    Dual display
    Scheduled Pinned Locked Moved Unsolved Hardware
    21 Posts 9 Posters 26.2k Views 11 Watching
    • W Offline
      wemarch
      Hi Thommy,
      i bought the Gert VGA 666 board but could not try it out yet (i preferred to start another Raspi-project in the meantime).
      But since you are interested i will try to assemble that thing and connect two displays. Maybe i can try it this weekend.
      Luke
      • KirAsh4K Offline
        KirAsh4 Moderator
        While the description says it can drive both a VGA and HDMI connected monitors, resulting in a dual setup, MM is configured to launch one Electron screen. You might be able to run a side-by-side installation of MM and launch it on a secondary port, and I’m assuming it will launch a second Electron window that you will then have to position on screen. I just don’t know what will happen when/if you restart the rpi. Will it remember where the screens were positioned? only testing will answer that.
          Jeff
          I’m really interested if it works.
          Has anybody tried yet?
          • lolobyteL Offline
            lolobyte
            The Raspi can’t manage two displays!
            2 display’s = 2 raspi’s!
            J 1 Reply Last reply Reply Quote -1
              Jeff @lolobyte
              @lolobyte said in Dual display:
              Do you really mean the Raspi, or do you mean MagicMirror?
              There is a VGA Modul for the Rasp, to handle two displays.
              It’s just interesting if MM knows hof to show it correct on restart.
              lolobyteL 1 Reply Last reply Reply Quote 0
              • lolobyteL Offline
                lolobyte @Jeff
                @Jeff
                Hi jeff,
                the raspi has only a hdmi output and a output 4 a gpio display.
                It is not possible to really work with 2 display’s.
                U have a link to your VGA Module?
                If this module is really capable to run those 2 displays than u maybe can run a MM as web server build and one as MM2.
                If it’s possible to run two different MM2 instances i don’t really know that.
                Maybe it’s possible to run a second MM2 at another port!
                  Jeff @lolobyte
                  @lolobyte
                  https://www.raspberrypi.org/blog/gert-vga-adapter/
                  • lolobyteL Offline
                    lolobyte @Jeff
                    @Jeff
                    nice project.
                    SW is in development!
                    • W Offline
                      wemarch
                      Hey everybody, finally i managed to solder the GERT VGA-adapter!
                      I hope to find the time to test if it works this week. i will share my experiences here :-)
                        Jeff
                        Looking forward seeing your experiences ;)
