    Need help - New programmer
    23 Posts 5 Posters 4.7k Views 5 Watching
      smart_user @sdetweil
      @sdetweil Thank you so much! I will use this module and let you know how it goes!
        sdetweil @smart_user
        @smart_user ok. Timer is in the node_helper.
        It is a one time timer, setTimer, vs repeating, setInterval.
        Doesn’t need to be in the node_helper, but did that to show the structure and communication between the parts
          smart_user
          @sdetweil It still isn’t working. I had configured for the alert to show up in 10 seconds but it didn’t
            @smart_user you changed the 15000 in node_helper to 10000, right?
            And u had a position: set in config.js, right?
              smart_user
              @sdetweil Yes
                smart_user
                @sdetweil Is it possible for you to send me a picture of the .js file so I can double check?
                  @smart_user u can look on the github site
                  View code. Then click on file.
                  If you used git clone, then u can do
                  git diff node_helper.js
                  to see the differences
                    smart_user
                    @sdetweil Hello. I did and still am not receiving any alert on the screen
                      @smart_user show me the config block. Minimum is this. MUST have a position
                           module:"SampleModule",
                           position:"middle",
                        A Former User
                        euh … position needed ONLY if you have to show something on the mirror (getDom).
                        If you have nothing to show THEN position is not needed
                        Note: verified in my lasted module (position is not needed because no visual)
