    Tado module?
    35 Posts 5 Posters 33.9k Views 5 Watching
    • K
      krisalexroberts @strawberry 3.141
      @strawberry-3.141 I’ll be getting radiator thermostats in the next few weeks but no cooling
        dinkybluebug245 @charliwest
        @charliwest This didnt work for me…
        I got this error:
        tado.sh: line 5: unexpected EOF while looking for matching `"’
        tado.sh: line 12: syntax error: unexpected end of file
        the contents of tado.sh, is:
        USERNAME=xxx
        PASSWORD=xxxx
        curl --silent “https://my.tado.com/mobile/1.9/getCurrentState?username=“$USERNAME”&password=“$PASSWORD”” > temp
        insideTemp=$(grep -o “insideTemp." temp| awk ‘{print substr($1,13,4)}’)
        setPointTemp=$(grep -o "setPointTemp.” temp| awk ‘{print substr($1,15,4)}’)
        heatingOn=$(if grep -q ““heatingOn”:true” temp; then
        echo '\xf0\x9f\x94\xa5’
        else
        echo '\xf0\x9f\x9a\xab’
        fi)
        echo “$insideTemp” / “$setPointTemp” / “$heatingOn”
          charliwest
          @dinkybluebug245 probably a cut and paste error with the ticks, try from here https://github.com/charliwest/random_scripts/blob/master/tado2
          D 1 Reply Last reply
            @charliwest Thanks for the response, I get a different error now,
            grep: temp: No such file or directory
            tado.sh: command substitution: line 16: syntax error near unexpected token fi' 'ado.sh: command substitution: line 16: fi)
            C 1 Reply Last reply
              charliwest @dinkybluebug245
              @dinkybluebug245 there shouldn’t be a line 16, can you double check the file u made is correct. Where are you running the script from? Also it says something about ado.sh … not sure what that’s referring to?
                @charliwest Yes you’re right… file wasnt created correctly.
                output now is
                20.5 / 10," / \xf0\x9f\x9a\xab
                seems to work, but your comment on how the pi would deal with hex values was right, and because the second value only has two digits (10) Im assuming this is why its picking up the characters ,"
                  charliwest
                  So here is the first attempt https://github.com/olipayne/MMM-Tado-ThermoStats
                  Works pretty well but still need some work
                    @charliwest this looks awesome. What variable is the tado home number?
                      @dinkybluebug245 I’ll write a readme for it tomorrow, but basically if you manually run my original tado.sh in each step you will get the answers. If you need more into it will be there when the readme is ready ;)
                        charliwest
                        OK, the readme is there now, hope it makes sense.
                        https://github.com/olipayne/MMM-Tado-ThermoStats/tree/master
                        Its by no means perfect, and still want to try and automated the homeid if I can, and add an icon for on or off but have yet to work out which result that actually is ;)
                        D 2 Replies Last reply
                          @charliwest great job. Works well. Thanks.
                          Once you’ve got the icons working for heating on etc, it would be great it there was a house icon at the beginning - I suppose it makes it obvious then it’s the temperature of inside your home.
                          Love it.
                            @charliwest also, just noticed that when Tado is off, the module doesn’t update at all. Just stays the same as the last recorded reading. If the module is restarted and Tadl is off, the is just says ‘loading’
                              charliwest
                              off as in not heating or as in powered off?
                                @charliwest off as in set heating to
                                Manually off. (Ignore current and target temperature)
                                Current output on api is
                                {“tadoMode”:“HOME”,“geolocationOverride”:false,“geolocationOverrideDisableTime”:null,“preparation”:null,“setting”:{“type”:“HEATING”,“power”:“OFF”,“temperature”:null},“overlayType”:“MANUAL”,“overlay”
                                  charliwest
                                  OK I see the problem
                                  vs
                                  “type”:“HEATING”,“power”:“ON”,“temperature”:{“celsius”:22,“fahrenheit”:71.6}
                                  So it tries to read celsius but its not there. Will look into how to fix that, while we also change celsius to be a variable for metric or imperial as well.
                                    @charliwest hi. Also I noticed that sometimes it doesn’t update. This morning woke up and it was still showing a reading from about 8pm the night before. Not an isolated occasion as it happened before but figured it was a one off. Might be my setup though.
                                      charliwest
                                      hmm, ok, we did some updates today. Should deal with the NULL, C or F now. It also now gets the homeid for you, and the zone is assumed to be 1.
                                      Neither of us have actually yet to set up a MagicMirror, looking for glass and a monitor now to do a couple so don’t have this running apart from when we work on it at the moment.
                                      The update frequency was also changed, so far I assume the api doesnt have a limit on calls, but we only call it every 5mins
                                        @charliwest Hi. I’ve updated everything. Home icon looks great. Just tested it and It still doesn’t know how to handle when my heating is Manually off. The module just reports as ‘Loading’
                                          @charliwest when I first set up my mirror I didn’t have a monitor either for the first month. I think I just left it running without a
                                          Monitor connected and then used another pc on the same network to see output using ipaddressofpi:8080
                                            dinkybluebug245
                                            @charliwest Sorry to bombard you with messages - One other update - I noticed that if I restart MagicMirror and heating is munually off - then module just reports at ‘Loading.’ If I turn the heating off when Mirror is running, then the whole thing crashes - clock stops everything
                                            This just might be my system though. It was working before - very odd
