    After update, nothing happens.
    64 Posts 3 Posters 33.9k Views 3 Watching
      ashishtank Module Developer @Richard238
      @Richard238 you need at least 3 reputation to post more often. It will be visible in your profile.
        Richard238 @sdetweil
        @sdetweil said in After update, nothing happens.:
        ~/install.log should say we upgraded node to 10.23 ish and npm to 6.14 ish
        [92mNode.js installation Done! version=v10.23.0
        0mInstalled npm version: V6.14.8
          @Richard238 no idea…
          so, now
          node --v
          npm --v
          pi@pi_mirror:~ $ node --v
          node: bad option: --v
          pi@pi_mirror:~ $ npm --v
          6.14.8
          pi@pi_mirror:~ $ node -v
          v10.23.0
          pi@pi_mirror:~ $
            sdetweil @Richard238
            @Richard238 ok, up to level
              Richard238
              MagicMirror installation finished successfully!
              added 330 packages from 282 contributors and audited 1149 packages in 152.782s
              16 packages are looking for funding
                run `npm fund` for details
              found 1 low severity vulnerability
                run `npm audit fix` to fix them, or `npm audit` for details
              pi@pi_mirror:~/MagicMirror__RL1 $ npm start
              > magicmirror@2.14.0-develop start /home/pi/MagicMirror__RL1
              /home/pi/MagicMirror__RL1/node_modules/electron/dist/electron: /lib/arm-linux-gnueabihf/libdbus-1.so.3: no version information available (required by /home/pi/MagicMirror__RL1/node_modules/electron/dist/electron)
                @Richard238 interesting. I have to go pick up grandson, be unable to research for a few hours. 3ish…
                  OK, thank you for your help this far.
                    @Richard238 try this
                    in the old mm folder
                    git pull origin develop
                    npm install --only=prod
                    npm start
                      Richard238
                      I just powered it off, and this time it’s booted to the default MM with US Holidays.
                      Does that help, what should I try next?
                        @Richard238 yes the new mm came up.
                          Should I stop that before doing this
                          "git pull origin develop / npm install --only=prod / npm start "
                          in the old MM?
                            @Richard238 yes pm2 stop all
                              Richard238
                              pi@pi_mirror:~ $ pm2 stop all
                              [PM2] Applying action stopProcessId on app [all](ids: 0)
                              [PM2] [mm](0) ✓
                              │ Name │ mode │ status  │ ↺ │ cpu │ memory │
                              │ mm   │ fork │ stopped │ 0 │ 0%  │ 0 B    │
                               Use `pm2 show <id|name>` to get more details about an app
                              pi@pi_mirror:~ $ cd ~/MagicMirror__RL1
                              pi@pi_mirror:~/MagicMirror__RL1 $ git pull origin develop
                              remote: Enumerating objects: 8, done.
                              remote: Counting objects: 100% (8/8), done.
                              remote: Compressing objects: 100% (8/8), done.
                              remote: Total 8 (delta 1), reused 0 (delta 0), pack-reused 0
                              Unpacking objects: 100% (8/8), done.
                              From https://github.com/MichMich/MagicMirror
                               * branch            develop    -> FETCH_HEAD
                                 a4ab0cb..da00c16  develop    -> origin/develop
                              Updating a4ab0cb..da00c16
                              Fast-forward
                               CHANGELOG.md | 1 +
                               js/module.js | 2 +-
                               2 files changed, 2 insertions(+), 1 deletion(-)
                              pi@pi_mirror:~/MagicMirror__RL1 $ npm install --only=prod
                              > magicmirror@2.14.0-develop install /home/pi/MagicMirror__RL1
                              " && cd vendor && npm install --loglevel=error
                              audited 24 packages in 1.991s
                              1 package is looking for funding
                              found 0 vulnerabilities
                              > magicmirror@2.14.0-develop postinstall /home/pi/MagicMirror__RL1
                              > npm run install-fonts && echo "MagicMirror installation finished successfully!
                              > magicmirror@2.14.0-develop install-fonts /home/pi/MagicMirror__RL1
                              > echo "Installing fonts ...
                              " && cd fonts && npm install --loglevel=error
                              audited 1 package in 1.03s
                              audited 1149 packages in 36.561s
                                @sdetweil the new install used the master branch, so on electron 6. the old folder is on develop, so electron 8.5
                                  @Richard238 ok. 1st time seeing this…
                                  just to make sure
                                  from the old folder
                                  grep version node_modules/electron/package.json
                                    Richard238
                                    pi@pi_mirror:~/MagicMirror__RL1 $ grep version node_modules/electron/package.json
                                    “type”: “version”,
                                    “version”: “8.5.3”
                                      @sdetweil one more diag command
                                      lsb_release -a
                                        Richard238
                                        pi@pi_mirror:~ $ lsb_release -a
                                        No LSB modules are available.
                                        Distributor ID: Raspbian
                                        Description: Raspbian GNU/Linux 8.0 (jessie)
                                        Release: 8.0
                                        Codename: jessie
                                        pi@pi_mirror:~ $
                                          @Richard238 ok, thx. problem is new electron won’t run on Jessie anymore…
                                          I don’t know if this will work.
                                          from. the old mm folder
                                          rm -rf node_modules/electron
                                          npm install electron@6.1.12
                                          then npm start
                                            Richard238
                                            Sam, you’re a genius!
                                            That’s fixed it.
                                            This will only happen again in the not too distant future I’m sure, so would I be better off installing a newer OS?
                                            And then how do I recreate my MM on said new OS?
                                            I’m going to logoff for now, thanks again for your help today.
                                            More tomorrow I’m sure.
                                            Kind regards,
                                            Richard.
                                            • 2 / 4
