    MMM-Button doesn't work
    11 Posts 2 Posters 8.2k Views 2 Watching
      Codejune
      Good morning.
      This time I’m adding a push button to my MagicMirror project.
      So, after searching, there was a module called MMM-Button.
      I cloned the module in ~ / MagicMirror / modules folder and added the module to the config file. However, when the npm start command is input to the terminal, the following error is displayed and only the white screen is output to the monitor.
      My npm version is 3.10.8.
      I also run
      npm install --save - dev electron - rebuild
      command, and
      rm - rf node_modules && npm install
      However, the error was not resolved.
      In addition to the above, I also tried
      npm rebuild --runtime = electron --target = 1.3.4 - disturl = https: //atom.io/download/atom-shell --abi = 50
      in the terminal. also tried to run
      npm rebuild --runtime = electron --target = 1.4.0 --disturl = https: //atom.io/download/atom-shell --build-from-source
      command but the problem is Expected 50, got In 48th, it was changed to Expected 50, got 49.
      magicmirror@2.0.0 start /home/pi/MagicMirror
      electron js/electron.js
      Loading config …
      Loading module helpers …
      WARNING! Could not load config file. Starting with default configuration. Error found: Error: Module version mismatch. Expected 50, got 49.
      App threw an error during load
      at Error (native)
      at process.module.(anonymous function) [as dlopen] (ELECTRON_ASAR.js:173:20)
      at Object.Module._extensions…node (module.js:583:18)
      at Object.module.(anonymous function) [as .node] (ELECTRON_ASAR.js:173:20)
      at Module.load (module.js:473:32)
      at tryModuleLoad (module.js:432:12)
      at Function.Module._load (module.js:424:3)
      at Module.require (module.js:483:17)
      at require (internal/module.js:20:19)
      at bindings (/home/pi/MagicMirror/modules/MMM-Button/node_modules/bindings/bindings.js:76:44)
      Whoops! There was an uncaught exception…
      at Error (native)
      Launching application.
      • L Offline
        lolobyte
        hi,
        see here…
        https://forum.magicmirror.builders/topic/948/error-found-error-module-version-mismatch-expected-50-got-46/7
          Codejune
          I have already run npm rebuild --runtime = electron --target = 1.4.5 --disturl = https: //atom.io/download/atom-shell --abi = 50, but Expected 50, got 49. The error is still output.
          • L Offline
            lolobyte
            at first u must check witch version u have.
            Error was in my electron:
            Error: Module version mismatch. Expected 50, got 51.
            Stat your shell an type following command in your MagicMirror folder: npm list | grep electron
            At result you must see something like this…
            pi@raspberrypi:~/MagicMirror $ npm list | grep electron
            ├─┬ electron-prebuilt@1.4.6
            │ ├─┬ electron-download@3.0.1
            npm ERR! extraneous: stylelint@7.5.0 /home/pi/MagicMirror/node_modules/stylelint
            What must be done here?
            at first change in your Button folder:
            cd ~/MagicMirror/modules/MMM-Button
            and then type in following command, you must change the version number with your own:
            npm rebuild --runtime=electron --target=1.4.6 --disturl=https://atom.io/download/atom-shell --abi=50
            That’s all.
              Codejune
              I have run the command in the project folder and have not run it from the module folder. So I guess it was not solved yet.
              This solves the problem. Thank you!
              • L Offline
                lolobyte
                you’re welcome.
                Have fun with your Mirror.
                Does the button work now with MMM-podcast?
                  Codejune
                  MMM-Podcast seems to be working correctly.
                  • L Offline
                    lolobyte @Codejune
                    @Codejune
                    nice, with gpio 5 and GND?
                      Codejune @lolobyte
                      @lolobyte Sure. By default, I put a Push Button on pin 5 and connected it to GND. As a result, I was able to see that it worked successfully.
                      Like this Image -> https://github.com/Codejune/WebImageStorage/blob/master/Result.jpg?raw=true
                      • L Offline
                        lolobyte @Codejune
                        @Codejune
                        are u in a club or a hw do it yourself organisation?
                          Codejune @lolobyte
                          @lolobyte I am a college student and I do not belong to any organization. I’m just studying alone, collecting money, buying or collecting parts, and doing my DIY MagicMirror project on my own.
