    Manual Installation Trouble
    12 Posts 3 Posters 4.1k Views 3 Watching
      brendan_c23
      Manual Installation Trouble Error
      S B 2 Replies Last reply
        sdetweil @brendan_c23
        @brendan_c23 use my install script
        see https://github.com/sdetweil/MagicMirror_scripts
        B 1 Reply Last reply
          brendan_c23 @brendan_c23
          @brendan_c23 I am attempting to install the latest Node.js version using the code provided on the manual installation page of this website. I copy and pasted each line one by one as directed. When I got to the “npm run start” line, I am hit with these lines:
          pi@raspberrypi:~/MagicMirror $ npm run start
          magicmirror@2.14.0 start /home/pi/MagicMirror
          /home/pi/MagicMirror/node_modules/electron/index.js:14
          throw new Error(‘Electron failed to install correctly, please delete node_modules/electron and try installing again’)
          Error: Electron failed to install correctly, please delete node_modules/electron and try installing again
          at getElectronPath (/home/pi/MagicMirror/node_modules/electron/index.js:14:11)
          at Object. (/home/pi/MagicMirror/node_modules/electron/index.js:18:18)
          at Object.Module._extensions…js (internal/modules/cjs/loader.js:789:10)
          at Module.require (internal/modules/cjs/loader.js:692:17)
          at require (internal/modules/cjs/helpers.js:25:18)
          at Object. (/home/pi/MagicMirror/node_modules/electron/cli.js:3:16)
          npm ERR! code ELIFECYCLE
          npm ERR! errno 1
          npm ERR! magicmirror@2.14.0 start: DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js
          npm ERR! Exit status 1
          npm ERR!
          npm ERR! Failed at the magicmirror@2.14.0 start script.
          npm ERR! /home/pi/.npm/_logs/2021-01-16T20_10_19_289Z-debug.log
          I am not sure where to go from here. Any guidance/help would be greatly appreciated. I am using a 2Gb raspberry Pi 4. I have a very limited background in coding, but I notice it is telling me to delete the node_modules/electron and try installing again, any guidance on how to go about doing that would be appreciated.
          Thanks you guys
            @brendan_c23 use my script. delete the mm folder and run my script
            u are running the desktop version of pi os yes? u must
              brendan_c23 @sdetweil
              @sdetweil Do I need to clear all of the previous downloads/code or am I good to just copy + paste that line below everything?
                @brendan_c23 u need to delete the mm folder
                rm -rf ~/MagicMirror
                then use the one line for install
                  @sdetweil Delete MM folder? How do I do that
                  And I think so but not totally sure
                    @brendan_c23 I gave u the command
                      @sdetweil Thank you. Can you link me to PM2 installation
                        @brendan_c23 it’s part of the install, u will be prompted. also see rest of the scripts
                          brendan_c23
                          Thank you I hit Y, but how can I reverse it? I want to start installing modules but the mirror screen keeps running
                          A 1 Reply Last reply
                          • A
                            ashishtank Module Developer @brendan_c23
                            @brendan_c23 Below are pm2 commands help. If you want to stop the mirror then use pm2 stop 0 or pm2 stop MagicMirror
                            refer : https://pm2.keymetrics.io/docs/usage/quick-start/
