    Extend table / insert TD - please help
    10 Posts 5 Posters 1.5k Views 5 Watching
      c1olli
      Hi Stefan,
      I have also since 1 Month the Fronius Inverter and installed the MMM-Fronius, but the text is bad to read. So I like to install your code, but I have no permission to open or download it.
      Can you help me?
      Greetings
      c1olli
        ashishtank Module Developer @Cetax
        @Cetax Your pastebin is private so others can not access the code. you want to have your data as below ?
          c1olli
          Is it possible to tell me how it works with the table?
          In that case on the original code.
            ashishtank Module Developer @c1olli
            @c1olli Not sure what exactly you are asking.
              c1olli
              How to get the MMM-Fronius results in a table?
              It would be nicer with the code from @Cetax but at the moment it would be ok for me when I know what I have to change to get the result in a nicer form.
                sdetweil @c1olli
                @c1olli the author did not create columns (td) on the row… (tr)
                table
                  th (header row with column labels
                     td, td, td, td (for each column)
                repeat below for each row
                  tr
                     td, td, td, td (data for each column)
                he just appended the strings together for the one value on each row
                  A Former User @sdetweil
                  Why not using div and flex?
                    sdetweil @Guest
                    @Bugsounet I wasn’t proposing anything… I was answering the question
                    that is how a table looks and the author didn’t use it right…
                    div and flex is a lot more work, but u get a lot of flexibility
                      @sdetweil dix and flex is for lazy man like me mouahah
