MM only server version working due to issues with config file
Yes, I checked the filename several times, its fine. The config file is also accessible via file:///home/pi/MagicMirror/config/config.js
@legan can I see the address: and ipWhitelist: settings from config.js
make them
address:"0.0.0.0", ipWhitelist:[],
@sdetweil I extended the whitelist and enabled all IP addresses. But still not working
@legan if u set it to [] that is all
@sdetweil said in MM only server version working due to issues with config file:
all
exactly, that’s what I did
@legan and address is localhost or 0.0.0.0?
@sdetweil now it’s working! Thank you very much you saved my tech mood though! :D
Have a good one! :)
@legan what did you do ?
@sdetweil I followed your instructions, and after changing localhost to 0.0.0.0.
I was able to start the mirror
