    Head first developing MM module for extreme beginners
    27 Posts 9 Posters 26.1k Views 12 Watching
      A Former User
      Today morning, I’ve got two messages from two members of this forum at the same time. Both of two asked me the same thing - “How can I show my contents on MM with my module?”
      So, here is a simple guide for developing MM module. This is not a royal road or perfect answer, but I hope this could be a help
      This article is not about using git or any other deeper knowledge. I assume you are familiar with javascript(nodeJS) at least.
      Make a workspace
      cd ~/MagicMirror/modules
      mkdir MMM-Test
      cd MMM-Test
      touch MMM-Test.js
      MMM-Test.js is your main module script. It will be called by MM core at running.
      Let’s make something.
      configuration
      First, add your module into MM framework. open ~/MagicMirror/config/config.js and add your module.
        module: "MMM-Test",
        config: {}
      For simple things, remove all other modules except your MMM-Test.
      MMM-Test.js
      open MMM-Test.js and edit.
      nano MMM-Test.js
      In that, copy this and paste into MMM-Test.js.
      Module.register("MMM-Timetable", {
        defaults: {},
        start: function () {},
        getDom: function() {},
        notificationReceived: function() {},
        socketNotificationReceived: function() {},
      There are many other things to study but currently, we will focus on these 5 things.
      getDom()
      This function will render your content on MM screen.
      Let’s do something.
        var element = document.createElement("div")
        element.className = "myContent"
        element.innerHTML = "Hello, World!"
        return element
      <div> element is created and returned to MM for rendering.
      When MM needs your module’s output being refreshed, this function will be called by MM core.
      See how it works.
      npm start dev
      defaults:{}
      You can use default configuration values. Let’s do it
      defaults: {
        foo: "I'm alive!"
        element.innerHTML = "Hello, World! " + this.config.foo
        return element
      your configuration value foo could be used like this.config.foo.
      this in this module, it directs module itself. you can access various module values with it.
      See how it works.
      And you can customize configuration values with config.js
      set your config.js like this;
        module: "MMM-Test",
          foo: "I'm the King of the world!"
      The result will be like this;
      start() & updateDom()
      This function will be executed when your module is loaded successfully.
      Let’s change something.
      start: function (){
        this.count = 0
        var timer = setInterval(()=>{
          this.updateDom()
          this.count++
        }, 1000)
        var subElement = document.createElement("p")
        subElement.innerHTML = "Count:" + this.count
        subElement.id = "COUNT"
        element.appendChild(subElement)
        return element
      After your module is loaded, your module’s output will be updated per every 1 second.
      Whenever you want to update your output, you can call .updateDom() to let MM also call your .getDom() to redraw the output. (Don’t try to call getDom() directly by yourself. It will not work as your expectation. Rendering is delegated to the MM core.)
      By the way, start() is not a good place to control drawing, because start() is called before your DOM objects are first rendered. Above code is somewhat bad behavior.
      notificationReceived()
      MM and modules are communicating each other with notification. Your module can receive notification and send it also.
      start: function (){
        this.count = 0
        return element
        switch(notification) {
          case "DOM_OBJECTS_CREATED":
              this.updateDom()
              this.count++
            }, 1000)
            break
      The result looks so same with previous codes. But your timer will be started after when “DOM_OBJECTS_CREATED” notification is received but not when the module is loaded.
      DOM_OBJECTS_CREATED notification is emitted when all of modules are loaded and rendered(with getDom()) first time. At the moment, you can manipulate your output in your module.
      Another way to control output
      Once your DOM is ready(after first calling getDom() and DOM_OBJECTS_CREATED notification is emitted), you can access your DOM with script.
              //this.updateDom()
              var countElm = document.getElementById("COUNT")
              countElm.innerHTML = "Count:" + this.count
              this.count++
            }, 1000)
            break
      Instead updateDom(), direct access to DOM is used.
      node_helper.js
      But your MMM-Test.js has some limitation. Because it is run on MM framework and Browser(Electron/Chromium or Midori)
      When you need more than what browser can provide, you should use node_helper.js
      By example, your MMM-Test.js cannot read or write local files by usual way (Of course, there is a hack, but that is not the point at this moment.).
      But your node_helper.js can. Or when you need to use other various node modules, node_helper.js exists for that purpose.
      Let’s make node_helper.js
      nano node_helper.js
      Copy this code and paste.
      var NodeHelper = require("node_helper")
        start: function() {},
      This is a default template of node_helper.js. Now add some codes.
        start: function() {
          this.countDown = 10000000
            case "DO_YOUR_JOB":
              this.sendSocketNotification("I_DID", (this.countDown - payload))
              break
      Like MMM-Test.js, start() will be executed when node_helper.js is loaded and connected to your module.
      Between MMM-Test.js and node_helper.js, socketNotification is used for communication. (similar with notification)
      You can get socketNotification with socketNotificationReceived() and can send it by sendSocketNotification().
      Then, you should modify MMM-Test.js
        return element
              this.sendSocketNotification("DO_YOUR_JOB", this.count)
              this.count++
            }, 1000)
            break
          case "I_DID":
            var elem = document.getElementById("COUNT")
            elem.innerHTML = "Count:" + payload
            break
      Result will be like this;
      Now you made your MMM-Test.js to work with node_helper.js
      Of course, this is not so good example to show what node_helper.js can do.
      But I believe you can understand how node_helper.js and MMM-Test.js work with each other.
      Well. You’ve learned 90% of how to develop MM module. the remains are described in https://github.com/MichMich/MagicMirror/blob/master/modules/README.md
      Good luck to you.
      1 Reply Last reply Reply Quote 7
        A Former User
        I cant get the text to appear when I run it, I made the Test.js file in the MagicMirror modules folder and copied in what was posted and put the config in the config.js file but when I run it the screens all black, here’s what happens when I try to run it
        pi@raspberrypi:~/MagicMirror/modules $ cd ~/MagicMirror
        pi@raspberrypi:~/MagicMirror $ npm start dev
        magicmirror@2.8.0 start /home/pi/MagicMirror
        sh run-start.sh “dev”
        Starting MagicMirror: v2.8.0
        Loading config …
        Loading module helpers …
        No helper found for module: MMM-Test.
        All module helpers loaded.
        Starting server on port 8080 …
        Server started …
        Sockets connected & modules started …
        Launching application.
        Shutting down server…
        any help would be greatly appreciated I dont see what I’m missing
          StuGrunt
          It is because there is an error (at least I think so - I am new too) and no instructions on where to put the function.
          1. change the Module.register(“MMM-Timetable”) to Module.register(“MMM-Test”)
          2. The article does not tell you where to put the getDom function when it is first introduced. Replace the getDom: function() {}. with the code shown. In other words, don’t just add it to the file. This article would have benefited from a final section that gave the entire code.
          I think the original author at least expected us to be very familiar with Node.js (fair enough), but alas, I am not so it took a bit of work to figure it out. :-)
          Here it is, for the first part:
          Module.register(“MMM-Test”, {
          defaults: {},
          var element = document.createElement(“div”)
          element.className = “myContent”
          element.innerHTML = “Hello, World!”
          return element
          _
          • N Offline
            nrayever
            Shame, code is really messed up. Not helpful to use it as a guide to start developing modules.
              sdetweil @nrayever
              @nrayever see my sample module,
              https://github.com/sdetweil/SampleModule
              and follow the module developers doc
              N 1 Reply Last reply Reply Quote 2
              • N Offline
                nrayever @sdetweil
                @sdetweil will try it. I don’t have JS experience that is why I have found it difficult to start.
                  sdetweil @nrayever
                  @nrayever sorry cant help develop module if u dont know programming and dont want to learn
                  N 1 Reply Last reply Reply Quote 1
                  • cowboysdudeC Offline
                    cowboysdude Module Developer @StuGrunt
                    @StuGrunt said in Head first developing MM module for extreme beginners:
                    defaults: {},
                    return element
                    _
                    Both of those functions go outside the getDom function pretty much anywhere you want to put them.
                    The socketNotificationReceived function [example below, can be used in either node_helper OR your main.js file. The example below is in my node_helper] :
                    		if (notification === 'CONFIG') {
                                this.config = payload;
                            if (notification === 'GET_CURRENT') {
                                this.getCurrent(payload);
                            if (notification === 'GET_FORECAST') {
                                if (this.forecast.timestamp === this.getDate() && this.forecast.data !== null) {
                                    this.sendSocketNotification('FORECAST_RESULT', this.forecast.data);
                                    console.log("Using data we already have");
                                } else {
                                    this.getForecast();
                    				console.log("Getting new data");
                    Here is the corresponding one in the main.js
                            if (notification === "CURRENT_RESULT") {
                                this.processCurrent(payload);
                            if (notification === "FORECAST_RESULT") {
                                this.processForecasts(payload);
                    		this.updateDom(this.config.initialLoadDelay);
                    You can use notificationReceived to receive info from other modules like this:
                    Here are examples of that:
                    notificationReceived: function (notification, payload){
                            if (notification === 'CURRENT_RESULT') {
                    this.sendNotification('CURRENT_RESULT', payload);
                    This is how I send and receive my ‘payload’ from one module to another.
                    The first example is getting my ‘CURRENT_RESULT’ [getting info for a Forecast module from the Current weather module] from the bottom example that is
                    sending out ‘CURRENT_RESULT’…
                    The bottom example will ‘broadcast’ and in reality ANY module can get the data it’s sending out.
                    Hope this helps. It’s a really simple process.
                      Schmaniel
                      How can I test the getDom() html output?
                      I don’t want to restart MM every time when I change something just to look if it worked.
                        sdetweil @Schmaniel
                        @Schmaniel ctrl-r to reload the screen
                        • N Offline
                          nrayever @sdetweil
                          @sdetweil … ok.
                            Dobi @nrayever
                            Hey guys,
                            I’m quite new in developing an own module. I was able to change exiting modules on my magic mirror but now I wanted to create my own module, but I’m not able to get socket communication between my “main” module an the “helper-function”
                            I uploaded my module here:
                            https://github.com/Dobherrmann/MMM_Testmodul.git
                            my Module looks like this on my magic mirror:
                            maybe someone can find my mistake(s).
                            BR
                              sdetweil @Dobi
                              @dobi two things
                              when the DomObject Created method is called, its POSSIBLE that the elements are not yet accessible… so your code fails as the document.getElementbyID returns null…
                              second, do you have a position: set in the module def in config.js?
                              third and MOST important
                              the module NAME must match the folder name AND the filename and the register in the file…
                              so, the filename is MMM-cookbook.js
                              therefore ALL the things must be called MMM-cookbook
                              git clone will name the folder the name of the github repo
                              (unless u add an extra part to git clone repo_url output_folder_name)
                              I fixed all those and the module displays the countdown/up each second
                                Dobi @sdetweil
                                @sdetweil ahh thank you for these information I will give it a try.
                                  Dobi
                                  @sdetweil I gave it a try but without differences :(
                                  I made a new git repo : https://github.com/Dobherrmann/MMM-cookbook.git
                                  Now there I should have the same name in the repo like my module.
                                  my config. js looks like this (I gave it a position):
                                        module: "MMM-cookbook",
                                        position: "middle_center",
                                          header: "My Cookbook",
                                  I started to debug “my code” a little bit and I found this when I want to send a socket notification:
                                  self.sendSocketNotification("DO_YOUR_JOB", this.count);
                                  					console.log("Notfication", this.sendSocketNotification("DO_YOUR_JOB", this.count))
                                  					this.subElementUp.innerHTML = "Count UP:" + this.count
                                  On my console i get the feedback that “this.sendSocketNotification(“DO_YOUR_JOB”, this.count” is undefined. It looks like that this function is unkown.
                                    sdetweil @Dobi
                                    @dobi u are inside a callback. change the ‘this’ to ‘self’ like the self.sendSocketNotification
                                    ‘this’ is always tricky. depends on the context, and some of the programming idioms used
                                    that’s why we typically see
                                    var self = this;
                                    at the beginning of functions that have callbacks or .then() used inside
                                      Dobi @sdetweil
                                      @sdetweil ok, but it dosen’t change something.
                                      notificationReceived: function (notification, payload, sender) {
                                      		self = this;
                                      		switch (notification) {
                                      				var timer = setInterval(() => {
                                      					//this.updateDom()
                                      					console.log(`self.sendSocketNotification("DO_YOUR_JOB", this.count)`, self.sendSocketNotification("DO_YOUR_JOB", this.count))
                                      					this.count++
                                      				}, 1000)
                                      				break
                                      Now i could post a picture of my console
                                        sdetweil @Dobi
                                        @dobi show the source code page. u had to fix both counters
                                        sources tab, modules, mmm-cookbook, mmm-cookbook.js
                                          sdetweil @Dobi
                                          @dobi
                                          but u didn’t change this.count to self.count
                                          in all the places
                                            Dobi @sdetweil
                                            @sdetweil I replaced all this. … calls to self. … but I don’t get a change. Is there a way that I can check to check that I can check that the function is loaded correctly from the kernal?
