    module that displays a certain text from a website, the text on the website is updated daily
    36 Posts 6 Posters 16.0k Views 7 Watching
    • A
      ashishtank Module Developer @Amoniak
      @Amoniak any error in dev console or PM2/terminal ?
      A 1 Reply Last reply
      • A
        Amoniak @ashishtank
        @ashishtank i got it now, i will now try to parse the html response to extract the text, any good tips?
        A E 2 Replies Last reply
        • A
          @Amoniak yes, I checked the response from watch tower in postman and they give data of last 2-3 days or may be from Sunday to this day, so you will need to select the right node. You can use class tabContent as identifier and today’s date for selection of the node. Also check which html parse is good enough, as HTML is very complex to parse you may want to choose right parser which gives speed and is lightweight. i.e. node-html-parser
          2021-01-20-18-33-58-Clipboard
          Other thing you can do is once you have parsed text data from watch tower, you can assign it to poem’s format (title, content and name) and it will just work. later on you can change the UI and text property names if you want.
            sdetweil @ashishtank
            @ashishtank cheerio lib will parse html to json
            • A
              Amoniak
              well, I’ll get started then. Keep your fingers crossed.
              • A
                Amoniak
                i installed cheerio, but i don’t know how to use it.
                do I have to put this now in my “MMM-PoemOfTheDay.js” ?
                  sdetweil @Amoniak
                  @Amoniak gotta go read the library usage
                  • L
                    lolo
                    It gonna be harder than u think as your text is changing daily. Just follow the the pattern.
                    Every day this is changed( https://wol.jw.org/hr/wol/h/r19/lp-c).
                    new day new text.
                    Text is in :
                    div id=“dailyText”
                    but if you ignore reference in text as (Mat. 16:24, 25; Ivan 15:20) located in a class it’s gonna be more easier.
                    And with cheerio u can complete this.
                    • A
                      Amoniak
                      so, this is what my NodeHelper.js looks like. like i thought, the screen is black.
                      const axios = require("axios");
                      const DetectLanguage = require("detectlanguage");
                              socketNotificationReceived: async function(noti, payload) {
                                      if (noti === "START") {
                                              if (payload.updateInterval < 120000) {
                                                      payload.updateInterval = 120000;
                                              const self = this;
                                              (async function displayWatchtower () {
                                                      const poem = await getWatchtower(payload);
                                                      self.sendSocketNotification("UPDATE", poem);
                                                      setTimeout(displayPoem, payload.updateInterval);
                      const cheerio = require("cheerio");
                      const axios = require("axios").default;
                      const fethHtml = async url => {
                        try {
                          const { data } = await axios.get(url);
                          return data;
                        } catch {
                          console.error(`ERROR: An error occurred while trying to fetch the URL: ${url}`);
                      const extracWatchtower = selector => {
                        const theme = selector
                          .find(".tabContent active")
                          .find("[class='themeScrp'] > [class='b'])
                          .text()
                          .trim();
                       const text = selector
                          .find(".bodyTxt")
                          .find("[class='section']")
                          .text()
                          .trim();
                       return { theme,
                                text
                      const scrapWatchtower = async () => {
                        const watchtowerUrl =
                          "https://wol.jw.org/hr/wol/h/r19/lp-c";
                        const html = await fethHtml(watchtowerUrl);
                        const selector = cheerio.load(html);
                        const searchResults = selector("body")
                            .find("#dailyText"
                        const deals = searchResults.map((idx, el) => {
                            const elementSelector = selector(el);
                            return extractDeal(elementSelector)
                          .get();
                        return Watchtower;
                      • A
                        @Amoniak there are lots of missing pieces… add console.log with some message in each function and see how the flow works.
                        • L
                          lolo
                          Try to do something with this code. It will retrieve data from current day. Modifying that node_helper is not great idea.
                              const url=  'https://wol.jw.org/hr/wol/h/r19/lp-c';
                              request({
                                  url: url,
                                  method: 'GET'
                                  }, (error, response, body) => {
                                      if (error) {
                                          return console.error(error)
                                      var $ = cheerio.load(body);
                                      //console.log($.html());
                                      const data =  $('div[class="tabContent"]').first();
                                      let header = $(data).find('h2').text();
                                      let title = $(data).find('p').first().text();
                                      let text = $(data).find('div.pGroup>p').text();
                                      //console.log(header,title,text);
                                      var recivedData={
                                          header,
                                          title,
                                          text
                                      //console.log(recivedData);
                          • F
                            fordi
                            I bet you could use the same technique to see if any playstation 5 are in stock on websites?
                            • A
                              Amoniak @lolo
                              @lolo thank you for the code.
                              I used the “MagicMirror-Module-Template” to create a new file and the associated folder.
                              this is my js:
                              Module.register(“dnevni_citat”, {
                              defaults: {
                              updateInterval: 60000,
                              retryDelay: 5000
                                  requiresVersion: "2.1.0", // Required version of MagicMirror
                                  start: function() {
                                          var self = this;
                                          var dataRequest = null;
                                          var dataNotification = null;
                                          //Flag for check if module is loaded
                                          this.loaded = false;
                                          // Schedule update timer.
                                          this.getData();
                                          setInterval(function() {
                                                  self.updateDom();
                                          }, this.config.updateInterval);
                              request({
                                  url: url,
                                  method: 'GET'
                                      if (error) {
                                      var recivedData={
                                          header,
                                          title,
                                          text
                              what am I doing wrong?
                              • L
                                lolo
                                This should be your node_helper.
                                const NodeHelper = require("node_helper");
                                const request = require('request');
                                    start: function () {
                                        self = this;
                                        console.log("Starting node_helper for: " + this.name);
                                    getData: function () {
                                        const url = 'https://wol.jw.org/hr/wol/h/r19/lp-c';
                                        request({
                                            url: url,
                                            method: 'GET'
                                            if (error) {
                                            var recivedData = {
                                                header,
                                                title,
                                                text
                                			self.sendSocketNotification('TEXT_RESULT', recivedData);
                                    socketNotificationReceived: function (notification, payload) {
                                        if (notification === 'GET_TEXT_DATA') {
                                            self.getData();
                                • L
                                  lolo
                                  Now create MMM-Dnevni_citat.js
                                  Inside you need first to registar module
                                  Module.register("MMM-Dnevni_citat", {
                                  	defaults: {
                                  		updateInterval:  10 x  60 x 1000,       //  minute ,seconds ,milliseconds
                                  		//retryDelay: 5000          // not needed for now
                                  Then first function will be start function
                                          requiresVersion: "2.1.0";
                                          this.scheduleUpdate();
                                  with first function we are calling second ( scheduleUpdate) , how often will fetch data.
                                     scheduleUpdate: function () {
                                          setInterval(() => {
                                              this.getData();
                                          this.getData();
                                  Then we are calling getData function. Sending socketNotification to node_helper.
                                          this.sendSocketNotification(''GET_TEXT_DATA'', this.config);
                                  Whe node_helper send back, next function will check if data is received and update DOM
                                         if (notification === "TEXT_RESULT") {
                                             this.textDataRecived = payload;
                                             this.loaded = true;
                                        },this.updateDom();
                                  Now only is left to create DOM
                                      getDom: function () {
                                          if (!this.loaded) {
                                              wrapper.innerHTML = "LOADING";
                                              return wrapper;
                                          if (this.loaded) {
                                         // here to add elements and styling
                                             return wrapper;
                                  • A
                                    Amoniak @lolo
                                    @lolo
                                    i did that. it is still not displayed
                                    i added this configuration in the config.js file:
                                    module: “MMM-Dnevni_citat”,
                                    position: “middle_center”
                                    L 1 Reply Last reply
                                    • L
                                      lolo
                                      It’s not displayed as DOM elements are not created.
                                      But there is another problem with cheerio, is not loading any data for Saturday and Sunday. This is because of website. Need to find another approach.
                                      • L
                                        lolo
                                        node_helper. But need to find different approach.
                                        var self;
                                                self = this;
                                                request({
                                                    url: url,
                                                    method: 'GET'
                                                    if (error) {
                                                        return console.error("ERROR: ",error)
                                                    if (!error && response.statusCode == 200) {
                                                    const data = $('div[class="tabContent"]').first();//
                                                    let textData = $(data).find('div.pGroup>p').text();
                                                    var recivedData = {
                                                        header,
                                                        title,
                                                        textData
                                        			//console.log('recivedData: ',recivedData);
                                             var self = this;
                                                    //console.log(notification,payload);
                                        			self.getData();
                                        MMM-Dnevni_citat.js. getDom need some styling.
                                            defaults: {
                                                updateInterval: 10 * 60 * 1000, //  minute ,seconds ,milliseconds
                                                setInterval(() => {
                                                    this.getData();
                                                this.getData();
                                                console.log(' GET_TEXT_DATA ', this.config)
                                                this.sendSocketNotification('GET_TEXT_DATA', this.config);
                                                    console.log(this.textDataRecived);
                                                    this.loaded = true;
                                                this.updateDom();
                                                if (!this.loaded) {
                                                    return wrapper;
                                                if (this.loaded) {
                                                    var header = document.createElement("header");
                                                    header.innerHTML = this.textDataRecived.header;
                                                    wrapper.appendChild(header);
                                                    var table = document.createElement('tr');
                                                    table.classList.add("xsmall", "normal");
                                                    var title = document.createElement('tr');
                                                    title.innerHTML = this.textDataRecived.title;
                                                    table.appendChild(title);
                                                    var textData = document.createElement('tr');
                                                    textData.innerHTML = this.textDataRecived.textData;
                                                    table.appendChild(textData);
                                                    wrapper.appendChild(table);
                                                return wrapper;
                                        config.js
                                        		{    module: "MMM-Dnevni_citat",
                                                     position: "middle_center"
                                        • L
                                          lolo @Amoniak
                                          @Amoniak
                                          This should fix the problem with loading text for current Date.
                                          node_helper:
                                          var self;
                                          const ur = 'https://wol.jw.org/wol/dt/r19/lp-c';
                                                  self = this;
                                                  self.browser
                                                  var self = this;
                                                  var url = self.setURL();
                                                  request({
                                                      url: url,
                                                      method: 'GET'
                                                      if (!error) {
                                                          var result = JSON.parse(body);
                                                          var contentData = result.items[0].content;
                                                          var $ = cheerio.load(contentData);
                                                          //console.log("cheerio:  ", $.html());
                                                          var header = $('html>body>header>h2').text();
                                                          var title = $('p').first().text();
                                                          var textData = $('p').first().next().text().replace(/(\r\n|\n|\r)/gm, "");
                                                          var recivedData = {
                                                              header,
                                                              title,
                                                              textData
                                                      if (error) {
                                                          console.log(error);
                                              setURL: function () {
                                                  console.log("ur old: ", ur);
                                                  var utc = new Date().toJSON().slice(0, 10).replace(/-/g, '/');
                                                  var newURL = ur.concat("/").concat(utc);
                                                  return newURL
                                                  var self = this;
                                                      self.getData();
                                          • A
                                            Amoniak @lolo
                                            @lolo
                                            thank you, I’ll try right now
