    MMM-SoccerLiveScore - Club Logos doesen’t show
    14 Posts 3 Posters 2.9k Views 3 Watching
    • kusselinK Offline
      kusselin
      Hello everybody,
      I installed the soccer module and it always worked wonderfully. It works now, only the club logos are no longer displayed in the table and the results … What could be the reason? I haven’t changed anything on the module. Here is my previous unchanged config code
      module: 'MMM-SoccerLiveScore',
      position: 'top_center',
      header: 'Fussball',
      leagues: [35, 44, 491, 9],
      showNames: true,
      showLogos: true,
      displayTime: 45 * 1000,
      showTables: true,
      0m4r0 1 Reply Last reply Reply Quote 0
      • kusselinK Offline
        kusselin
        Hi Sam, have you an idea why the logos not shown. In paste the logos were shown but till one week the logos not shown :-(
        Parallel i make a issue in github
          sdetweil @kusselin
          @kusselin not really… pm2 logs --lines=100
          then open the developers window, ctrl-shift-i, select the console tab and scroll up… u can also filter by module,
          by putting a part of the module name in the filter field, like soccer
          • kusselinK Offline
            kusselin
            Ok thank you, but i know that that module is actually not supported… ithink so what i see in github
              sdetweil @kusselin
              @kusselin no idea… i don’t know most of the modules… just how to debug to get to the problem… not neccessarily a fix…
              • kusselinK Offline
                kusselin
                Ok… thanks… tomorrow i look in the developer console as you said…
                • 0m4r0 Offline
                  0m4r Module Developer @kusselin
                  @kusselin the api that are used to fetch the logos return an error.
                  That must be the reason. Also the web application from the APIs owner have the same problem (https://www.toralarm.de)
                  https://github.com/0m4r
                  • kusselinK Offline
                    kusselin
                    Hi 0m4r, i think you have this module too…right? Thanks for ther anwer. That say me that i have to wait or i musst go to another module like mmm-soccer right?
                    In the developer Console of chrome there is not comming an error about the module :-(
                    Initializing MagicMirror.
                    translator.js:137 Loading core translation file: translations/de.json
                    translator.js:162 Loading core translation fallback file: translations/en.json
                    loader.js:176 Load script: modules/MMM-Carousel//MMM-Carousel.js
                    module.js:517 Module registered: MMM-Carousel
                    loader.js:148 Bootstrapping module: MMM-Carousel
                    loader.js:153 Scripts loaded for: MMM-Carousel
                    loader.js:155 Styles loaded for: MMM-Carousel
                    loader.js:157 Translations loaded for: MMM-Carousel
                    loader.js:176 Load script: modules/default/alert//alert.js
                    module.js:517 Module registered: alert
                    loader.js:148 Bootstrapping module: alert
                    loader.js:176 Load script: modules/default/alert/notificationFx.js
                    loader.js:153 Scripts loaded for: alert
                    loader.js:195 Load stylesheet: modules/default/alert/notificationFx.css
                    loader.js:195 Load stylesheet: vendor/css/font-awesome.css
                    loader.js:155 Styles loaded for: alert
                    translator.js:108 alert - Load translation: translations/de.json
                    translator.js:110 alert - Load translation fallback: translations/en.json
                    loader.js:157 Translations loaded for: alert
                    loader.js:176 Load script: modules/default/updatenotification//updatenotification.js
                    module.js:517 Module registered: updatenotification
                    loader.js:148 Bootstrapping module: updatenotification
                    loader.js:153 Scripts loaded for: updatenotification
                    loader.js:155 Styles loaded for: updatenotification
                    loader.js:157 Translations loaded for: updatenotification
                    loader.js:176 Load script: modules/default/clock//clock.js
                    module.js:517 Module registered: clock
                    loader.js:148 Bootstrapping module: clock
                    loader.js:176 Load script: vendor/node_modules/moment/min/moment-with-locales.js
                    loader.js:176 Load script: vendor/node_modules/moment-timezone/builds/moment-timezone-with-data.js
                    loader.js:176 Load script: vendor/node_modules/suncalc/suncalc.js
                    loader.js:153 Scripts loaded for: clock
                    loader.js:195 Load stylesheet: modules/default/clock/clock_styles.css
                    loader.js:155 Styles loaded for: clock
                    loader.js:157 Translations loaded for: clock
                    loader.js:176 Load script: modules/default/calendar//calendar.js
                    module.js:509 Check MagicMirror version for module 'calendar' - Minimum version:  2.1.0 - Current version: 2.14.0
                    module.js:511 Version is ok!
                    module.js:517 Module registered: calendar
                    loader.js:148 Bootstrapping module: calendar
                    loader.js:236 File already loaded: moment.js
                    loader.js:153 Scripts loaded for: calendar
                    loader.js:195 Load stylesheet: modules/default/calendar/calendar.css
                    loader.js:236 File already loaded: font-awesome.css
                    loader.js:155 Styles loaded for: calendar
                    loader.js:157 Translations loaded for: calendar
                    loader.js:236 File already loaded: calendar.css
                    loader.js:176 Load script: modules/MMM-OpenmapWeather//MMM-OpenmapWeather.js
                    module.js:517 Module registered: MMM-OpenmapWeather
                    loader.js:148 Bootstrapping module: MMM-OpenmapWeather
                    loader.js:153 Scripts loaded for: MMM-OpenmapWeather
                    loader.js:195 Load stylesheet: vendor/node_modules/weathericons/css/weather-icons.css
                    loader.js:195 Load stylesheet: modules/MMM-OpenmapWeather/MMM-OpenmapWeather.css
                    loader.js:155 Styles loaded for: MMM-OpenmapWeather
                    loader.js:157 Translations loaded for: MMM-OpenmapWeather
                    loader.js:176 Load script: modules/default/weatherforecast//weatherforecast.js
                    module.js:517 Module registered: weatherforecast
                    loader.js:148 Bootstrapping module: weatherforecast
                    loader.js:153 Scripts loaded for: weatherforecast
                    loader.js:236 File already loaded: weather-icons.css
                    loader.js:195 Load stylesheet: modules/default/weatherforecast/weatherforecast.css
                    loader.js:155 Styles loaded for: weatherforecast
                    loader.js:157 Translations loaded for: weatherforecast
                    loader.js:176 Load script: modules/MMM-Remote-Control//MMM-Remote-Control.js
                    module.js:509 Check MagicMirror version for module 'MMM-Remote-Control' - Minimum version:  2.12.0 - Current version: 2.14.0
                    module.js:517 Module registered: MMM-Remote-Control
                    loader.js:148 Bootstrapping module: MMM-Remote-Control
                    loader.js:153 Scripts loaded for: MMM-Remote-Control
                    loader.js:195 Load stylesheet: modules/MMM-Remote-Control/remote-control.css
                    loader.js:155 Styles loaded for: MMM-Remote-Control
                    loader.js:157 Translations loaded for: MMM-Remote-Control
                    loader.js:176 Load script: modules/MMM-SoccerLiveScore//MMM-SoccerLiveScore.js
                    module.js:517 Module registered: MMM-SoccerLiveScore
                    loader.js:148 Bootstrapping module: MMM-SoccerLiveScore
                    loader.js:153 Scripts loaded for: MMM-SoccerLiveScore
                    loader.js:195 Load stylesheet: modules/MMM-SoccerLiveScore/MMM-SoccerLiveScore.css
                    loader.js:155 Styles loaded for: MMM-SoccerLiveScore
                    loader.js:157 Translations loaded for: MMM-SoccerLiveScore
                    loader.js:176 Load script: modules/MMM-Formula1//MMM-Formula1.js
                    module.js:517 Module registered: MMM-Formula1
                    loader.js:148 Bootstrapping module: MMM-Formula1
                    loader.js:153 Scripts loaded for: MMM-Formula1
                    loader.js:195 Load stylesheet: modules/MMM-Formula1/MMM-Formula1.css
                    loader.js:155 Styles loaded for: MMM-Formula1
                    translator.js:108 MMM-Formula1 - Load translation: translations/de.json
                    translator.js:110 MMM-Formula1 - Load translation fallback: translations/en.json
                    loader.js:157 Translations loaded for: MMM-Formula1
                    loader.js:176 Load script: modules/MMM-Tankerkoenig//MMM-Tankerkoenig.js
                    module.js:509 Check MagicMirror version for module 'MMM-Tankerkoenig' - Minimum version:  2.2.0 - Current version: 2.14.0
                    module.js:517 Module registered: MMM-Tankerkoenig
                    loader.js:148 Bootstrapping module: MMM-Tankerkoenig
                    loader.js:153 Scripts loaded for: MMM-Tankerkoenig
                    loader.js:195 Load stylesheet: modules/MMM-Tankerkoenig/MMM-Tankerkoenig.css
                    loader.js:155 Styles loaded for: MMM-Tankerkoenig
                    translator.js:108 MMM-Tankerkoenig - Load translation: i18n/de.json
                    translator.js:110 MMM-Tankerkoenig - Load translation fallback: i18n/en.json
                    loader.js:157 Translations loaded for: MMM-Tankerkoenig
                    loader.js:176 Load script: modules/MMM-SmartWebDisplay//MMM-SmartWebDisplay.js
                    MMM-SmartWebDisplay.js:1 Failed to load resource: the server responded with a status of 404 (Not Found)
                    loader.js:186 Error on loading script: modules/MMM-SmartWebDisplay//MMM-SmartWebDisplay.js
                    script.onerror @ loader.js:186
                    loader.js:176 Load script: modules/MMM-ioBroker//MMM-ioBroker.js
                    module.js:517 Module registered: MMM-ioBroker
                    loader.js:148 Bootstrapping module: MMM-ioBroker
                    loader.js:153 Scripts loaded for: MMM-ioBroker
                    loader.js:195 Load stylesheet: modules/MMM-ioBroker/MMM-ioBroker.css
                    loader.js:155 Styles loaded for: MMM-ioBroker
                    loader.js:157 Translations loaded for: MMM-ioBroker
                    loader.js:176 Load script: modules/MMM-Fuel//MMM-Fuel.js
                    module.js:517 Module registered: MMM-Fuel
                    loader.js:148 Bootstrapping module: MMM-Fuel
                    loader.js:153 Scripts loaded for: MMM-Fuel
                    loader.js:195 Load stylesheet: modules/MMM-Fuel/MMM-Fuel.css
                    loader.js:155 Styles loaded for: MMM-Fuel
                    translator.js:108 MMM-Fuel - Load translation: translations/de.json
                    translator.js:110 MMM-Fuel - Load translation fallback: translations/en.json
                    loader.js:157 Translations loaded for: MMM-Fuel
                    loader.js:176 Load script: modules/MMM-PublicTransportHafas//MMM-PublicTransportHafas.js
                    module.js:517 Module registered: MMM-PublicTransportHafas
                    loader.js:148 Bootstrapping module: MMM-PublicTransportHafas
                    loader.js:176 Load script: modules/MMM-PublicTransportHafas/core/PTHAFASDomBuilder.js
                    loader.js:176 Load script: modules/MMM-PublicTransportHafas/core/PTHAFASTableBodyBuilder.js
                    loader.js:153 Scripts loaded for: MMM-PublicTransportHafas
                    loader.js:195 Load stylesheet: modules/MMM-PublicTransportHafas/css/styles.css
                    loader.js:155 Styles loaded for: MMM-PublicTransportHafas
                    translator.js:108 MMM-PublicTransportHafas - Load translation: translations/de.json
                    translator.js:110 MMM-PublicTransportHafas - Load translation fallback: translations/en.json
                    loader.js:157 Translations loaded for: MMM-PublicTransportHafas
                    loader.js:176 Load script: modules/default/compliments//compliments.js
                    module.js:517 Module registered: compliments
                    loader.js:148 Bootstrapping module: compliments
                    loader.js:153 Scripts loaded for: compliments
                    loader.js:155 Styles loaded for: compliments
                    loader.js:157 Translations loaded for: compliments
                    loader.js:176 Load script: modules/MMM-Tools//MMM-Tools.js
                    module.js:517 Module registered: MMM-Tools
                    loader.js:148 Bootstrapping module: MMM-Tools
                    loader.js:176 Load script: modules/MMM-Tools/configMerge.min.js
                    configMerge.min.js:1 [@bugsounet] configMerge v1.0.0 Loaded !
                    loader.js:153 Scripts loaded for: MMM-Tools
                    loader.js:195 Load stylesheet: modules/MMM-Tools/MMM-Tools.css
                    loader.js:155 Styles loaded for: MMM-Tools
                    translator.js:108 MMM-Tools - Load translation: translations/de.json
                    translator.js:110 MMM-Tools - Load translation fallback: translations/en.json
                    loader.js:157 Translations loaded for: MMM-Tools
                    loader.js:176 Load script: modules/MMM-Traffic//MMM-Traffic.js
                    module.js:517 Module registered: MMM-Traffic
                    loader.js:148 Bootstrapping module: MMM-Traffic
                    loader.js:153 Scripts loaded for: MMM-Traffic
                    loader.js:195 Load stylesheet: modules/MMM-Traffic/traffic.css
                    loader.js:155 Styles loaded for: MMM-Traffic
                    loader.js:157 Translations loaded for: MMM-Traffic
                    loader.js:236 File already loaded: traffic.css
                    loader.js:176 Load script: modules/MMM-COVID19-AMPEL//MMM-COVID19-AMPEL.js
                    module.js:517 Module registered: MMM-COVID19-AMPEL
                    loader.js:148 Bootstrapping module: MMM-COVID19-AMPEL
                    loader.js:153 Scripts loaded for: MMM-COVID19-AMPEL
                    loader.js:195 Load stylesheet: modules/MMM-COVID19-AMPEL/MMM-COVID19-AMPEL.css
                    loader.js:155 Styles loaded for: MMM-COVID19-AMPEL
                    translator.js:108 MMM-COVID19-AMPEL - Load translation: translations/de.json
                    translator.js:110 MMM-COVID19-AMPEL - Load translation fallback: translations/en.json
                    loader.js:157 Translations loaded for: MMM-COVID19-AMPEL
                    loader.js:176 Load script: modules/default/newsfeed//newsfeed.js
                    module.js:517 Module registered: newsfeed
                    loader.js:148 Bootstrapping module: newsfeed
                    loader.js:153 Scripts loaded for: newsfeed
                    loader.js:155 Styles loaded for: newsfeed
                    loader.js:157 Translations loaded for: newsfeed
                    loader.js:195 Load stylesheet: css/custom.css
                    module.js:45 Starting module: MMM-Carousel
                    alert.js:165 Starting module: alert
                    updatenotification.js:19 Start updatenotification
                    clock.js:46 Starting module: clock
                    3calendar.js:85 Starting module: calendar
                    MMM-OpenmapWeather.js:117 Starting module: MMM-OpenmapWeather
                    weatherforecast.js:90 Starting module: weatherforecast
                    MMM-Remote-Control.js:23 Starting module: MMM-Remote-Control
                    MMM-Formula1.js:50 Starting module: MMM-Formula1
                    MMM-ioBroker.js:52 Starting module: MMM-ioBroker
                    MMM-Fuel.js:183 Starting module: MMM-Fuel
                    MMM-Fuel.js:186 Config option sortBy has no matching value in config option types! Falling back to first entry.
                    start @ MMM-Fuel.js:186
                    MMM-PublicTransportHafas.js:43 Starting module: MMM-PublicTransportHafas with identifier: module_16_MMM-PublicTransportHafas
                    compliments.js:38 Starting module: compliments
                    2MMM-Traffic.js:21 Starting module: MMM-Traffic
                    newsfeed.js:57 Starting module: newsfeed
                    main.js:505 All modules started!
                    MMM-Tools.js:156 MMM-Tools is suspended.
                    module.js:199 MMM-Remote-Control is suspended.
                    module.js:199 MMM-Formula1 is suspended.
                    module.js:199 MMM-Tankerkoenig is suspended.
                    module.js:199 MMM-ioBroker is suspended.
                    module.js:199 MMM-COVID19-AMPEL is suspended.
                    module.js:199 MMM-OpenmapWeather is suspended.
                    module.js:199 weatherforecast is suspended.
                    module.js:206 MMM-PublicTransportHafas is resumed.
                    api.openweathermap.org/data/2.5/forecast/daily?id=2847614&cnt=7&exclude=false&units=metric&lang=de&APPID=8a:1 Failed to load resource: the server responded with a status of 401 (Unauthorized)
                    weatherforecast.js:265 weatherforecast: Your AppID does not support long term forecasts. Switching to fallback endpoint.
                    weatherRequest.onreadystatechange @ weatherforecast.js:265
                    MMM-Formula1.js:66 MMM-Formula1 received a notification: DRIVER_STANDINGS
                    MMM-Traffic.js:126 received MMM_TRAFFIC_DURATION
                    calendar.js:147 Calendar Error. Could not fetch calendar: https://calendar.google.com/calendar/ical/kcb3j40group.calendar.google.com/
                    socketNotificationReceived @ calendar.js:147
                    MMM-Tools.js:161 MMM-Tools is resumed.
                    module.js:199 MMM-PublicTransportHafas is suspended.
                    module.js:206 MMM-Formula1 is resumed.
                    data:image/png;base64, undefined:1 GET data:image/png;base64, undefined net::ERR_INVALID_URL
                    Image (async)
                    getDom @ MMM-SoccerLiveScore.js:224
                    (anonymous) @ main.js:114
                    updateDom @ main.js:113
                    updateDom @ main.js:551
                    updateDom @ module.js:364
                    changeLeague @ MMM-SoccerLiveScore.js:63
                    (anonymous) @ MMM-SoccerLiveScore.js:65
                    setTimeout (async)
                    changeLeague @ MMM-SoccerLiveScore.js:64
                    (anonymous) @ MMM-SoccerLiveScore.js:76
                    setTimeout (async)
                    changeLeague @ MMM-SoccerLiveScore.js:75
                    setTimeout (async)
                    Image (async)
                    getDom @ MMM-SoccerLiveScore.js:153
                    (anonymous) @ MMM-SoccerLiveScore.js:275
                    setTimeout (async)
                    getDom @ MMM-SoccerLiveScore.js:274
                    setTimeout (async)
                    setTimeout (async)
                    setTimeout (async)
                    module.js:206 MMM-COVID19-AMPEL is resumed.
                    Image (async)
                    (anonymous) @ MMM-SoccerLiveScore.js:187
                    setTimeout (async)
                    getDom @ MMM-SoccerLiveScore.js:186
                    setTimeout (async)
                    setTimeout (async)
                    setTimeout (async)
                    setTimeout (async)
                    Image (async)
                    setTimeout (async)
                    setTimeout (async)
                    setTimeout (async)
                    setTimeout (async)
                    setTimeout (async)
                    setTimeout (async)
                    Image (async)
                    setTimeout (async)
                    setTimeout (async)
                    setTimeout (async)
                    setTimeout (async)
                    Image (async)
                    setTimeout (async)
                    setTimeout (async)
                    setTimeout (async)
                    setTimeout (async)
                    setTimeout (async)
                    setTimeout (async)
                    setTimeout (async)
                    module.js:206 MMM-Tankerkoenig is resumed.
                    Image (async)
                    setTimeout (async)
                    setTimeout (async)
                    setTimeout (async)
                    setTimeout (async)
                    setTimeout (async)
                    Image (async)
                    setTimeout (async)
                    setTimeout (async)
                    setTimeout (async)
                    setTimeout (async)
                    setTimeout (async)
                    setTimeout (async)
                    setTimeout (async)
                    setTimeout (async)
                    2MMM-Traffic.js:126 received MMM_TRAFFIC_DURATION
                    • kusselinK Offline
                      kusselin
                      can this only the developer reapair with the Club logos?
                      • 0m4r0 Offline
                        @kusselin no, the problem is with the 3rd party that provides the API to get the logos.
                        The developer of the module cannot do much about it.
                        • 0m4r0 Offline
                          the logos should now work again, see: https://www.toralarm.com/ergebnisse/deutschland/bundesliga (which is where they do come from)
                          • kusselinK Offline
                            kusselin
                            Ok thanks
                            • 0m4r0 Offline
                              I have forked the repo and fixed a few issues here (i.e. infinite API call when showTables:true). You can find it here: https://github.com/0m4r/MMM-SoccerLiveScore
                              • kusselinK Offline
                                kusselin
                                Thank you very much
