    Trafficmaps
    63 Posts 11 Posters 91.2k Views 12 Watching
      Jeff @wscheer
      @wscheer
      Is this modul still working?
      I did everthing you explained:
      in my config.js:
                            module: 'maproute',
                            position: 'middle_center',
      And /var/www/html/MagicMirror/modules/maproute/maproute.js is the code from above.
      I’ve created an API for Bing maps.
      But if I run MM I just see a small image. Like the right picture could not be found.
      And if I look to the report om bing how often my API was used, it counts 0.
      Where is the mistake?
      W 1 Reply Last reply
      • W
        wscheer @Jeff
        @Jeff yeah mine is still working.
        To troubleshoot you could run magic mirror in “standalone” mode. That would let you view the page on a desktop computer and you can look at the browser console to see what the errors are.
        Let me know if you need more instructions on that. I’m on a mobile right now. I could add more later.
        J 1 Reply Last reply
          Jeff @wscheer
          @wscheer
          Thanks for your quick reply.
          Can you just tell me how to enter the “standalone” mode?
          thanks
          • W
            wscheer @Jeff
            @Jeff yeah
            execute the following command from the MagicMirror folder: “node serveronly”. This will start the server, after which you can open the application in your browser of choice.
              Jeff @wscheer
              @wscheer
              oh okay, I already did that and the command line said my page was created correctly.
              But in teh browser it said page not found.
              I think that’s a different problem and I have to handle that first…
                Jeff
                Now I can open the MM in the webbrowser.
                What should I do now?
                • W
                  wscheer @Jeff
                  @Jeff Ok so now if you load the page and you still see the broken image, the browser can help you find out what the problem is.
                  If you use firefox, hit F12 and reload the magic mirror page you can see if there are any errors being reported. When I was first testing mine, I had an typo in the api string and I couldn’t really see it until I looked at it in the browser.
                  Let me know if that helps, or post some screenshots of any errors and hopefully I can help :)
                    Jeff @wscheer
                    @wscheer
                    I’ve installed Firefox:
                    Initializing MagicMirror.  logger.js:17:4
                    Loading core translation file: translations/de.json  logger.js:20:4
                    Loading core translation fallback file: translations/en.json  logger.js:20:4
                    Load script: modules/default/alert//alert.js  logger.js:20:4
                    Module registered: alert  logger.js:20:4
                    Bootstrapping module: alert  logger.js:17:4
                    Load script: modules/default/alert//classie.js  logger.js:20:4
                    Load script: modules/default/alert//modernizr.custom.js  logger.js:20:4
                    Load script: modules/default/alert//notificationFx.js  logger.js:20:4
                    Scripts loaded for: alert  logger.js:20:4
                    Load stylesheet: modules/default/alert//ns-default.css  logger.js:20:4
                    Styles loaded for: alert  logger.js:20:4
                    alert - Load translation: translations/de.json  logger.js:20:4
                    alert - Load translation fallback: translations/en.json  logger.js:20:4
                    Translations loaded for: alert  logger.js:20:4
                    Load script: modules/maproute//maproute.js  logger.js:20:4
                    Module registered: maproute  logger.js:20:4
                    Bootstrapping module: maproute  logger.js:17:4
                    Scripts loaded for: maproute  logger.js:20:4
                    Styles loaded for: maproute  logger.js:20:4
                    Translations loaded for: maproute  logger.js:20:4
                    Load stylesheet: css/custom.css  logger.js:20:4
                    Starting module: alert  logger.js:17:4
                    All modules started!  logger.js:17:4
                    maproute received a system notification: ALL_MODULES_STARTED  logger.js:20:4
                    maproute received a system notification: DOM_OBJECTS_CREATED  logger.js:20:4
                    GET
                    http://dev.virtualearth.net/REST/v1/Imagery/Map/Road/40.4406,-79.9959/12 [HTTP/1.1 401 Unauthorized 108ms]
                    I think I have a wrong API access, but I think I did everything as described…
                    • W
                      wscheer @Jeff
                      @Jeff Ok now we are getting somewhere.
                      Try this:
                      In your browser, paste this url but add your bing maps api key at the end. Mine looks like this (i replaced some characters with #)
                      ######ss9ZpK9lZjPRNo78Xp######xM_zjDmyQ2M5GmkzcOUhW2BYmO######-2
                      http://dev.virtualearth.net/REST/v1/Imagery/Map/Road/40.4406,-79.9959/12?mapSize=500,500&ml=TrafficFlow&key= ADD YOUR API KEY HERE
                      When you do that, you should see the map all by itself. That would tell you if it was an issue with your api key itself.
                      If that works, double check the api key was copied right in the config section
                      “api_key: ‘123456789’, // Your Bing maps api key”
                      Let me know what you find
                        Jeff
                        @wscheer
                        Okay your link with my API worked…
                        I put my API key in the maproute.js file as the default key. Maybe that is the problem.
                        How should the config.js file look?
                        Like this?
                                        latitude: '40.4406', // City latitude. Use google to get these coordinates
                                        longitude: '-79.9959', // City longitude
                                        map_zoom: '12', // 1 - 21
                                        map_layer: 'TrafficFlow',
                                        map_size: '500', // Using this for both length and width
                                        api_key: 'xxxxx', // Your Bing maps api key
                                        updateInterval: 300000 // 5 min refresh
                        • W
                          wscheer @Jeff
                          @Jeff yeah. Just replace the xxxx with your API key.
                            Jeff @wscheer
                            @wscheer
                            That’s what I did.
                            I really don’t know what’s going on.
                            Maybe I should just implement it as a final picture
                            • W
                              wscheer @Jeff
                              @Jeff ok Jeff I have an idea.
                              Can you look at your magic mirror page in server only mode again? Then if you right click and “inspect” the broken image you should see the url its trying to reach.
                              Compare that to the url I had you copy paste in with your API that worked.
                              Then if there is some sort of difference we should be able to track it down.
                                Jeff @wscheer
                                @wscheer
                                I found the mistake ;)
                                In your maproute.js it says “map_key” not “api_key”.
                                • W
                                  wscheer @Jeff
                                  @Jeff omg I’m such a doof. I’ll go back in my previous post and fix that.
                                  I’m so glad you got it working! I searched for months to find a map like this. I hope you enjoy it :)
                                  • Z
                                    Zoltan @wscheer
                                    @wscheer
                                    My map is working and it shows the traffic. I however also have a map that don’t update and tried the Math.random() that you mentioned. The moment i add this to the line my map disappear completely which suggest i broke something. Do i interpret it wrong and can you please advise.
                                    Like this the code is working fine:
                                    wrapper.src = ‘http://dev.virtualearth.net/REST/v1/Imagery/Map/Road/-26.0460,27.9790/13?mapSize=500,420&ml=TrafficFlow&key=Asm#####AJWIWc5o8Onf4fhH8O3IEe2e8ZcHaLTBWhx4_BWTvOW4S5xj60MuUJf4’;
                                    Like this it isn’t working:
                                    wrapper.src = ‘http://dev.virtualearth.net/REST/v1/Imagery/Map/Road/-26.0460,27.9790/13?mapSize=500,420&pp=Math.random(),Math.random()&ml=TrafficFlow&key=Asm#####AJWIWc5o8Onf4fhH8O3IEe2e8ZcHaLTBWhx4_BWTvOW4S5xj60MuUJf4’;
                                    • strawberry 3.141S
                                      strawberry 3.141 Project Sponsor Module Developer @Zoltan
                                      @zoltan try the following:
                                      wrapper.src = 'http://dev.virtualearth.net/REST/v1/Imagery/Map/Road/-26.0460,27.9790/13?mapSize=500,420&pp=' + Math.random() + ',' + Math.random() + '&ml=TrafficFlow&key=Asm#####AJWIWc5o8Onf4fhH8O3IEe2e8ZcHaLTBWhx4_BWTvOW4S5xj60MuUJf4';
                                      This way you use the actual value and not Math.random() as a string.
                                      Z 1 Reply Last reply
                                      • Z
                                        Zoltan @strawberry 3.141
                                        @strawberry-3-141 said in Trafficmaps:
                                        http://dev.
                                        Thanks very much. You are a legend. It’s finally working after me trying everything that I could think of.
                                        One of my biggest mistakes was I started with “http:// and ended with jf4”; which works fine without the Math.random. Clearly ‘ was the way to go and not “.
                                        • strawberry 3.141S
                                          @zoltan ' and " makes no difference. Your problem was, that you didn’t seperate the function call Math.random() from the link as text. So you literally had Math.random() in your link.
                                          • Z
                                            @strawberry-3-141 Ok, then it was me chasing ghosts again lol. I really appreciate the help and advice, thanks.
                                            • 3 / 4
