    Copy of calendar
    7 Posts 2 Posters 922 Views 2 Watching
      sdetweil @panda974
      @panda974 the calendar does not look for a field labeled birthday.
      As u have found u can filter/exclude events whos summary fields contain specific words
        panda974
        @sdetweil but I succed to do it with the default.
        that I tried to do is to copy the default module, rename it and use two modules “default calendar” and “specific calendar” with a filter for include only not exclude.
        but the copy dosn’t work and I don’t know how to do it
          sdetweil @panda974
          @panda974 the copy has to be moved out of the defaults folder
            panda974
            @sdetweil i did.
            with npm run start dev : no error but I have always a loading message for the specific calendar with all the same option as the default
              sdetweil @panda974
              @panda974 the fetcher info is displayed in the window where u did npm start.
              alt-spacebar, n to minimize mm
                panda974
                i found the module MMM-Mycalendar wich is a copy of the default calendar
                I will try to do a copy of this and find a way to do my specific-calendar
                thks
