    module that displays a certain text from a website, the text on the website is updated daily
    36 Posts 6 Posters 12.9k Views 7 Watching
      Amoniak
      so, this is what my NodeHelper.js looks like. like i thought, the screen is black.
      const axios = require("axios");
      const DetectLanguage = require("detectlanguage");
              socketNotificationReceived: async function(noti, payload) {
                      if (noti === "START") {
                              if (payload.updateInterval < 120000) {
                                      payload.updateInterval = 120000;
                              const self = this;
                              (async function displayWatchtower () {
                                      const poem = await getWatchtower(payload);
                                      self.sendSocketNotification("UPDATE", poem);
                                      setTimeout(displayPoem, payload.updateInterval);
      const cheerio = require("cheerio");
      const axios = require("axios").default;
      const fethHtml = async url => {
        try {
          const { data } = await axios.get(url);
          return data;
        } catch {
          console.error(`ERROR: An error occurred while trying to fetch the URL: ${url}`);
      const extracWatchtower = selector => {
        const theme = selector
          .find(".tabContent active")
          .find("[class='themeScrp'] > [class='b'])
          .text()
          .trim();
       const text = selector
          .find(".bodyTxt")
          .find("[class='section']")
          .text()
          .trim();
       return { theme,
                text
      const scrapWatchtower = async () => {
        const watchtowerUrl =
          "https://wol.jw.org/hr/wol/h/r19/lp-c";
        const html = await fethHtml(watchtowerUrl);
        const selector = cheerio.load(html);
        const searchResults = selector("body")
            .find("#dailyText"
        const deals = searchResults.map((idx, el) => {
            const elementSelector = selector(el);
            return extractDeal(elementSelector)
          .get();
        return Watchtower;
        ashishtank Module Developer
        @Amoniak there are lots of missing pieces… add console.log with some message in each function and see how the flow works.
        • L Offline
          lolo
          Try to do something with this code. It will retrieve data from current day. Modifying that node_helper is not great idea.
              const url=  'https://wol.jw.org/hr/wol/h/r19/lp-c';
              request({
                  url: url,
                  method: 'GET'
                  }, (error, response, body) => {
                      if (error) {
                          return console.error(error)
                      var $ = cheerio.load(body);
                      //console.log($.html());
                      const data =  $('div[class="tabContent"]').first();
                      let header = $(data).find('h2').text();
                      let title = $(data).find('p').first().text();
                      let text = $(data).find('div.pGroup>p').text();
                      //console.log(header,title,text);
                      var recivedData={
                          header,
                          title,
                          text
                      //console.log(recivedData);
          • F Offline
            fordi
            I bet you could use the same technique to see if any playstation 5 are in stock on websites?
              Amoniak @lolo
              @lolo thank you for the code.
              I used the “MagicMirror-Module-Template” to create a new file and the associated folder.
              this is my js:
              Module.register(“dnevni_citat”, {
              defaults: {
              updateInterval: 60000,
              retryDelay: 5000
                  requiresVersion: "2.1.0", // Required version of MagicMirror
                  start: function() {
                          var self = this;
                          var dataRequest = null;
                          var dataNotification = null;
                          //Flag for check if module is loaded
                          this.loaded = false;
                          // Schedule update timer.
                          this.getData();
                          setInterval(function() {
                                  self.updateDom();
                          }, this.config.updateInterval);
              request({
                  url: url,
                  method: 'GET'
                      if (error) {
                      var recivedData={
                          header,
                          title,
                          text
              what am I doing wrong?
              • L Offline
                lolo
                This should be your node_helper.
                const NodeHelper = require("node_helper");
                const request = require('request');
                    start: function () {
                        self = this;
                        console.log("Starting node_helper for: " + this.name);
                    getData: function () {
                        const url = 'https://wol.jw.org/hr/wol/h/r19/lp-c';
                        request({
                            url: url,
                            method: 'GET'
                            if (error) {
                            var recivedData = {
                                header,
                                title,
                                text
                			self.sendSocketNotification('TEXT_RESULT', recivedData);
                    socketNotificationReceived: function (notification, payload) {
                        if (notification === 'GET_TEXT_DATA') {
                            self.getData();
                • L Offline
                  lolo
                  Now create MMM-Dnevni_citat.js
                  Inside you need first to registar module
                  Module.register("MMM-Dnevni_citat", {
                  	defaults: {
                  		updateInterval:  10 x  60 x 1000,       //  minute ,seconds ,milliseconds
                  		//retryDelay: 5000          // not needed for now
                  Then first function will be start function
                          requiresVersion: "2.1.0";
                          this.scheduleUpdate();
                  with first function we are calling second ( scheduleUpdate) , how often will fetch data.
                     scheduleUpdate: function () {
                          setInterval(() => {
                              this.getData();
                          this.getData();
                  Then we are calling getData function. Sending socketNotification to node_helper.
                          this.sendSocketNotification(''GET_TEXT_DATA'', this.config);
                  Whe node_helper send back, next function will check if data is received and update DOM
                         if (notification === "TEXT_RESULT") {
                             this.textDataRecived = payload;
                             this.loaded = true;
                        },this.updateDom();
                  Now only is left to create DOM
                      getDom: function () {
                          if (!this.loaded) {
                              wrapper.innerHTML = "LOADING";
                              return wrapper;
                          if (this.loaded) {
                         // here to add elements and styling
                             return wrapper;
                    Amoniak @lolo
                    @lolo
                    i did that. it is still not displayed
                    i added this configuration in the config.js file:
                    module: “MMM-Dnevni_citat”,
                    position: “middle_center”
                    • L Offline
                      lolo
                      It’s not displayed as DOM elements are not created.
                      But there is another problem with cheerio, is not loading any data for Saturday and Sunday. This is because of website. Need to find another approach.
                      • L Offline
                        lolo
                        node_helper. But need to find different approach.
                        var self;
                                self = this;
                                request({
                                    url: url,
                                    method: 'GET'
                                    if (error) {
                                        return console.error("ERROR: ",error)
                                    if (!error && response.statusCode == 200) {
                                    const data = $('div[class="tabContent"]').first();//
                                    let textData = $(data).find('div.pGroup>p').text();
                                    var recivedData = {
                                        header,
                                        title,
                                        textData
                        			//console.log('recivedData: ',recivedData);
                             var self = this;
                                    //console.log(notification,payload);
                        			self.getData();
                        MMM-Dnevni_citat.js. getDom need some styling.
                            defaults: {
                                updateInterval: 10 * 60 * 1000, //  minute ,seconds ,milliseconds
                                setInterval(() => {
                                    this.getData();
                                this.getData();
                                console.log(' GET_TEXT_DATA ', this.config)
                                this.sendSocketNotification('GET_TEXT_DATA', this.config);
                                    console.log(this.textDataRecived);
                                    this.loaded = true;
                                this.updateDom();
                                if (!this.loaded) {
                                    return wrapper;
                                if (this.loaded) {
                                    var header = document.createElement("header");
                                    header.innerHTML = this.textDataRecived.header;
                                    wrapper.appendChild(header);
                                    var table = document.createElement('tr');
                                    table.classList.add("xsmall", "normal");
                                    var title = document.createElement('tr');
                                    title.innerHTML = this.textDataRecived.title;
                                    table.appendChild(title);
                                    var textData = document.createElement('tr');
                                    textData.innerHTML = this.textDataRecived.textData;
                                    table.appendChild(textData);
                                    wrapper.appendChild(table);
                                return wrapper;
                        config.js
                        		{    module: "MMM-Dnevni_citat",
                                     position: "middle_center"
                        • L Offline
                          lolo @Amoniak
                          @Amoniak
                          This should fix the problem with loading text for current Date.
                          node_helper:
                          var self;
                          const ur = 'https://wol.jw.org/wol/dt/r19/lp-c';
                                  self = this;
                                  self.browser
                                  var self = this;
                                  var url = self.setURL();
                                  request({
                                      url: url,
                                      method: 'GET'
                                      if (!error) {
                                          var result = JSON.parse(body);
                                          var contentData = result.items[0].content;
                                          var $ = cheerio.load(contentData);
                                          //console.log("cheerio:  ", $.html());
                                          var header = $('html>body>header>h2').text();
                                          var title = $('p').first().text();
                                          var textData = $('p').first().next().text().replace(/(\r\n|\n|\r)/gm, "");
                                          var recivedData = {
                                              header,
                                              title,
                                              textData
                                      if (error) {
                                          console.log(error);
                              setURL: function () {
                                  console.log("ur old: ", ur);
                                  var utc = new Date().toJSON().slice(0, 10).replace(/-/g, '/');
                                  var newURL = ur.concat("/").concat(utc);
                                  return newURL
                                  var self = this;
                                      self.getData();
                            Amoniak @lolo
                            @lolo
                            thank you, I’ll try right now
                              Amoniak
                              @lolo there it is.
                              many, many, many thanks. and thanks for adding explanations
                              • L Offline
                                lolo @Amoniak
                                @Amoniak you’re welcome.
                                Just delete the second appendChild in MMM-Dnevni_citat.js
                                            table.appendChild(title);        // delete this one
                                I added twice,my mistake.
                                • E Offline
                                  e199504 @Amoniak
                                  @amoniak how did you fix the black screen? I am getting the same error
                                    sdetweil @e199504
                                    @e199504 is this after install?
                                    did u do the npm install in the module folder?
                                    • E Offline
                                      e199504 @sdetweil
                                      @sdetweil in the reeadme file it did not say to go inside the module and use npm install but once I did it started working.
                                      thank you
                                        sdetweil @e199504
                                        @e199504 yes. it seems many authors forget to write that step.
                                        general rule. look for a package.json file.
                                        if present, run the npm install
