    Magic Mirror wont start. :(
    11 Posts 6 Posters 10.5k Views 6 Watching
    • strawberry 3.141S Offline
      strawberry 3.141 Project Sponsor Module Developer @MQ4
      @MQ4 did you run npm install in the MagicMirror directory? Looks like your missing some dependencies there
        chrisyy @MQ4
        @MQ4
        Looks like ur missing the module ‘express’. Did u try
        $ npm install express
        to install it manually?
        • L Offline
          Leotrap
          I got the same problem… where can i find the express module? Thanks
          • L Offline
            Leotrap @chrisyy
            @chrisyy I got the same problem… where can i find the express module? Thanks
            reply
            • bheplerB Offline
              bhepler Module Developer @Leotrap
              @Leotrap You shouldn’t have to find it, you just need to run the installation command: npm install express
              Give it a go and let us know what happens. (be sure to do it from within the ~/MagicMirror folder).
              @chrisyy Perhaps designating commands using the markdown features would make 'em stand out.
                MQ4
                Ok. I figured it out!!! There was a few things I was doing wrong… I found this tutorial and it is EPIC!! https://forum.magicmirror.builders/topic/236/complete-setup-tutorial/3
                Hope it helps!!
