    CalendarEXT2 and Calendar (default)
    17 Posts 4 Posters 5.1k Views 4 Watching
      sdetweil @ankonaskiff17
      @ankonaskiff17 the default calendar has a lot of work done since last release. Download the develop branch for the fixes.
      See the instructions here
      https://forum.magicmirror.builders/topic/13770/2-13-calendar-fix-for-office-365-users/2
      It won’t help ext2. The author has left mm for family reasons, and no-one has taken over this module.
      ankonaskiff17A 1 Reply Last reply Reply Quote 0
      • BKeyportB Offline
        BKeyport Module Developer
        That’s called relative time.
        It’s easy to fix… in your config…
        CX2:
         useEventTimeRelative: false,
        https://github.com/MMM-CalendarExt2/MMM-CalendarExt2/blob/master/docs/Event-Time.md
        Calendar:
        urgency: 0,
        getRelative: 0,
        timeFormat: "absolute",
        • ankonaskiff17A Offline
          ankonaskiff17 @sdetweil
          @sdetweil I got the CalendarEXT2 done per another reply.
          I’m following your instructions at link but I get error telling me to either commit or stash clock.js, calendar.js, package-lock.json and package.json.
          I copied the contents of calendar, clock, config, css as I needed to do that (with css & config) anyway but my Noobie is showing in not knowing how to commit files. I can move if I need to.
          Also, which of those json files are being referred to?
          I get a hernia repaired later today so may be a couple of days.
            @ankonaskiff17 you should not change any module files unless u know what u are doing.
            package-lock.json is rebuilt, so not needed
            git checkout package-lock.json
            there are big changes in package.json, do u remember why u changed that?
            Unless u were fixing a bug by changing the code in clock and calendar. I would move the changes to config.js
            And then restore those files too
            git checkout Filename
              ankonaskiff17
              I think (but am far from sure) that any changes made to to those json files were done by MS VSCode automatically and not directly by me. That’s why I asked VSCode Question about committing changes, etc.
              VSCode and Github are both Microsoft products and entities meant to tightly integrate with each other, which I learned somewhat after the fact.
              What I think happened was those files were in the commit location, I posted my question and closed VSCode to hopefully get an answer, but clicking close in VSCode caused a commit.
              I just want a code editor with a save or save as option that also has good color coding and breaks out the code block hierarchy well.
              I want to mess with the code at my end as locally installed files. If I break a module, that’s on me alone then. I then just re-download the file, try to understand why it broke and start over.
              I’m not going to learn the language otherwise.
              I understand Github is a version control tool among other things but I did not know that a link existed between Github<---------->VSCode so that one doesn’t need to leave VSCode to for it to merge files on closing VSCode, hence my VSCode question.
                @ankonaskiff17 use winscp on windows. It will give u a file manager window over the files on pi (via ssh)
                Then I use notepad++ on my windows box to edit the files. By double clicking…
                because the mm folder working directory is managed by git, you can git diff to see what changed, and git checkout file to restore from the local repo to the working directory
                  ankonaskiff17
                  I use VNC client & server to essentially remote in to the Pi desktop directly. So I sit at Windows 10 laptop and access the Pi desktop.
                  For me as an end user with terrible typing skills I find VNC much easier to use.
                  I don’t have a clue how git works under the hood like you and developers do.
                  I understand conceptually the benefit it provides to developers who may be widely disbursed geographically.
                  I fired up GEANY which is part of the Pi OS programming software but initially found it very hard to read, so gave VSCode a shot which ended up being a bad choice on my part. I then poked around GEANY early yesterday prior to surgery and found some settings that made the code much more readable. It also looks like there is no built-in ability to commit files back to Github. So will use it going forward.
                  If an individual uses the automatic install vs manual, does the custom.css file get loaded pre-populated say with the default modules css settings or is it blank?
                  For me, as an end user with poor typing skills, I see plugging in the css values directly in to the module as steps saved rather than generating that same set over on the custom.css file that is not there initially, since I have no reason to send the original but css edited XYZ.js file back to github.
                    @ankonaskiff17 custom.css will be empty
                    Problem with changing main.css. like the other files, is update will be blocked because a file mm owns was changed.
                    I hate editing over vnc.
                      ankonaskiff17
                      @sdetweil That’s kind of funny, you hate VNC, I hate SSH. That’s what makes the world go round.
                      I’m not editing main.css really. At least not yet.
                      In the case of main.css I need to better understand how it works. If you remember, a few days ago I talked about needing to globally shrink some things, while globally enlarge other items. That was in reference to plugging in Pi to a bigger screen TV. They are about giving away 75" TV’s at Best Buy electronics stores for under $1000.00 so if you use a spare HDMI port on one of those, the modules are huge because the region is huge.
                      The clock default module would be 2 ft across. In that scenario, one would want to shrink things in the top_left and top_right globally while increasing the center regions for like an iFrame showing weather radar or a live YouTube stream in the middle portion. That also has the side benefit of allowing more modules on the screen the bigger the screen is.
                      All I’ve changed css that is internal to some of the modules. For example on the default calendar, there is a long list of defaults in the calendar.js file. Those default configuration settings are all basically css-like properties to me. But the calendar config file doesn’t contain that whole list of defaults when you copy from the module web page.
                      Since I am an end user, I just change the defaults in thecalendar.js file rather than copy it all over to the config.js file,
                      It gets even more complicated when the module is using an external program such as chartjs or momentjs as a wrapper I think is the term used.
                      It may not seem apparent but I do try and dig for the answer prior to posting the question.
                      S BKeyportB 3 Replies Last reply Reply Quote 0
                        @ankonaskiff17 I don’t edit in the ssh window. I use a file system connection over ssh to edit the file with the local system editor. Best of both worlds.
                          @ankonaskiff17 and if u edit the module source files, you get what u deserve when updates come…
                          • BKeyportB Offline
                            BKeyport Module Developer @ankonaskiff17
                            @ankonaskiff17 and I can’t hate either SSH or VNC. They both have their uses. I use a vertical mirror, so SSH is far more useful to me than VNC, but they both are useful.
                            I’m the kind of person that sets up SAMBA and shares the entire Pi drive over to Windows so I can edit directly, then use MMM-Remote-Control to restart my mirror when needed. 🤣
                              ankonaskiff17
                              Do updates load to my machine without me knowing? If they do, you’re right, that will be a problem.
                              If they are announced and I choose then I just copy the whole existing MM complex to sd card.
                              That way if update is bad I can revert. I imagine most end users are like me. They build a display, configure with a little tweaking and then rarely update,
                              I have two Pi’s running ADSB receivers and the underlying Raspian OS are several years since I’ve done apt update on either SSH’ed in to one just now. 2017
                                @ankonaskiff17 mm gets an update once every 3 months. Next jan 1.
                                I’ve spent most of the last quarter fixing the calendar module. Things u might want to update
                                  ankonaskiff17
                                  I’m going to move everything over to config.js but it would be nice if the sample config file that people copy paste contained all the configurable items.
                                  If there is a big list in the module code like this sample, can I just copy it in one big block, paste appropriately in config.js, change default to config and bracket appropriately and plug in my values and they’ll override the defaults lines in xyz.js even if they have values plugged in already.
                                  So that this sample config directly below becomes more like the second block?
                                              "module": "MMM-WeatherChart",
                                              "position": "top_right",
                                              **"config":** {
                                                  "apiKey": "xxxx",
                                                  "dataNum": 12,
                                                  "dataType": "hourly",
                                                  "height": "500px",
                                                  "width": "800px",
                                                  "lat": 35.571337,
                                                  "lon": 139.633989,
                                                  "units": "metric",
                                   defaults: {
                                          updateInterval: 10 * 60 * 1000,
                                          retryDelay: 5000,
                                          apiBase: "https://api.openweathermap.org/data/",
                                          apiVersion: "2.5",
                                          apiEndpoint: "onecall",
                                          apiKey: "",
                                          lat: "",
                                          lon: "",
                                          units: "standard",
                                          lang: "en",
                                          chartjsVersion: "2.9.3",
                                          chartjsDatalablesVersion: "0.7.0",
                                          height: "300px",
                                          width: "500px",
                                          fontSize: 16,
                                          dataNum: 24,
                                          timeOffsetHours: 0,
                                          title: "Weather Forecast",
                                          iconURLBase: "https://openweathermap.org/img/wn/",
                                          dataType: "hourly",
                                          nightBorderDash: [5, 1],
                                          showIcon: false,
                                          showRain: false,
                                          color: 'rgba(255, 255, 255, 1)',
                                          backgroundColor: 'rgba(0, 0, 0, 0)',
                                          fillColor: 'rgba(255, 255, 255, 0.1)',
                                          dailyLabel: 'date',
                                          hourFormat: "24h"
                                    Alvinger @ankonaskiff17
                                    @ankonaskiff17 In most cases the default values are set so that you do not need to change more than a few values to adjust to your needs. It makes no sense copying the entire config just to set the values to the default ones. That said, yes, you can copy the default block and change it to “config”, just remember to set the other module options appropriately.
                                    @sdetweil has put significant effort into the calendar module and done a great job of fixing all the quirks so expect the default calendar module to be really great in the next MM version! Just be sure to move all your config stuff to config.js so you can upgrade without issues.
