    Not all Modules are displaying on the tv
    34 Posts 6 Posters 14.7k Views 5 Watching
    • lavolp3L
      @sdetweil Thank you. It seems the hide and show calls in MMM-pages need to be amended by the (standard) lockstring to work properly.
      The module is after all expected to overwrite any other hide/show functionality.
      I had the same issue so I’ll try that out in the next days.
      How to troubleshoot modules
      MMM-soccer v2, MMM-AVStock
        sdetweil @lavolp3
        @lavolp3 Pages uses lockstring already
        module.hide(
                self.config.animationTime / 2,
                { lockString: self.identifier }
        module.show(
        uses the MMM-Pages module identifier as the string
          sdetweil @lavolp3
          @lavolp3 said in Not all Modules are displaying on the tv:
          it may need FORCE (it should check if the hide or show worked)
          • kusselinK
            kusselin
            OK. thank you for the detailed discussion. But what does that mean in plain language for everyone or for me as a not so html understanding?
            What must or can I change in my config.js so that it works again?
            Greeting
              sdetweil @kusselin
              @kusselin if you use MMM-Pages, every module must be described on some page, or in the fixed list (fixed means every page)
              • kusselinK
                kusselin
                @sdetweil said in Not all Modules are displaying on the tv:
                o.k. and how do i this with the describe?? Sorry, but can you give an example please with my config.js with MM-Traffic
                • mumblebajM
                  mumblebaj Module Developer @kusselin
                  @kusselin This is an example of mine.
                  Modules are either on Page1 or Page 2 and then I have modules (fixed) that display on all pages.
                  • kusselinK
                    kusselin
                    and this is mine:
                        			module: "MMM-pages",
                    		disabled: false,
                                				modules:
                    			[[ "MMM-SoccerLiveScore" ],
                    			[ "MMM-NowPlayingOnSpotify" ],
                    			[ "MMM-COVID19-AMPEL" , "MMM-Traffic" ],
                    			[ "MMM-Formula1" , "MMM-Spotify" ],
                    			[ "MMM-Globe" , "MMM-Spotify" ],
                    			[ "MMM-PublicTransportHafas" , "MMM-Spotify" ],
                    			[ "MMM-Worldclock" , "MMM-Spotify" ]],
                    				fixed: [ "clock" , "MMM-OpenmapWeather" , "weatherforecast" , "MMM-PublicTransportHafas" , "newsfeed" , "calendar" , "MMM-Fuel", "MMM-Tankerkoenig" , "MMM-ioBroker" ],
                        				rotationTime: 60000,
                    			animationTime: 0,
                    but what is there wromg?
                    • mumblebajM
                      @kusselin Have you tried running the module without the extra config? animationTime has default value of 0, disabled you probably don’t need to set and the rotationTime you probably don’t need to set for now.
                      • kusselinK
                        kusselin
                        @mumblebaj said in Not all Modules are displaying on the tv:
                        If I take out rotation time and duration time nothing happens either :-( traffic is not displayed although it is fixed … I don’t know what to do now … it’s strange …
                        've actually already stuck that with pages … fixed modules are always there and the others are then faded in!
                        • mumblebajM
                          @kusselin You are rotating the pages every 60 seconds? Correct? From what I understand, ever time the pages rotate a call is done to get data which would be true in the case of mmm-traffic. It could be that by the time the module get it’s data that the rotation has happened and then it does not display? I may be wrong. I don’t use the module myself.
                          • kusselinK
                            kusselin
                            I have now taken the code for my MMM-pages out of the config.js - strange then everything works! then traffic is displayed … so it is due to the MMM-pages module …
                            Question: Can the mmm-pages code be at the very end of the config.js or does it have to be at the beginning?
                            Question 2: the mmm-pages code from me is correct, right?
                            I have already set the time to 120,000, there too no traffic and current weather is displayed! :-( I’m with my Latain at the end :-(
                              sdetweil @kusselin
                              @kusselin said in Not all Modules are displaying on the tv:
                              what is the time value increment, seconds or milliseconds? if milliseconds, that 120,000 is just 2 minutes
                              • kusselinK
                                kusselin
                                exactly … milliseconds and two minutes should be long for a switch …
                                as I said, even if I take out the duration time it doesn’t work with traffic and the weather module :-(
                                I take the complete mmm-pages code out of the config, then everything works!
                                • mumblebajM
                                  @sdetweil I have had a look and I see the following:
                                  Will not show MMM-Traffic. LockStrings active: module_7_MMM-pages
                                  I assume this is why the MMM-Traffic is not showing when used in MMM-Pages? I have added the modules on my test machine and I can’t get the module to show either. I see that the above error comes from the main.js of MM. maybe you can shed more light on the issue for @kusselin
                                    sdetweil @mumblebaj
                                    @mumblebaj that is not an error. Just info.
                                    The module will ONLY be shown on its page, or if set to fixed.
                                    All the message says is pages hid it, and no-one else can show it
                                      Looks like this module manipulates the hidden status directly, instead of calling the hide/show api…
                                      • mumblebajM
                                        @sdetweil Yeah, doesn’t seem to play well with pages. The minute you remove paged the module works fine.
                                        • kusselinK
                                          kusselin
                                          Yep, that’s how I see it … the MMM traffic module cannot be used in combination with the MMM pages module !!
                                          • kusselinK
                                            kusselin
                                            MMM-Traffic definitely doesn’t work with the module “Pages” !!! And the weather module doesn’t work either if you run the “pages” module !! This is a pity :-(
                                            Can the developer of MMM Traffic and the MMM-OpenmapWeather take a look …
                                            here again my config:
                                            						modules:
                                            						[ "MMM-COVID19-AMPEL" ],
                                            						[ "MMM-Formula1" ]],
                                            			fixed: [ "clock" , "MMM-OpenmapWeather" , "weatherforecast" , "MMM-PublicTransportHafas" , "newsfeed" , "calendar" , "MMM-Fuel", "MMM-Tankerkoenig" , "MMM-ioBroker" , "MMM-Traffic" ],
                                                		rotationTime: 120000,
