Can I rotate the pages (MMM-Pages) with MMM-TelegramBot or MMM-RemoteControl?
9 Posts 3 Posters 1.1k Views 3 Watching
    MiguelDAD
    With the MMM-Pages module, is there a way to turn pages whenever you want without touching the screen?
    Hasta Shakespere es inadecuado para describir tu perfección.
    A 1 Reply Last reply Dec 30, 2020, 1:48 PM Reply Quote 0
      ashishtank Module Developer @MiguelDAD
      @MiguelDAD You should be able to do it with remote control or telegram module. check the documentation of MMM-Pages. You need to send notification to it to change the page.
        MiguelDAD
        I have tried to follow the wiki of the modules but it has not worked for me.
                    module: 'MMM-Remote-Control',
                    // position: 'bottom_right',
                        apiKey: 'xxx',
                        customCommand: {
                            PAGE_INCREMENT: 'Pasar de página',
                            PAGE_DECREMENT: 'Retroceder de página'
                    module: 'MMM-TelegramBot',
                    position: 'top_center',
                        telegramAPIKey: 'xxx',
                        allowedUser: ['MiguelDAD'],
                        customCommands: [
                                getCommands: function (commander) {
                                    commander.add({
                                        command: 'PAGE_INCREMENT',
                                        callback: 'PasarPagina'
        A 1 Reply Last reply Dec 31, 2020, 2:02 PM Reply Quote 0
          A Former User
          read wiki of TB
            @MiguelDAD the telegram bot syntax looks incorrect. Check the wiki https://github.com/bugsounet/MMM-TelegramBot/wiki/Custom-Command as @Bugsounet suggested or try below (I have not tested it my self yet)
            customCommands: [
                command: "nextpage",
                description: "Show next page"
                callback: (command, handler, self) => {
                  self.sendNotification("PAGE_INCREMENT")
                  handler.reply("TEXT", "Okay... next page will be shown!")
            you can then use /nextpage command in telegram to change the page
            M 1 Reply Last reply Jan 12, 2021, 10:58 PM Reply Quote 0
              MiguelDAD @ashishtank
              @ashishtank I’m very stupid I know but I try these two options and neither works for me:
                  telegramAPIKey : 'thisapkiokey',
              	allowedUser : ['MiguelDAD'], // This is NOT the username of bot.
              	customCommands: [
              			description: "Muestra la siguiente página"
              			  handler.reply("TEXT", "Okay... mostrando la siguiente página")
                  telegramAPIKey : 'thisisokey',
                customCommands: [
              A 1 Reply Last reply Jan 13, 2021, 4:41 PM Reply Quote 0
                A Former User
                try this: (you have miss a coma)
                    customCommands: [
                        description: "Muestra la siguiente página",
                result of /nexpage and /help
                Bugsounet Cédric, [13.01.21 00:04
                /help nextpage
                Dev MagicMirror, [13.01.21 00:04]
                [En réponse à Bugsounet Cédric]
                /nextpage
                Servi par MMM-TelegramBot
                Bugsounet Cédric, [13.01.21 00:04]
                /nextpage
                and Naturaly the notification will be sended: (verified with my personal debug module)
                [Notification][MMM-TelegramBot] PAGE_INCREMENT
                Note: don’t forget your adminChatId field
                M 1 Reply Last reply Jan 13, 2021, 9:02 PM Reply Quote 0
                  @MiguelDAD said in Can I rotate the pages (MMM-Pages) with MMM-TelegramBot or MMM-RemoteControl?:
                  >  config: {
                  >   } < ---------------------------------Comma is missing here
                  >   customCommands: [
                  @MiguelDAD Are you able to get it working after adding comma here as @Bugsounet have suggested ?
                    MiguelDAD @Guest
                    @Bugsounet said in Can I rotate the pages (MMM-Pages) with MMM-TelegramBot or MMM-RemoteControl?:
                    module: ‘MMM-TelegramBot’,
                    position: ‘top_center’,
                    telegramAPIKey : ‘thisapkiokey’,
                    allowedUser : [‘MiguelDAD’], // This is NOT the username of bot.
                    customCommands: [
                    command: “nextpage”,
                    description: “Muestra la siguiente página”,
                    self.sendNotification(“PAGE_INCREMENT”)
                    handler.reply(“TEXT”, “Okay… mostrando la siguiente página”)
                    Niceee, thanks so much <3
