    Calendar Timezone Issues
    17 Posts 2 Posters 4.5k Views 2 Watching
      Jonsar @sdetweil
      @sdetweil The ics file is generated with Microsoft Exchange Server 2010.
      UID:55CA88B7-8EF2-4AB5-AD4E-557F33C33FBE
      SUMMARY: TEST
      DTSTART;TZID="(UTC-05:00) Eastern Time (US & Canada)":20201028T133000
      DTEND;TZID="(UTC-05:00) Eastern Time (US & Canada)":20201028T150000
      CLASS:PUBLIC
      PRIORITY:5
      DTSTAMP:20201015T165939Z
      TRANSP:OPAQUE
      STATUS:CONFIRMED
      SEQUENCE:0
      X-MICROSOFT-CDO-APPT-SEQUENCE:0
      X-MICROSOFT-CDO-BUSYSTATUS:BUSY
      X-MICROSOFT-CDO-INTENDEDSTATUS:BUSY
      X-MICROSOFT-CDO-ALLDAYEVENT:FALSE
      X-MICROSOFT-CDO-IMPORTANCE:1
      X-MICROSOFT-CDO-INSTTYPE:0
      X-MICROSOFT-DONOTFORWARDMEETING:FALSE
      X-MICROSOFT-DISALLOW-COUNTER:FALSE
      END:VEVENT
        sdetweil @Jonsar
        @Jonsar yeh, that is a challenge… its broken in both the parser and the magic mirror code that handles the cal entries
        I can get it ‘mostly’ right
        the problem is that TZ= has stuff we can’t process…
        “(UTC-05:00) Eastern Time (US & Canada)”
        we can get the offset, and look up some timezone with the SAME offset to get back to UTC
        except, the 1st entry America/Atikokan, doesn’t do Daylight savings,
        and the date conversion library appears to have a bug, saying Daylight savings in the US is in effect on Oct 28, 2020, even tho its NOT til Nov 1, 2020
        the rest of the text doesn’t match anything in the Windows timezone list.
        so, it will be 1 hour off for a while.
          @Jonsar I have found a solution and have submitted changes to the ics parser library
          https://github.com/jens-maus/node-ical/issues/32
          and will submit changes to MM to match.
          https://github.com/MichMich/MagicMirror/issues/2171
          if U are interested I could send u the test files, chat message me if u are interested.
            Jonsar @sdetweil
            @sdetweil Not sure what changed but the times are now displaying as starting 5 hours before they are supposed to.
              sdetweil @Jonsar
              @Jonsar do another git pull. Latest update accepted on friday
                Jonsar @sdetweil
                @sdetweil I’m still on the branch origin/develop and it says I’m up to date.
                  sdetweil @Jonsar
                  @Jonsar hm… show me a vevent entry please.
                    Jonsar @sdetweil
                    As you can see, this event is scheduled to begin at 10:00am but is actually displaying on the calendar as starting at 5:00am.
                    BEGIN:VEVENT
                    UID:00D4F0F7-BF5A-45C4-B92F-41B8C771E111
                    SUMMARY:TEST
                    DTSTART;TZID="(UTC-05:00) Eastern Time (US & Canada)":20201123T100000
                    DTEND;TZID="(UTC-05:00) Eastern Time (US & Canada)":20201123T103000
                    CLASS:PUBLIC
                    PRIORITY:5
                    DTSTAMP:20201122T204236Z
                    TRANSP:OPAQUE
                    STATUS:CONFIRMED
                    SEQUENCE:0
                    END:VEVENT
                      sdetweil @Jonsar
                      @Jonsar I don’t see that
                      only your vevent in ics file, tz set to us eastern
                      Sunday, November 22, 2020
                      10:50:31pm
                      NEXT EVENT
                      TEST Tomorrow at 10:00 AM
                      if u set debug in config.js this is what I see
                      	logLevel: ["INFO", "LOG", "WARN", "ERROR","DEBUG"],
                      this is what I see
                       start=Mon Nov 23 2020 10:00:00 GMT-0500 (Eastern Standard Time) end=Mon Nov 23 2020 10:30:00 GMT-0500 (Eastern Standard Time)
                      initial tz=(UTC-05:00) Eastern Time (US & Canada)
                      corrected TZ=America/New_York
                      corrected tz=America/New_York
                      start date/time=Mon Nov 23 2020 10:00:00 GMT-0500 (Eastern Standard Time)
                      start offset=-300
                      start date/time w tz =Mon Nov 23 2020 10:00:00 GMT-0500 (Eastern Standard Time)
                      event date=Mon Nov 23 2020 10:00:00 GMT-0500 (Eastern Standard Time)
                      event offset=-300 hour=10 event date=Mon Nov 23 2020 10:00:00 GMT-0500 (Eastern Standard Time)
                      adjustHours=0
                        Jonsar @sdetweil
                        @sdetweil You’re right. Was totally on my end. Didn’t realize I had a file that was preventing the upgrade. After upgrading, works like a charm. Thanks for your help as always.
                          sdetweil @Jonsar
                          @Jonsar cool, glad u found it, and it works as you expected!
                          Thanks for the fast feedback
