    MMM-bergfex not working
    mmm-bergfexbergfexsnow
    38 Posts 5 Posters 18.3k Views 5 Watching
      MajorC Project Sponsor @FatTony123
      @FatTony123 can you explain how to use the fork? I am a total noob.
      • F Offline
        FatTony123 @MajorC
        @MajorC Same approach as with other modules.
        Get the repository via
        git clone https://github.com/FatTony123/MMM-bergfex.git
        and then run
        npm install cheerio
        then
        npm install
        That installs all relevant software. After that you need to setup your config file accordingly.
        I’m not that active here, so you can reach me via github too …
          sdetweil @FatTony123
          @FatTony123 u shouldn’t have to do the separate install of cheerio as it is in the package.json
          • F Offline
            FatTony123 @sdetweil
            @sdetweil Thanks for the hint! (still not that familiar with npm ;-))
            Updated the install instructions and package.json file accordingly.
              @FatTony123 said in MMM-bergfex not working:
              Hi all,
              I’ve created a fork and did some updates to the code and config.
              You can now select the country where bergfex should choose the values from.
              Feel free to test and let me know any feedback.
              So far I can show multiple countries and their values…
              Works like a charm. Thank you very much!
              • F Offline
                FatTony123
                Great to hear, thanks!
                Let me know if you have any question, comments or ideas for improvements…
                Cheers!
                  I never saw values for “neu” maybe they are not provided by the city. Perhaps this would be nice to have this optional to save some unused space.
                  And I will play around with the CSS at the weekend. I would like to have some more space between each column.
                  • F Offline
                    FatTony123 @MajorC
                    @MajorC said in MMM-bergfex not working:
                    Any particular values you are missing / not seeing? The values should get updated once they are updated on bergfex.
                    Which cities / config are you using? Then I can check on my mirror…
                      @FatTony123 my mistake. It looks like the cities I have in my configurations are not reporting “new snow” (Neu") to bergfex. So I never saw something where. I just added another city and it works quite nice.
                      As I am not interested in “new snow”, it would be nice to be able to activate/deactivate all (Tal, Berg, Neu, Lifte) as an option in the config. But I can do that by myself in the source code.
                      • F Offline
                        FatTony123 @MajorC
                        @MajorC Sounds like a good idea to set the options that should be visible on the mirror. Let me know once you have something so I can play with it too ;-)
                          I played a little bit around with coustom.css and at the moment it looks nice to me with:
                           * MMM-bergfex
                          .MMM-bergfex td {
                          	padding-right: 20px;
                          • F Offline
                            FatTony123 @MajorC
                            @majorc Thank you, I’ve added that and updated the repo.
                              @fattony123
                              I added a second element, so it looks nice, even if there is now data available e.g. “new snow”.
                              .MMM-bergfex td {
                              	min-width: 35px;
                              • F Offline
                                FatTony123 @MajorC
                                @majorc thanks, added!
                                • L Offline
                                  lxne Project Sponsor @FatTony123
                                  @FatTony123 Hi, your fork is gone from git. Has anybody a working bergfex module? Mine isn’t showing any values anymore.
                                  Log says: [12.12.2022 16:52.17.247] [LOG] 230 snow reports from bergfex.at retrieved.
                                  Last season it worked.
                                  Anybody any idea?
                                  Oh boy. They changed the names of a view locations.
                                  After updating my list it works again.
                                  F 1 Reply Last reply Reply Quote 1
                                  • F Offline
                                    FatTony123 @lxne
                                    @lxne Glad to hear that it’s working again.
                                    Out of curiosity, which locations are you using?
                                    I’ve moved my repositories to gitlab, you should find the latest version here:
                                    https://gitlab.com/FatTony404/MMM-bergfex
                                    As far as I recall I’ve updated the MagicMirror module list accordingly as well.
                                    Cheers!
                                    L M 2 Replies Last reply Reply Quote 0
                                    • L Offline
                                      @FatTony123 Thanks for your reply.
                                      Just three locations I am visiting more or less regularly:
                                      ‘Wildkogel-Arena / Neukirchen / Bramberg’,
                                      ‘Lech Zürs / Arlberg’,
                                      ‘Hochkössen / Unterberg’
                                      Now the names are all with slashes. Last year there were some minuses.
                                      Thank you for the link.
                                      Best wishes
                                        @FatTony123
                                        You moved to gitlab with MMM-bergfex. But in the readme is:
                                        clone https://github.com/FatTony404/MMM-bergfex.git
                                        Should this not be
                                        clone https://gitlab.com/FatTony404/MMM-bergfex.git
                                        Christian
