MagicMirror runs in small window after update
17 Posts 2 Posters 2.9k Views 2 Watching
    maxheartrate
    Hi, I just updated my Magic Mirror. After rebooting the mirror dashboard is no longer running in full screen. It looks like an overlay window without borders which is on top of the desktop.
    I did not change anything in my setup and have no clue where to look to fix this.
    I checked main.css and everything looks fine.
    Does anyone have an idea where this might come from and how to fix it?magicmirror-window.jpg
    S 1 Reply Last reply Dec 7, 2020, 10:34 PM Reply Quote 0
    • S Online
      sdetweil @maxheartrate
      @maxheartrate try ctrl-- ( minus sign)
      M 1 Reply Last reply Dec 8, 2020, 6:50 AM Reply Quote 0
        maxheartrate @sdetweil
        @sdetweil Hi Sam, CTRL + “-” decreases the size of the modules in the window. However, the Magic Mirror window’s overall size remains the same. I would like to show it full screen again so that I don’t see the desktop.
        Best, Max
          maxheartrate
          I just tried to start MM with npm start from the MagicMirror directory. Didn’t work.
          This is the message I receive:
          magicmirror@2.13.0 start /home/pi/MagicMirror
            maxheartrate
            I was able to almost fix my problem using
            electronOptions : { width: 1080, height: 1920 }
            However, I have a thin line from the desktop at the right and bottom edge shining through. The electron window does not cover the whole screen. I tried to use fullscreen: true and kiosk: trueand set the width and height to values higher than my display size but it didn’t change anything. Interesting though, when I set x: 1 in electronOptions to offset the window by a pixel, the thin line will disappear on the right side but appears on the left.
            Any ideas how to fix this? @sdetweil
            S 1 Reply Last reply Dec 8, 2020, 12:03 PM Reply Quote 0
            • S Online
              @maxheartrate x:0, and width: add one
              M 1 Reply Last reply Dec 8, 2020, 12:45 PM Reply Quote 0
                @sdetweil Thank you for your advise, Sam.
                This is what I already tried - and just tried again:
                electronOptions:{ x:0, width: 1081, height: 1921, fullscreen: false, kiosk: true }
                The problem remains the same. I also added more than one pixel to width and height but it wouldn’t change the result.
                S 1 Reply Last reply Dec 8, 2020, 12:47 PM Reply Quote 0
                • S Online
                  @maxheartrate kiosk sets full-screen to true
                  M 1 Reply Last reply Dec 8, 2020, 1:37 PM Reply Quote 0
                    @sdetweil O.k. Thank you for the information. I still wonder why the Magic Mirror does not cover the full desktop. Before the latest update, I did not see anything but the Mirror window.
                    S 1 Reply Last reply Dec 8, 2020, 1:41 PM Reply Quote 0
                    • S Online
                      @maxheartrate good question. Can u tell me the version.
                      grep version ~/MagicMirror/package.json
                      The develop branch is a big jump on electron version…
                      M 1 Reply Last reply Dec 9, 2020, 12:48 PM Reply Quote 0
