    Change the way calendar presents day and time
    3 Posts 2 Posters 965 Views 2 Watching
      MM-Hans
      After a new installation something goes wrong with the standard calendar module that I use with Apple calendar. As you can see in the photo, there are two different ways to present the date, namely “Wednesday at 00:00” and “27-01-2021”. I would like each calendar note to be displayed as “dd-mm-yy” or “dd-mm”.
      Unfortunately, I cannot do that, not even by changing the dateFormat in the config.js file. Can someone tell me how to change this so all dates are presented the same way?
      • BKeyportB Offline
        BKeyport Module Developer
        If I’m remembering correct (I don’t use the module anymore), it’s having to do with absolute dates. All three of these need to be set…
        // Force Absolute to Absolute all the time, michmich *really* hates solid dates, apparently.
        timeformat: "absolute",
        getRelative: 0,
        urgency: 0 ,
          MM-Hans @BKeyport
          @BKeyport Thanks for your suggestion! I now use the code below which results in what is shown in the image. Exactly what I wanted :-)
                                          fade: false,
                                          maximumEntries: 7,
                                          displaySymbol: false,
             				timeFormat: 'absolute',
             				dateFormat: 'ddd D MMM',
            				fullDayEventDateFormat: 'dd DD-MM',
           				urgency: 0,
