    MM does not start full screen (pi Zero)
    20 Posts 3 Posters 6.0k Views 3 Watching
      sdetweil @ashishtank
      @ashishtank I know. i was talking to @jthewarrior7
        jthewarrior7
        Yes it is indeed chromium
          sdetweil @jthewarrior7
          @jthewarrior7 ok, if u close mm, pm2 stop 0.
          then start chromium manually. (probably from terminal window), does it open to fill the screen?
            jthewarrior7
            I have started the chromium-browser , which opens in the same size as the magic mirror.
              ashishtank Module Developer @jthewarrior7
              @jthewarrior7 May be it is remembering the last opened size of browser ? can you maximize it then close and reopen it ? Is it open maximized ? Then try with Mirror script.
                @ashishtank but the script (run-start.sh), requests maximize…
                  jthewarrior7
                  Chromium indeed remembers the size when I reopen it after increasing the window size, and also the kiosk mode of chromium opens in this size. Unfurtunately the MM still opens in its original size.
                  Is it maybe possible to start up the MM in the non-kiosk mode, then adjust the size/position and turn it back into kiosk?
                    @jthewarrior7 sure, edit the run-start.sh and remove ‘-kiosk’ from the parameters
                     chromium-browser -noerrdialogs -kiosk -start_maximized  --disable-infobars --app=http://localhost:$port  --ignore-certificate-errors-spki-list --ignore-ssl-errors --ignore-certificate-errors 2>/dev/null
                    hm… looking thru the flags supported, it says all need double dash in front… so, add a dash to -maximized
                    and -kiosk
                    https://peter.sh/experiments/chromium-command-line-switches/
                      @jthewarrior7 u can also try adding the window-size parm.
                      --window-size ⊗	Sets the initial window size. Provided as string in the format "800,600".
                        jthewarrior7
                        Thanks for these tips, I will try if that works and let you know :)
                          @jthewarrior7 ok, I am trying to change my pi0 orientation to test
                            @jthewarrior7 mine came up full screen without any script changes
                              jthewarrior7
                              The --start-maximized but also the --window-size does not seem to have any effect. I tried them both when opening a new chromium window via the console (chromium-browser --start-maximized, but the chromium still launches at its previously closed size and position.
                                @jthewarrior7 try --start-fullscreen
                                this seems to work on my pi0, where --start-maximized does not
                                  jthewarrior7
                                  start fullscreen removes the top bar etc. but strangely enough the size of the chromium window does not go to fullscreen.
                                    @jthewarrior7 weird… kiosk is what removes the titlebar
