    MMM-LocalTemperature doesn't work :(
    6 Posts 4 Posters 1.4k Views 4 Watching
    • I Offline
      Ipsopedion
      Hi guys,
      I’m trying to make a magic mirror as a school project. We are using a DHT-22 sensor to get local temperature and humidity but it doesn’t work. I’ve been working on it for 4 days now and I can’t find any solution :(
      Here is my config.js and how i wired it
      BTW : I have a python script on the py that reads datas from dht 22 soooo ://
      Thanks,
      Ipso
      • I Offline
        Ipsopedion
        Update : I’ve tried other modules (dht-22 & DHT-22) but nothing changed :/
        But my script still works so I was wondering if there’s a way to use it in a module ?
        I’m clearly a beginner so I somebody as any clue for me ://
        Ipso
        • ankonaskiff17A Offline
          ankonaskiff17
          Have you looked in the 3rd Party modules section? There are several DHT sensor modules in there you can use for reference, Just do text search on DHT
            jimus888
            Hi
            I have the module working, but had to specify the pin scheme for it to work. It wouldn’t work for me without this config line.
            See below
                                module: "MMM-LocalTemperature",
                                header: "Inside Temperature",
                                        pinScheme: "WPI",
                                        sensorPin: 0,
                                        fontsize: "medium",
                                        updateInterval: 1,
                                        showTemperature: true,
                                        showHumidity: true,
            • I Offline
              Ipsopedion @jimus888
              @jimus888 Thanks for your answer, but still doesn’t work :!
              The module seems to load forever :/
              I’ve tried apt-get update && apt-get full-upgrade but nothing seems to work :/
                sdetweil @Ipsopedion
                @Ipsopedion said in MMM-LocalTemperature doesn't work :(:
                That means the default message was put up while the module is waiting for data… but hasn’t yet received it
                Can u should the output where u start magic mirror? Either the terminal window for npm start,
                Or if using pm2, the output of pm2 logs --lines=???, where ??? Is a number, defaults to 15
