    Copy of calendar
    7 Posts 2 Posters 1.0k Views 2 Watching
      panda974
      i tried with the default calendar to show only birthday events. we can filter “birthday” but not only show birthday.
      i succed to do it by modifying the file"calendarfetcher.js", row 436 : initial “return title.includes(filter);” to “return !title.includes(filter);”
      i tried to do a copy of the default module calendar to create a specific-calendar module but this is not working : always a loading message for the copy.
      I wanted a copy because I want a specific module only showing birthday and in the default calendar not showing birthday
      or maybe it is possible to show only birthday with the default module ?
        sdetweil @panda974
        @panda974 the calendar does not look for a field labeled birthday.
        As u have found u can filter/exclude events whos summary fields contain specific words
          panda974
          @sdetweil but I succed to do it with the default.
          that I tried to do is to copy the default module, rename it and use two modules “default calendar” and “specific calendar” with a filter for include only not exclude.
          but the copy dosn’t work and I don’t know how to do it
            sdetweil @panda974
            @panda974 the copy has to be moved out of the defaults folder
              panda974
              @sdetweil i did.
              with npm run start dev : no error but I have always a loading message for the specific calendar with all the same option as the default
                sdetweil @panda974
                @panda974 the fetcher info is displayed in the window where u did npm start.
                alt-spacebar, n to minimize mm
                  panda974
                  i found the module MMM-Mycalendar wich is a copy of the default calendar
                  I will try to do a copy of this and find a way to do my specific-calendar
                  thks
