    Not all Modules are displaying on the tv
    34 Posts 6 Posters 14.3k Views 5 Watching
    • kusselinK Offline
      kusselin
      exactly … milliseconds and two minutes should be long for a switch …
      as I said, even if I take out the duration time it doesn’t work with traffic and the weather module :-(
      I take the complete mmm-pages code out of the config, then everything works!
      • mumblebajM Offline
        @sdetweil I have had a look and I see the following:
        Will not show MMM-Traffic. LockStrings active: module_7_MMM-pages
        I assume this is why the MMM-Traffic is not showing when used in MMM-Pages? I have added the modules on my test machine and I can’t get the module to show either. I see that the above error comes from the main.js of MM. maybe you can shed more light on the issue for @kusselin
          sdetweil @mumblebaj
          @mumblebaj that is not an error. Just info.
          The module will ONLY be shown on its page, or if set to fixed.
          All the message says is pages hid it, and no-one else can show it
            Looks like this module manipulates the hidden status directly, instead of calling the hide/show api…
              @sdetweil Yeah, doesn’t seem to play well with pages. The minute you remove paged the module works fine.
              • kusselinK Offline
                kusselin
                @mumblebaj said in Not all Modules are displaying on the tv:
                Yep, that’s how I see it … the MMM traffic module cannot be used in combination with the MMM pages module !!
                • kusselinK Offline
                  kusselin
                  MMM-Traffic definitely doesn’t work with the module “Pages” !!! And the weather module doesn’t work either if you run the “pages” module !! This is a pity :-(
                  Can the developer of MMM Traffic and the MMM-OpenmapWeather take a look …
                  here again my config:
                      			module: "MMM-pages",
                  						modules:
                  						[[ "MMM-SoccerLiveScore" ],
                  						[ "MMM-COVID19-AMPEL" ],
                  						[ "MMM-Formula1" ]],
                  			fixed: [ "clock" , "MMM-OpenmapWeather" , "weatherforecast" , "MMM-PublicTransportHafas" , "newsfeed" , "calendar" , "MMM-Fuel", "MMM-Tankerkoenig" , "MMM-ioBroker" , "MMM-Traffic" ],
                      		rotationTime: 120000,
                    sdetweil @kusselin
                    @kusselin posting here probably won’t get the developer’s attention… open an issue on the module github site
                    • kusselinK Offline
                      kusselin
                      @sdetweil said in Not all Modules are displaying on the tv:
                      ok. thanks
                      • O Offline
                        OberfragGER @kusselin
                        @kusselin I have nearly sam problem with less Modules.
                        The default weather and also MMM-openmapweather are not loading, when u put that on the first page of MM-Pages. If you put that on other Pages, no problem so far.
                        I dont have any idea why…
                        • kusselinK Offline
                          kusselin
                          Ok, thank you for answer
