    Mi Temperature2 with xiaomi hygromether
    17 Posts 6 Posters 6.0k Views 5 Watching
    • rubenixR
      rubenix
      Hey @Stoffbeuteluwe yeah seen that but unfortunately do not have the gateway.
      As the pi has BT it can connect directly to the hygrometer (have it next to it). python program works great but would be nice to show the info on the mirror…
        rubinho101
        Hi @rubenix , I wanna do the same thing without a gateway. I got a LYWSDCGQ Temp and Humidity sensor. I am able to read the values with mitemp and btlewrap on a Rpi4, but dont know yet how to plot the data to MMM efficiently. Any ideas?
        • rubenixR
          rubenix
          Sorry @rubinho101 do not have a clue; Thats why I asked here.
          Hope someone can help us :crossed_fingers_light_skin_tone:
          There are loots of brilliant minds here :call_me_hand_light_skin_tone:
          Two Rubens all over the world looking for the same f thing…LOL
          seen your post answering mine on github too…
          • rubenixR
            rubenix
            no one can give some instructions for a newby?
            • A
              Albert2002
              I would be interested in this module as well. Am not able to code, but at least am able test.
              rubenixR 1 Reply Last reply Reply Quote 0
              • rubenixR
                rubenix @Albert2002
                @Albert2002 am not a coder neither but i can check/test too
                at the moment data its stored on a txt file so next move its creating my very first module (I should have underlined and bold that) / grab the text from the txt file created by the python script and display it on the Mirror; sounds like easy (sure it is) but its a big deal for me as im not a coder and have no much time to look at…
                like every single thing on earth it needs understanding on what we need (this its kinda sorted) and how it can be accomplished (thats the thing) --> so it means TIME :eleven-thirty: :eleven_o_clock:
                hope someone can give us a kindly hand on this :call_me_hand_light_skin_tone:
                  rubinho101
                  @rubenix @Albert2002 I created a module to display the values without the gateway. It works fine for me.
                  https://github.com/rubinho101/MMM-01ZM
                    A Former User
                    powa … what a lot of courage for installing :/ (I’m thinking to newbies)
                    Please, try to do better with a package.json file… (eventually take a look in any installer in my modules)
                      sdetweil @rubinho101
                      @rubinho101 followup to @Bugsounet’s recommendation,
                      npm init
                      Will prompt u thru creating the package.json
                      npm install ??? -save will add the library ?? to the package.json dependencies, so npm install will do the work.
                      For non-node libraries, u can use the postinstall script to do the work for your pip libraries.
                      And u could use sed to change the code u need to fix…
                      • rubenixR
                        rubenix
                        Thanks @rubinho101 I’ve the LYWSD03MMC version not the LYWSDCGQ so I don’t know if this actually will work…
                        Instructions are detailed but seems quite confusing for a newbie like me…:confused_face:
                          rubinho101 @sdetweil
                          @sdetweil thanks for your input. I have setup the package.json and postinstaller.sh. The postinstaller works fine when I run bash postinstaller.sh from the console. But when the package.json invokes the postinstaller I got the following errors:
                          sh: 1: img/postinstaller.sh: Permission denied
                          npm ERR! code ELIFECYCLE
                          npm ERR! errno 126
                          npm ERR! mmm-01zm@0.0.5 postinstall: `img/postinstaller.sh`
                          npm ERR! Exit status 126
                          npm ERR!
                          npm ERR! Failed at the mmm-01zm@0.0.5 postinstall script.
                          How can the shell be executed without giving it permissions / running it manually from the console?
                            rubinho101 @rubenix
                            @rubenix said in Mi Temperature2 with xiaomi hygromether:
                            To my understanding there are some fundamental differences between the LYWSDCGQ and LYWSD03MMC. Whereas the former sends the data in the Advertisement Channels (so basically anyone can read the values), your sensor requires (a more privacy friendly) actual connection. I assume while this connection is established no other BLE devices can be parsed. https://github.com/JsBergbau/MiTemperature2 should work for your sensor. Maybe I find some time to integrate this library as well and a concept for BLE balancing depending on the type and number of sensors.
                            • rubenixR
                              rubenix @rubinho101
                              @rubinho101 said in Mi Temperature2 with xiaomi hygromether:
                              yeah thats it, thats the link I posted on the 1st post actually, and it works with that indeed (read first post)
                                @rubinho101 u need to.mark the postinstall script executable.
                                chmod +x filename
                                  rubinho101
                                  @sdetweil I added the postinstaller.sh and I hope it’s easier for newbies to get the module run. In addition, I added an option for the SDS011 PM Air Quality sensor and a correction function based on current humidity.
