    Mi Temperature2 with xiaomi hygromether
    17 Posts 6 Posters 4.8k Views 5 Watching
      rubinho101
      Hi @rubenix , I wanna do the same thing without a gateway. I got a LYWSDCGQ Temp and Humidity sensor. I am able to read the values with mitemp and btlewrap on a Rpi4, but dont know yet how to plot the data to MMM efficiently. Any ideas?
      • rubenixR Offline
        rubenix
        Sorry @rubinho101 do not have a clue; Thats why I asked here.
        Hope someone can help us :crossed_fingers_light_skin_tone:
        There are loots of brilliant minds here :call_me_hand_light_skin_tone:
        Two Rubens all over the world looking for the same f thing…LOL
        seen your post answering mine on github too…
        • rubenixR Offline
          rubenix
          no one can give some instructions for a newby?
            Albert2002
            I would be interested in this module as well. Am not able to code, but at least am able test.
            rubenixR 1 Reply Last reply Reply Quote 0
            • rubenixR Offline
              rubenix @Albert2002
              @Albert2002 am not a coder neither but i can check/test too
              at the moment data its stored on a txt file so next move its creating my very first module (I should have underlined and bold that) / grab the text from the txt file created by the python script and display it on the Mirror; sounds like easy (sure it is) but its a big deal for me as im not a coder and have no much time to look at…
              like every single thing on earth it needs understanding on what we need (this its kinda sorted) and how it can be accomplished (thats the thing) --> so it means TIME :eleven-thirty: :eleven_o_clock:
              hope someone can give us a kindly hand on this :call_me_hand_light_skin_tone:
                rubinho101
                @rubenix @Albert2002 I created a module to display the values without the gateway. It works fine for me.
                https://github.com/rubinho101/MMM-01ZM
                  A Former User
                  powa … what a lot of courage for installing :/ (I’m thinking to newbies)
                  Please, try to do better with a package.json file… (eventually take a look in any installer in my modules)
                    sdetweil @rubinho101
                    @rubinho101 followup to @Bugsounet’s recommendation,
                    npm init
                    Will prompt u thru creating the package.json
                    npm install ??? -save will add the library ?? to the package.json dependencies, so npm install will do the work.
                    For non-node libraries, u can use the postinstall script to do the work for your pip libraries.
                    And u could use sed to change the code u need to fix…
                    • rubenixR Offline
                      rubenix
                      Thanks @rubinho101 I’ve the LYWSD03MMC version not the LYWSDCGQ so I don’t know if this actually will work…
                      Instructions are detailed but seems quite confusing for a newbie like me…:confused_face:
                        rubinho101 @sdetweil
                        @sdetweil thanks for your input. I have setup the package.json and postinstaller.sh. The postinstaller works fine when I run bash postinstaller.sh from the console. But when the package.json invokes the postinstaller I got the following errors:
                        sh: 1: img/postinstaller.sh: Permission denied
                        npm ERR! code ELIFECYCLE
                        npm ERR! errno 126
                        npm ERR! mmm-01zm@0.0.5 postinstall: `img/postinstaller.sh`
                        npm ERR! Exit status 126
                        npm ERR!
                        npm ERR! Failed at the mmm-01zm@0.0.5 postinstall script.
                        How can the shell be executed without giving it permissions / running it manually from the console?
