    MMM-SoccerLiveScore - Club Logos doesen’t show
    14 Posts 3 Posters 3.0k Views 3 Watching
      sdetweil @kusselin
      @kusselin not really… pm2 logs --lines=100
      then open the developers window, ctrl-shift-i, select the console tab and scroll up… u can also filter by module,
      by putting a part of the module name in the filter field, like soccer
      • kusselinK Offline
        kusselin
        Ok thank you, but i know that that module is actually not supported… ithink so what i see in github
          sdetweil @kusselin
          @kusselin no idea… i don’t know most of the modules… just how to debug to get to the problem… not neccessarily a fix…
          • kusselinK Offline
            kusselin
            Ok… thanks… tomorrow i look in the developer console as you said…
            • 0m4r0 Offline
              0m4r Module Developer @kusselin
              @kusselin the api that are used to fetch the logos return an error.
              That must be the reason. Also the web application from the APIs owner have the same problem (https://www.toralarm.de)
              https://github.com/0m4r
              • kusselinK Offline
                kusselin
                Hi 0m4r, i think you have this module too…right? Thanks for ther anwer. That say me that i have to wait or i musst go to another module like mmm-soccer right?
                In the developer Console of chrome there is not comming an error about the module :-(
                Initializing MagicMirror.
                translator.js:137 Loading core translation file: translations/de.json
                translator.js:162 Loading core translation fallback file: translations/en.json
                loader.js:176 Load script: modules/MMM-Carousel//MMM-Carousel.js
                module.js:517 Module registered: MMM-Carousel
                loader.js:148 Bootstrapping module: MMM-Carousel
                loader.js:153 Scripts loaded for: MMM-Carousel
                loader.js:155 Styles loaded for: MMM-Carousel
                loader.js:157 Translations loaded for: MMM-Carousel
                loader.js:176 Load script: modules/default/alert//alert.js
                module.js:517 Module registered: alert
                loader.js:148 Bootstrapping module: alert
                loader.js:176 Load script: modules/default/alert/notificationFx.js
                loader.js:153 Scripts loaded for: alert
                loader.js:195 Load stylesheet: modules/default/alert/notificationFx.css
                loader.js:195 Load stylesheet: vendor/css/font-awesome.css
                loader.js:155 Styles loaded for: alert
                translator.js:108 alert - Load translation: translations/de.json
                translator.js:110 alert - Load translation fallback: translations/en.json
                loader.js:157 Translations loaded for: alert
                loader.js:176 Load script: modules/default/updatenotification//updatenotification.js
                module.js:517 Module registered: updatenotification
                loader.js:148 Bootstrapping module: updatenotification
                loader.js:153 Scripts loaded for: updatenotification
                loader.js:155 Styles loaded for: updatenotification
                loader.js:157 Translations loaded for: updatenotification
                loader.js:176 Load script: modules/default/clock//clock.js
                module.js:517 Module registered: clock
                loader.js:148 Bootstrapping module: clock
                loader.js:176 Load script: vendor/node_modules/moment/min/moment-with-locales.js
                loader.js:176 Load script: vendor/node_modules/moment-timezone/builds/moment-timezone-with-data.js
                loader.js:176 Load script: vendor/node_modules/suncalc/suncalc.js
                loader.js:153 Scripts loaded for: clock
                loader.js:195 Load stylesheet: modules/default/clock/clock_styles.css
                loader.js:155 Styles loaded for: clock
                loader.js:157 Translations loaded for: clock
                loader.js:176 Load script: modules/default/calendar//calendar.js
                module.js:509 Check MagicMirror version for module 'calendar' - Minimum version:  2.1.0 - Current version: 2.14.0
                module.js:511 Version is ok!
                module.js:517 Module registered: calendar
                loader.js:148 Bootstrapping module: calendar
                loader.js:236 File already loaded: moment.js
                loader.js:153 Scripts loaded for: calendar
                loader.js:195 Load stylesheet: modules/default/calendar/calendar.css
                loader.js:236 File already loaded: font-awesome.css
                loader.js:155 Styles loaded for: calendar
                loader.js:157 Translations loaded for: calendar
                loader.js:236 File already loaded: calendar.css
                loader.js:176 Load script: modules/MMM-OpenmapWeather//MMM-OpenmapWeather.js
                module.js:517 Module registered: MMM-OpenmapWeather
                loader.js:148 Bootstrapping module: MMM-OpenmapWeather
                loader.js:153 Scripts loaded for: MMM-OpenmapWeather
                loader.js:195 Load stylesheet: vendor/node_modules/weathericons/css/weather-icons.css
                loader.js:195 Load stylesheet: modules/MMM-OpenmapWeather/MMM-OpenmapWeather.css
                loader.js:155 Styles loaded for: MMM-OpenmapWeather
                loader.js:157 Translations loaded for: MMM-OpenmapWeather
                loader.js:176 Load script: modules/default/weatherforecast//weatherforecast.js
                module.js:517 Module registered: weatherforecast
                loader.js:148 Bootstrapping module: weatherforecast
                loader.js:153 Scripts loaded for: weatherforecast
                loader.js:236 File already loaded: weather-icons.css
                loader.js:195 Load stylesheet: modules/default/weatherforecast/weatherforecast.css
                loader.js:155 Styles loaded for: weatherforecast
                loader.js:157 Translations loaded for: weatherforecast
                loader.js:176 Load script: modules/MMM-Remote-Control//MMM-Remote-Control.js
                module.js:509 Check MagicMirror version for module 'MMM-Remote-Control' - Minimum version:  2.12.0 - Current version: 2.14.0
                module.js:517 Module registered: MMM-Remote-Control
                loader.js:148 Bootstrapping module: MMM-Remote-Control
                loader.js:153 Scripts loaded for: MMM-Remote-Control
                loader.js:195 Load stylesheet: modules/MMM-Remote-Control/remote-control.css
                loader.js:155 Styles loaded for: MMM-Remote-Control
                loader.js:157 Translations loaded for: MMM-Remote-Control
                loader.js:176 Load script: modules/MMM-SoccerLiveScore//MMM-SoccerLiveScore.js
                module.js:517 Module registered: MMM-SoccerLiveScore
                loader.js:148 Bootstrapping module: MMM-SoccerLiveScore
                loader.js:153 Scripts loaded for: MMM-SoccerLiveScore
                loader.js:195 Load stylesheet: modules/MMM-SoccerLiveScore/MMM-SoccerLiveScore.css
                loader.js:155 Styles loaded for: MMM-SoccerLiveScore
                loader.js:157 Translations loaded for: MMM-SoccerLiveScore
                loader.js:176 Load script: modules/MMM-Formula1//MMM-Formula1.js
                module.js:517 Module registered: MMM-Formula1
                loader.js:148 Bootstrapping module: MMM-Formula1
                loader.js:153 Scripts loaded for: MMM-Formula1
                loader.js:195 Load stylesheet: modules/MMM-Formula1/MMM-Formula1.css
                loader.js:155 Styles loaded for: MMM-Formula1
                translator.js:108 MMM-Formula1 - Load translation: translations/de.json
                translator.js:110 MMM-Formula1 - Load translation fallback: translations/en.json
                loader.js:157 Translations loaded for: MMM-Formula1
                loader.js:176 Load script: modules/MMM-Tankerkoenig//MMM-Tankerkoenig.js
                module.js:509 Check MagicMirror version for module 'MMM-Tankerkoenig' - Minimum version:  2.2.0 - Current version: 2.14.0
                module.js:517 Module registered: MMM-Tankerkoenig
                loader.js:148 Bootstrapping module: MMM-Tankerkoenig
                loader.js:153 Scripts loaded for: MMM-Tankerkoenig
                loader.js:195 Load stylesheet: modules/MMM-Tankerkoenig/MMM-Tankerkoenig.css
                loader.js:155 Styles loaded for: MMM-Tankerkoenig
                translator.js:108 MMM-Tankerkoenig - Load translation: i18n/de.json
                translator.js:110 MMM-Tankerkoenig - Load translation fallback: i18n/en.json
                loader.js:157 Translations loaded for: MMM-Tankerkoenig
                loader.js:176 Load script: modules/MMM-SmartWebDisplay//MMM-SmartWebDisplay.js
                MMM-SmartWebDisplay.js:1 Failed to load resource: the server responded with a status of 404 (Not Found)
                loader.js:186 Error on loading script: modules/MMM-SmartWebDisplay//MMM-SmartWebDisplay.js
                script.onerror @ loader.js:186
                loader.js:176 Load script: modules/MMM-ioBroker//MMM-ioBroker.js
                module.js:517 Module registered: MMM-ioBroker
                loader.js:148 Bootstrapping module: MMM-ioBroker
                loader.js:153 Scripts loaded for: MMM-ioBroker
                loader.js:195 Load stylesheet: modules/MMM-ioBroker/MMM-ioBroker.css
                loader.js:155 Styles loaded for: MMM-ioBroker
                loader.js:157 Translations loaded for: MMM-ioBroker
                loader.js:176 Load script: modules/MMM-Fuel//MMM-Fuel.js
                module.js:517 Module registered: MMM-Fuel
                loader.js:148 Bootstrapping module: MMM-Fuel
                loader.js:153 Scripts loaded for: MMM-Fuel
                loader.js:195 Load stylesheet: modules/MMM-Fuel/MMM-Fuel.css
                loader.js:155 Styles loaded for: MMM-Fuel
                translator.js:108 MMM-Fuel - Load translation: translations/de.json
                translator.js:110 MMM-Fuel - Load translation fallback: translations/en.json
                loader.js:157 Translations loaded for: MMM-Fuel
                loader.js:176 Load script: modules/MMM-PublicTransportHafas//MMM-PublicTransportHafas.js
                module.js:517 Module registered: MMM-PublicTransportHafas
                loader.js:148 Bootstrapping module: MMM-PublicTransportHafas
                loader.js:176 Load script: modules/MMM-PublicTransportHafas/core/PTHAFASDomBuilder.js
                loader.js:176 Load script: modules/MMM-PublicTransportHafas/core/PTHAFASTableBodyBuilder.js
                loader.js:153 Scripts loaded for: MMM-PublicTransportHafas
                loader.js:195 Load stylesheet: modules/MMM-PublicTransportHafas/css/styles.css
                loader.js:155 Styles loaded for: MMM-PublicTransportHafas
                translator.js:108 MMM-PublicTransportHafas - Load translation: translations/de.json
                translator.js:110 MMM-PublicTransportHafas - Load translation fallback: translations/en.json
                loader.js:157 Translations loaded for: MMM-PublicTransportHafas
                loader.js:176 Load script: modules/default/compliments//compliments.js
                module.js:517 Module registered: compliments
                loader.js:148 Bootstrapping module: compliments
                loader.js:153 Scripts loaded for: compliments
                loader.js:155 Styles loaded for: compliments
                loader.js:157 Translations loaded for: compliments
                loader.js:176 Load script: modules/MMM-Tools//MMM-Tools.js
                module.js:517 Module registered: MMM-Tools
                loader.js:148 Bootstrapping module: MMM-Tools
                loader.js:176 Load script: modules/MMM-Tools/configMerge.min.js
                configMerge.min.js:1 [@bugsounet] configMerge v1.0.0 Loaded !
                loader.js:153 Scripts loaded for: MMM-Tools
                loader.js:195 Load stylesheet: modules/MMM-Tools/MMM-Tools.css
                loader.js:155 Styles loaded for: MMM-Tools
                translator.js:108 MMM-Tools - Load translation: translations/de.json
                translator.js:110 MMM-Tools - Load translation fallback: translations/en.json
                loader.js:157 Translations loaded for: MMM-Tools
                loader.js:176 Load script: modules/MMM-Traffic//MMM-Traffic.js
                module.js:517 Module registered: MMM-Traffic
                loader.js:148 Bootstrapping module: MMM-Traffic
                loader.js:153 Scripts loaded for: MMM-Traffic
                loader.js:195 Load stylesheet: modules/MMM-Traffic/traffic.css
                loader.js:155 Styles loaded for: MMM-Traffic
                loader.js:157 Translations loaded for: MMM-Traffic
                loader.js:236 File already loaded: traffic.css
                loader.js:176 Load script: modules/MMM-COVID19-AMPEL//MMM-COVID19-AMPEL.js
                module.js:517 Module registered: MMM-COVID19-AMPEL
                loader.js:148 Bootstrapping module: MMM-COVID19-AMPEL
                loader.js:153 Scripts loaded for: MMM-COVID19-AMPEL
                loader.js:195 Load stylesheet: modules/MMM-COVID19-AMPEL/MMM-COVID19-AMPEL.css
                loader.js:155 Styles loaded for: MMM-COVID19-AMPEL
                translator.js:108 MMM-COVID19-AMPEL - Load translation: translations/de.json
                translator.js:110 MMM-COVID19-AMPEL - Load translation fallback: translations/en.json
                loader.js:157 Translations loaded for: MMM-COVID19-AMPEL
                loader.js:176 Load script: modules/default/newsfeed//newsfeed.js
                module.js:517 Module registered: newsfeed
                loader.js:148 Bootstrapping module: newsfeed
                loader.js:153 Scripts loaded for: newsfeed
                loader.js:155 Styles loaded for: newsfeed
                loader.js:157 Translations loaded for: newsfeed
                loader.js:195 Load stylesheet: css/custom.css
                module.js:45 Starting module: MMM-Carousel
                alert.js:165 Starting module: alert
                updatenotification.js:19 Start updatenotification
                clock.js:46 Starting module: clock
                3calendar.js:85 Starting module: calendar
                MMM-OpenmapWeather.js:117 Starting module: MMM-OpenmapWeather
                weatherforecast.js:90 Starting module: weatherforecast
                MMM-Remote-Control.js:23 Starting module: MMM-Remote-Control
                MMM-Formula1.js:50 Starting module: MMM-Formula1
                MMM-ioBroker.js:52 Starting module: MMM-ioBroker
                MMM-Fuel.js:183 Starting module: MMM-Fuel
                MMM-Fuel.js:186 Config option sortBy has no matching value in config option types! Falling back to first entry.
                start @ MMM-Fuel.js:186
                MMM-PublicTransportHafas.js:43 Starting module: MMM-PublicTransportHafas with identifier: module_16_MMM-PublicTransportHafas
                compliments.js:38 Starting module: compliments
                2MMM-Traffic.js:21 Starting module: MMM-Traffic
                newsfeed.js:57 Starting module: newsfeed
                main.js:505 All modules started!
                MMM-Tools.js:156 MMM-Tools is suspended.
                module.js:199 MMM-Remote-Control is suspended.
                module.js:199 MMM-Formula1 is suspended.
                module.js:199 MMM-Tankerkoenig is suspended.
                module.js:199 MMM-ioBroker is suspended.
                module.js:199 MMM-COVID19-AMPEL is suspended.
                module.js:199 MMM-OpenmapWeather is suspended.
                module.js:199 weatherforecast is suspended.
                module.js:206 MMM-PublicTransportHafas is resumed.
                api.openweathermap.org/data/2.5/forecast/daily?id=2847614&cnt=7&exclude=false&units=metric&lang=de&APPID=8a:1 Failed to load resource: the server responded with a status of 401 (Unauthorized)
                weatherforecast.js:265 weatherforecast: Your AppID does not support long term forecasts. Switching to fallback endpoint.
                weatherRequest.onreadystatechange @ weatherforecast.js:265
                MMM-Formula1.js:66 MMM-Formula1 received a notification: DRIVER_STANDINGS
                MMM-Traffic.js:126 received MMM_TRAFFIC_DURATION
                calendar.js:147 Calendar Error. Could not fetch calendar: https://calendar.google.com/calendar/ical/kcb3j40group.calendar.google.com/
                socketNotificationReceived @ calendar.js:147
                MMM-Tools.js:161 MMM-Tools is resumed.
                module.js:199 MMM-PublicTransportHafas is suspended.
                module.js:206 MMM-Formula1 is resumed.
                data:image/png;base64, undefined:1 GET data:image/png;base64, undefined net::ERR_INVALID_URL
                Image (async)
                getDom @ MMM-SoccerLiveScore.js:224
                (anonymous) @ main.js:114
                updateDom @ main.js:113
                updateDom @ main.js:551
                updateDom @ module.js:364
                changeLeague @ MMM-SoccerLiveScore.js:63
                (anonymous) @ MMM-SoccerLiveScore.js:65
                setTimeout (async)
                changeLeague @ MMM-SoccerLiveScore.js:64
                (anonymous) @ MMM-SoccerLiveScore.js:76
                setTimeout (async)
                changeLeague @ MMM-SoccerLiveScore.js:75
                setTimeout (async)
                Image (async)
                getDom @ MMM-SoccerLiveScore.js:153
                (anonymous) @ MMM-SoccerLiveScore.js:275
                setTimeout (async)
                getDom @ MMM-SoccerLiveScore.js:274
                setTimeout (async)
                setTimeout (async)
                setTimeout (async)
                module.js:206 MMM-COVID19-AMPEL is resumed.
                Image (async)
                (anonymous) @ MMM-SoccerLiveScore.js:187
                setTimeout (async)
                getDom @ MMM-SoccerLiveScore.js:186
                setTimeout (async)
                setTimeout (async)
                setTimeout (async)
                setTimeout (async)
                Image (async)
                setTimeout (async)
                setTimeout (async)
                setTimeout (async)
                setTimeout (async)
                setTimeout (async)
                setTimeout (async)
                Image (async)
                setTimeout (async)
                setTimeout (async)
                setTimeout (async)
                setTimeout (async)
                Image (async)
                setTimeout (async)
                setTimeout (async)
                setTimeout (async)
                setTimeout (async)
                setTimeout (async)
                setTimeout (async)
                setTimeout (async)
                module.js:206 MMM-Tankerkoenig is resumed.
                Image (async)
                setTimeout (async)
                setTimeout (async)
                setTimeout (async)
                setTimeout (async)
                setTimeout (async)
                Image (async)
                setTimeout (async)
                setTimeout (async)
                setTimeout (async)
                setTimeout (async)
                setTimeout (async)
                setTimeout (async)
                setTimeout (async)
                setTimeout (async)
                2MMM-Traffic.js:126 received MMM_TRAFFIC_DURATION
                • kusselinK Offline
                  kusselin
                  can this only the developer reapair with the Club logos?
                  0m4r0 1 Reply Last reply Reply Quote 0
                  • 0m4r0 Offline
                    @kusselin no, the problem is with the 3rd party that provides the API to get the logos.
                    The developer of the module cannot do much about it.
                    • 0m4r0 Offline
                      the logos should now work again, see: https://www.toralarm.com/ergebnisse/deutschland/bundesliga (which is where they do come from)
                      • kusselinK Offline
                        kusselin
                        Ok thanks
                        • 0m4r0 Offline
                          I have forked the repo and fixed a few issues here (i.e. infinite API call when showTables:true). You can find it here: https://github.com/0m4r/MMM-SoccerLiveScore
                          • kusselinK Offline
                            kusselin
                            Thank you very much
