    Need help - New programmer
    23 Posts 5 Posters 5.6k Views 5 Watching
      sdetweil @smart_user
      @smart_user you could use my sample module which puts up a configured message every few minutes. Change the message and the time…
      https://github.com/sdetweil/SampleModule
        smart_user @ashishtank
        @ashishtank Yes I will look into it. Thank you so much for the instant reply. Appreciate it a lot
          smart_user @sdetweil
          @sdetweil Thank you so much! I will use this module and let you know how it goes!
            @smart_user ok. Timer is in the node_helper.
            It is a one time timer, setTimer, vs repeating, setInterval.
            Doesn’t need to be in the node_helper, but did that to show the structure and communication between the parts
              smart_user
              @sdetweil It still isn’t working. I had configured for the alert to show up in 10 seconds but it didn’t
                @smart_user you changed the 15000 in node_helper to 10000, right?
                And u had a position: set in config.js, right?
                  smart_user
                  @sdetweil Yes
                    smart_user
                    @sdetweil Is it possible for you to send me a picture of the .js file so I can double check?
                      @smart_user u can look on the github site
                      View code. Then click on file.
                      If you used git clone, then u can do
                      git diff node_helper.js
                      to see the differences
                        smart_user
                        @sdetweil Hello. I did and still am not receiving any alert on the screen
                          @smart_user show me the config block. Minimum is this. MUST have a position
                               module:"SampleModule",
                               position:"middle",
                            [[global:former-user]]
                            euh … position needed ONLY if you have to show something on the mirror (getDom).
                            If you have nothing to show THEN position is not needed
                            Note: verified in my lasted module (position is not needed because no visual)
                              sdetweil @Guest
                              @Bugsounet yes, my sample module DOES want to display something
                                smart_user
                                @sdetweil Yes! I missed adding the position to the config file. Just have another clarification. Can these messages show up for a few seconds then disappear and then appear again after 30 minutes? If so, how do I do that?
                                  @smart_user sure. When u want the message to go away, set the string to empty, or not create any content in getDom()…
                                  U would start a timer after u display the text, and the call updateDom() in the timer routine.
                                  Wait, display. Wait. Remove output
                                  Repeat
                                  • I Offline
                                    innovation
                                    @sdetweil Hello, I am facing the same problem - and I want the same feature @smart_user mentioned. But I am sorry, I didn’t get the timer part. Which string are you talking about? and where will I add the updateDom()? Please help
                                      sdetweil @innovation
                                      @innovation i have my grandson for a few hours will get back to you
                                      • I Offline
                                        innovation
                                        sure @sdetweil, no problem!
                                          @innovation the ‘string’ is the value used in the getDom() function to create the html content
                                          somestring:“this is just a test string”,
                                          counter: 0,
                                          getDom(){
                                             var wrapper=createElement("div")
                                             wrapper.innerText=this.somestring
                                             return wrapper;
                                          there is no stopping the module, it MUST always be running… so, if u want to change the string,
                                          you can start a timer, and when the timer expires, call a routine that does the work.
                                          timerRoutine: function(){
                                               this.somestring="some other string"
                                          but how does MM know u changed the value?
                                          u tell MM there is new content…
                                               this.somestring="some other string "+ this.counter++;
                                               this.updateDom(time_to_delay_in_ms, 0 = immediately)
                                          now we need to start a timer… lets say, 15 seconds after we do it in getDom, lets change the text
                                          getDom(){
                                             var wrapper=createElement("div')
                                             wrapper.innerText=this.somestring  // use the value of the somestring variable to display
                                            setTimeout(this.timerRoutine, 15000)   // call the timerRoutine in 15000 milliseconds
                                             return wrapper;
                                             // after here , MM will put the html tree defined in wrapper,
                                             // in the 'position' the module  defined in config.js
                                          another way is to use the repeating timer, instead of the single event version
                                          start: {
                                              // now the timerRoutine will be called every 15 seconds, forever
                                              // it will change the string, and then inform MM to call to get new content
                                              setInterval(this.timerRoutine,15000) //  start a repeating timer  every 15 seconds
                                          getDom(){
                                             return wrapper;
                                          you can do this same updateDom() call after receiving a message back from your node helper with new content.
                                          (my sample module does this)
                                          • I Offline
                                            innovation
                                            @ sdetweil, this is what I have entered in the js file. I am still not getting it:
                                            sample module structure
                                            Module.register("SampleModule", {
                                            // define variables used by module, but not in config data
                                            some_variable:  true,
                                            some_other_variable: "a string",
                                            // holder for config info from module_name.js
                                            config:null,
                                            // anything here in defaults will be added to the config data
                                            // and replaced if the same thing is provided in config
                                            defaults: {
                                            message: "STAY HYDRATED! DRINK A GLASS OF WATER"
                                            init: function(){
                                            Log.log(this.name + " is in init!");
                                            start: function(){
                                            Log.log(this.name + " is starting!");
                                            loaded: function(callback) {
                                            Log.log(this.name + " is loaded!");
                                            callback();
                                            // return list of other functional scripts to use, if any (like require in node_helper)
                                            getScripts: function() {
                                            return	[
                                            // sample of list of files to specify here, if no files,do not use this routine, or return empty list
                                            //'script.js', // will try to load it from the vendor folder, otherwise it will load is from the module folder.
                                            //'moment.js', // this file is available in the vendor folder, so it doesn't need to be available in the module folder.
                                            //this.file('anotherfile.js'), // this file will be loaded straight from the module folder.
                                            //'https://code.jquery.com/jquery-2.2.3.min.js',  // this file will be loaded from the jquery servers.
                                            // return list of stylesheet files to use if any
                                            getStyles: function() {
                                            return [
                                            // sample of list of files to specify here, if no files, do not use this routine, , or return empty list
                                            //'script.css', // will try to load it from the vendor folder, otherwise it will load is from the module folder.
                                            //'font-awesome.css', // this file is available in the vendor folder, so it doesn't need to be avialable in the module folder.
                                            //this.file('anotherfile.css'), // this file will be loaded straight from the module folder.
                                            //'https://maxcdn.bootstrapcdn.com/bootstrap/3.3.6/css/bootstrap.min.css',  // this file will be loaded from the bootstrapcdn servers.
                                            // return list of translation files to use, if any
                                            /*getTranslations: function() {
                                            return {
                                            // en: "translations/en.json",  (folders and filenames in your module folder)
                                            // de: "translations/de.json"
                                            // only called if the module header was configured in module config in config.js
                                            // getHeader: function() {
                                            //	return this.data.header + " Foo Bar";
                                            // messages received from other modules and the system (NOT from your node helper)
                                            // payload is a notification dependent data structure
                                            // once everybody is loaded up
                                            if(notification==="ALL_MODULES_STARTED"){
                                            // send our config to our node_helper
                                            this.sendSocketNotification("CONFIG",this.config)
                                            if (sender) {
                                            Log.log(this.name + " received a module notification: " + notification + " from sender: " + sender.name);
                                            } else {
                                            Log.log(this.name + " received a system notification: " + notification);
                                            // messages received from from your node helper (NOT other modules or the system)
                                            // payload is a notification dependent data structure, up to you to design between module and node_helper
                                            Log.log(this.name + " received a socket notification: " + notification + " - Payload: " + payload);
                                            if(notification === "message_from_helper"){
                                            this.config.message = payload;
                                            // tell mirror runtime that our data has changed,
                                            // we will be called back at GetDom() to provide the updated content
                                            this.updateDom(1000)
                                            // system notification your module is being hidden
                                            // typically you would stop doing UI updates (getDom/updateDom) if the module is hidden
                                            suspend: function(){
                                            // system notification your module is being unhidden/shown
                                            // typically you would resume doing UI updates (getDom/updateDom) if the module is shown
                                            resume: function(){
                                            // this is the major worker of the module, it provides the displayable content for this module
                                            start: {
                                            getDom (){
                                               return wrapper;
                                            // if user supplied message text in its module config, use it
                                            if(this.config.hasOwnProperty("message")){
                                            // using text from module config block in config.js
                                            wrapper.innerHTML = this.config.message;
                                            else{
                                            // use hard coded text
                                            wrapper.innerHTML = "Hello world!";
                                            // pass the created content back to MM to add to DOM.
                                            return wrapper;
