    Need help - New programmer
    23 Posts 5 Posters 4.7k Views 5 Watching
      smart_user @ashishtank
      @ashishtank Yes I will look into it. Thank you so much for the instant reply. Appreciate it a lot
        smart_user @sdetweil
        @sdetweil Thank you so much! I will use this module and let you know how it goes!
          sdetweil @smart_user
          @smart_user ok. Timer is in the node_helper.
          It is a one time timer, setTimer, vs repeating, setInterval.
          Doesn’t need to be in the node_helper, but did that to show the structure and communication between the parts
            smart_user
            @sdetweil It still isn’t working. I had configured for the alert to show up in 10 seconds but it didn’t
              @smart_user you changed the 15000 in node_helper to 10000, right?
              And u had a position: set in config.js, right?
                smart_user
                @sdetweil Yes
                  smart_user
                  @sdetweil Is it possible for you to send me a picture of the .js file so I can double check?
                    @smart_user u can look on the github site
                    View code. Then click on file.
                    If you used git clone, then u can do
                    git diff node_helper.js
                    to see the differences
                      smart_user
                      @sdetweil Hello. I did and still am not receiving any alert on the screen
                        @smart_user show me the config block. Minimum is this. MUST have a position
                             module:"SampleModule",
                             position:"middle",
