    v2.14.0
    Scheduled Pinned Locked Moved MagicMirror
    1 Posts 1 Posters 1.9k Views 1 Watching
    • MichMichM Offline
      MichMich
      https://github.com/MichMich/MagicMirror/releases/tag/v2.14.0
      [2.14.0] - 2021-01-01
      Special thanks to the following contributors: @Alvinger, @AndyPoms, @ashishtank, @bluemanos, @flopp999, @jakemulley, @jakobsarwary1, @marvai-vgtu, @mirontoli, @rejas, @sdetweil, @Snille & @Sub028.
      ℹ️ Note: This update uses new dependencies. Please update using the following command: git pull && npm install.
      Added
      • Added new log level “debug” to the logger.
      • Added new parameter “useKmh” to weather module for displaying wind speed as kmh.
      • Chuvash translation.
      • Added Weatherbit as a provider to Weather module.
      • Added SMHI as a provider to Weather module.
      • Added Hindi & Gujarati translation.
      • Added optional support for DEGREE position in Feels like translation.
      • Added support for variables in nunjucks templates for translate filter.
      • Added Chuvash translation.
      • Calendar: new options “limitDays” and “coloredEvents”.
      • Added new option “limitDays” - limit the number of discreet days displayed.
      • Added new option “customEvents” - use custom symbol/color based on keyword in event title.
      • Added GitHub workflows for automated testing and changelog enforcement.
      Updated
      • Merging .gitignore in the config-folder with the .gitignore in the root-folder.
      • Weather module - forecast now show TODAY and TOMORROW instead of weekday, to make it easier to understand.
      • Update dependencies to latest versions.
      • Update dependencies eslint, feedme, simple-git and socket.io to latest versions.
      • Update lithuanian translation.
      • Update config sample.
      • Highlight required version mismatch.
      • No select Text for TouchScreen use.
      • Corrected logic for timeFormat “relative” and “absolute”.
      • Added missing function call in module.show()
      • Translator variables can have falsy values (e.g. empty string)
      • Fix issue with weather module with DEGREE label in FEELS like
      Deleted
      • Removed Travis CI intergration.
      Fixed
      • JSON Parse translation files with comments crashing UI. (#2149)
      • Calendar parsing where RRULE bug returns wrong date, add Windows timezone name support. (#2145, #2151)
      • Wrong node-ical version installed (package.json) requested version. (#2153)
      • Fix calendar fetcher subsequent timing. (#2160)
      • Rename Greek translation to correct ISO 639-1 alpha-2 code (gr > el). (#2155)
      • Add a space after icons of sunrise and sunset. (#2169)
      • Fix calendar when no DTEND record found in event, startDate overlay when endDate set. (#2177)
      • Fix windspeed convertion error in ukmetoffice weather provider. (#2189)
      • Fix console.debug not having timestamps. (#2199)
      • Fix calendar full day event east of UTC start time. (#2200)
      • Fix non-fullday recurring rule processing. (#2216)
      • Catch errors when parsing calendar data with ical. (#2022)
      • Fix Default Alert Module does not hide black overlay when alert is dismissed manually. (#2228)
      • Weather module - Always displays night icons when local is other then English. (#2221)
      • Update Node-ical 0.12.4 , fix invalid RRULE format in cal entries
      • Fix package.json for optional electron dependency (2378)
      • Update node-ical version again, 0.12.5, change RRULE fix (#2371, #2379)
      • Remove undefined objects from modules array (#2382)
      • Update node-ical version again, 0.12.7, change RRULE fix (#2371, #2379), node-ical now throws error (which we catch)
      • Update simple-git version to 2.31 unhandled promise rejection (#2383)
