    module that displays a certain text from a website, the text on the website is updated daily
    36 Posts 6 Posters 15.3k Views 7 Watching
      Amoniak
      I think I’ve found a similar module (MMM-PoemOfTheDay), but I don’t know how to adapt it to my needs, can someone help me?
        ashishtank Module Developer @Amoniak
        @Amoniak MMM-PoemOfTheDay is perfect to adapt for your need. Instead of poem site you need to get data from WatchTower site and parse the html response to extract the text.
          Amoniak @ashishtank
          @ashishtank said in module that displays a certain text from a website, the text on the website is updated daily:
          wow, thank you very much for your feedback, I’ll try to see if I can do it.
            Amoniak
            @ashishtank ok, I have installed the module, but it only shows me a black screen
              @Amoniak any error in dev console or PM2/terminal ?
                Amoniak @ashishtank
                @ashishtank i got it now, i will now try to parse the html response to extract the text, any good tips?
                A E 2 Replies Last reply Reply Quote 0
                  @Amoniak yes, I checked the response from watch tower in postman and they give data of last 2-3 days or may be from Sunday to this day, so you will need to select the right node. You can use class tabContent as identifier and today’s date for selection of the node. Also check which html parse is good enough, as HTML is very complex to parse you may want to choose right parser which gives speed and is lightweight. i.e. node-html-parser
                  2021-01-20-18-33-58-Clipboard
                  Other thing you can do is once you have parsed text data from watch tower, you can assign it to poem’s format (title, content and name) and it will just work. later on you can change the UI and text property names if you want.
                    sdetweil @ashishtank
                    @ashishtank cheerio lib will parse html to json
                      Amoniak
                      well, I’ll get started then. Keep your fingers crossed.
                        Amoniak
                        i installed cheerio, but i don’t know how to use it.
                        do I have to put this now in my “MMM-PoemOfTheDay.js” ?
                          sdetweil @Amoniak
                          @Amoniak gotta go read the library usage
                          • L Offline
                            lolo
                            It gonna be harder than u think as your text is changing daily. Just follow the the pattern.
                            Every day this is changed( https://wol.jw.org/hr/wol/h/r19/lp-c).
                            new day new text.
                            Text is in :
                            div id=“dailyText”
                            but if you ignore reference in text as (Mat. 16:24, 25; Ivan 15:20) located in a class it’s gonna be more easier.
                            And with cheerio u can complete this.
                              Amoniak
                              so, this is what my NodeHelper.js looks like. like i thought, the screen is black.
                              const axios = require("axios");
                              const DetectLanguage = require("detectlanguage");
                                      socketNotificationReceived: async function(noti, payload) {
                                              if (noti === "START") {
                                                      if (payload.updateInterval < 120000) {
                                                              payload.updateInterval = 120000;
                                                      const self = this;
                                                      (async function displayWatchtower () {
                                                              const poem = await getWatchtower(payload);
                                                              self.sendSocketNotification("UPDATE", poem);
                                                              setTimeout(displayPoem, payload.updateInterval);
                              const cheerio = require("cheerio");
                              const axios = require("axios").default;
                              const fethHtml = async url => {
                                try {
                                  const { data } = await axios.get(url);
                                  return data;
                                } catch {
                                  console.error(`ERROR: An error occurred while trying to fetch the URL: ${url}`);
                              const extracWatchtower = selector => {
                                const theme = selector
                                  .find(".tabContent active")
                                  .find("[class='themeScrp'] > [class='b'])
                                  .text()
                                  .trim();
                               const text = selector
                                  .find(".bodyTxt")
                                  .find("[class='section']")
                                  .text()
                                  .trim();
                               return { theme,
                                        text
                              const scrapWatchtower = async () => {
                                const watchtowerUrl =
                                  "https://wol.jw.org/hr/wol/h/r19/lp-c";
                                const html = await fethHtml(watchtowerUrl);
                                const selector = cheerio.load(html);
                                const searchResults = selector("body")
                                    .find("#dailyText"
                                const deals = searchResults.map((idx, el) => {
                                    const elementSelector = selector(el);
                                    return extractDeal(elementSelector)
                                  .get();
                                return Watchtower;
                                @Amoniak there are lots of missing pieces… add console.log with some message in each function and see how the flow works.
                                • L Offline
                                  lolo
                                  Try to do something with this code. It will retrieve data from current day. Modifying that node_helper is not great idea.
                                      const url=  'https://wol.jw.org/hr/wol/h/r19/lp-c';
                                      request({
                                          url: url,
                                          method: 'GET'
                                          }, (error, response, body) => {
                                              if (error) {
                                                  return console.error(error)
                                              var $ = cheerio.load(body);
                                              //console.log($.html());
                                              const data =  $('div[class="tabContent"]').first();
                                              let header = $(data).find('h2').text();
                                              let title = $(data).find('p').first().text();
                                              let text = $(data).find('div.pGroup>p').text();
                                              //console.log(header,title,text);
                                              var recivedData={
                                                  header,
                                                  title,
                                                  text
                                              //console.log(recivedData);
                                  • F Offline
                                    fordi
                                    I bet you could use the same technique to see if any playstation 5 are in stock on websites?
                                      Amoniak @lolo
                                      @lolo thank you for the code.
                                      I used the “MagicMirror-Module-Template” to create a new file and the associated folder.
                                      this is my js:
                                      Module.register(“dnevni_citat”, {
                                      defaults: {
                                      updateInterval: 60000,
                                      retryDelay: 5000
                                          requiresVersion: "2.1.0", // Required version of MagicMirror
                                          start: function() {
                                                  var self = this;
                                                  var dataRequest = null;
                                                  var dataNotification = null;
                                                  //Flag for check if module is loaded
                                                  this.loaded = false;
                                                  // Schedule update timer.
                                                  this.getData();
                                                  setInterval(function() {
                                                          self.updateDom();
                                                  }, this.config.updateInterval);
                                      request({
                                          url: url,
                                          method: 'GET'
                                              if (error) {
                                              var recivedData={
                                                  header,
                                                  title,
                                                  text
                                      what am I doing wrong?
                                      • L Offline
                                        lolo
                                        This should be your node_helper.
                                        const NodeHelper = require("node_helper");
                                        const request = require('request');
                                            start: function () {
                                                self = this;
                                                console.log("Starting node_helper for: " + this.name);
                                            getData: function () {
                                                const url = 'https://wol.jw.org/hr/wol/h/r19/lp-c';
                                                request({
                                                    url: url,
                                                    method: 'GET'
                                                    if (error) {
                                                    var recivedData = {
                                                        header,
                                                        title,
                                                        text
                                        			self.sendSocketNotification('TEXT_RESULT', recivedData);
                                            socketNotificationReceived: function (notification, payload) {
                                                if (notification === 'GET_TEXT_DATA') {
                                                    self.getData();
                                        • L Offline
                                          lolo
                                          Now create MMM-Dnevni_citat.js
                                          Inside you need first to registar module
                                          Module.register("MMM-Dnevni_citat", {
                                          	defaults: {
                                          		updateInterval:  10 x  60 x 1000,       //  minute ,seconds ,milliseconds
                                          		//retryDelay: 5000          // not needed for now
                                          Then first function will be start function
                                                  requiresVersion: "2.1.0";
                                                  this.scheduleUpdate();
                                          with first function we are calling second ( scheduleUpdate) , how often will fetch data.
                                             scheduleUpdate: function () {
                                                  setInterval(() => {
                                                      this.getData();
                                                  this.getData();
                                          Then we are calling getData function. Sending socketNotification to node_helper.
                                                  this.sendSocketNotification(''GET_TEXT_DATA'', this.config);
                                          Whe node_helper send back, next function will check if data is received and update DOM
                                                 if (notification === "TEXT_RESULT") {
                                                     this.textDataRecived = payload;
                                                     this.loaded = true;
                                                },this.updateDom();
                                          Now only is left to create DOM
                                              getDom: function () {
                                                  if (!this.loaded) {
                                                      wrapper.innerHTML = "LOADING";
                                                      return wrapper;
                                                  if (this.loaded) {
                                                 // here to add elements and styling
                                                     return wrapper;
                                            Amoniak @lolo
                                            @lolo
                                            i did that. it is still not displayed
                                            i added this configuration in the config.js file:
                                            module: “MMM-Dnevni_citat”,
                                            position: “middle_center”
