while.
              @Jonsar I have found a solution and have submitted changes to the ics parser library
              https://github.com/jens-maus/node-ical/issues/32
              and will submit changes to MM to match.
              https://github.com/MichMich/MagicMirror/issues/2171
              if U are interested I could send u the test files, chat message me if u are interested.
                Jonsar @sdetweil
                @sdetweil Not sure what changed but the times are now displaying as starting 5 hours before they are supposed to.
                  sdetweil @Jonsar
                  @Jonsar do another git pull. Latest update accepted on friday
                    Jonsar @sdetweil
                    @sdetweil I’m still on the branch origin/develop and it says I’m up to date.
                      sdetweil @Jonsar
                      @Jonsar hm… show me a vevent entry please.
                        Jonsar @sdetweil
                        As you can see, this event is scheduled to begin at 10:00am but is actually displaying on the calendar as starting at 5:00am.
                        BEGIN:VEVENT
                        UID:00D4F0F7-BF5A-45C4-B92F-41B8C771E111
                        SUMMARY:TEST
                        DTSTART;TZID="(UTC-05:00) Eastern Time (US & Canada)":20201123T100000
                        DTEND;TZID="(UTC-05:00) Eastern Time (US & Canada)":20201123T103000
                        CLASS:PUBLIC
                        PRIORITY:5
                        DTSTAMP:20201122T204236Z
                        TRANSP:OPAQUE
                        STATUS:CONFIRMED
                        SEQUENCE:0
                        END:VEVENT
                          sdetweil @Jonsar
                          @Jonsar I don’t see that
                          only your vevent in ics file, tz set to us eastern
                          Sunday, November 22, 2020
                          10:50:31pm
                          NEXT EVENT
                          TEST Tomorrow at 10:00 AM
                          if u set debug in config.js this is what I see
                          	logLevel: ["INFO", "LOG", "WARN", "ERROR","DEBUG"],
                          this is what I see
                           start=Mon Nov 23 2020 10:00:00 GMT-0500 (Eastern Standard Time) end=Mon Nov 23 2020 10:30:00 GMT-0500 (Eastern Standard Time)
                          initial tz=(UTC-05:00) Eastern Time (US & Canada)
                          corrected TZ=America/New_York
                          corrected tz=America/New_York
                          start date/time=Mon Nov 23 2020 10:00:00 GMT-0500 (Eastern Standard Time)
                          start offset=-300
                          start date/time w tz =Mon Nov 23 2020 10:00:00 GMT-0500 (Eastern Standard Time)
                          event date=Mon Nov 23 2020 10:00:00 GMT-0500 (Eastern Standard Time)
                          event offset=-300 hour=10 event date=Mon Nov 23 2020 10:00:00 GMT-0500 (Eastern Standard Time)
                          adjustHours=0
                            Jonsar @sdetweil
                            @sdetweil You’re right. Was totally on my end. Didn’t realize I had a file that was preventing the upgrade. After upgrading, works like a charm. Thanks for your help as always.
                              sdetweil @Jonsar
                              @Jonsar cool, glad u found it, and it works as you expected!
                              Thanks for the fast feedback
