    module that displays a certain text from a website, the text on the website is updated daily
    36 Posts 6 Posters 13.2k Views 7 Watching
      Amoniak @lolo
      @lolo
      i did that. it is still not displayed
      i added this configuration in the config.js file:
      module: “MMM-Dnevni_citat”,
      position: “middle_center”
      • L Offline
        lolo
        It’s not displayed as DOM elements are not created.
        But there is another problem with cheerio, is not loading any data for Saturday and Sunday. This is because of website. Need to find another approach.
        • L Offline
          lolo
          node_helper. But need to find different approach.
          const NodeHelper = require("node_helper");
          const cheerio = require("cheerio");
          const request = require('request');
          var self;
              start: function () {
                  self = this;
                  console.log("Starting node_helper for: " + this.name);
              getData: function () {
          		const url = 'https://wol.jw.org/hr/wol/h/r19/lp-c';
                  request({
                      url: url,
                      method: 'GET'
                  }, (error, response, body) => {
                      if (error) {
                          return console.error("ERROR: ",error)
                      if (!error && response.statusCode == 200) {
                      var $ = cheerio.load(body);
                      //console.log($.html());
                      const data = $('div[class="tabContent"]').first();//
                      let header = $(data).find('h2').text();
                      let title = $(data).find('p').first().text();
                      let textData = $(data).find('div.pGroup>p').text();
                      //console.log(header,title,text);
                      var recivedData = {
                          header,
                          title,
                          textData
          			//console.log('recivedData: ',recivedData);
          			self.sendSocketNotification('TEXT_RESULT', recivedData);
              socketNotificationReceived: function (notification, payload) {
               var self = this;
                  if (notification === 'GET_TEXT_DATA') {
                      //console.log(notification,payload);
          			self.getData();
          MMM-Dnevni_citat.js. getDom need some styling.
          Module.register("MMM-Dnevni_citat", {
              defaults: {
                  updateInterval: 10 * 60 * 1000, //  minute ,seconds ,milliseconds
                  //retryDelay: 5000          // not needed for now
                  requiresVersion: "2.1.0";
                  this.loaded = false;
                  this.scheduleUpdate();
              scheduleUpdate: function () {
                  setInterval(() => {
                      this.getData();
                  }, this.config.updateInterval);
                  this.getData();
                  console.log(' GET_TEXT_DATA ', this.config)
                  this.sendSocketNotification('GET_TEXT_DATA', this.config);
                  if (notification === "TEXT_RESULT") {
                      this.textDataRecived = payload;
                      console.log(this.textDataRecived);
                      this.loaded = true;
                  this.updateDom();
              getDom: function () {
                  if (!this.loaded) {
                      wrapper.innerHTML = "LOADING";
                      return wrapper;
                  if (this.loaded) {
                      var header = document.createElement("header");
                      header.innerHTML = this.textDataRecived.header;
                      wrapper.appendChild(header);
                      var table = document.createElement('tr');
                      table.classList.add("xsmall", "normal");
                      var title = document.createElement('tr');
                      title.innerHTML = this.textDataRecived.title;
                      table.appendChild(title);
                      var textData = document.createElement('tr');
                      textData.innerHTML = this.textDataRecived.textData;
                      table.appendChild(textData);
                      wrapper.appendChild(table);
                  return wrapper;
          config.js
          		{    module: "MMM-Dnevni_citat",
                       position: "middle_center"
          • L Offline
            lolo @Amoniak
            @Amoniak
            This should fix the problem with loading text for current Date.
            node_helper:
            var self;
            const ur = 'https://wol.jw.org/wol/dt/r19/lp-c';
                    self = this;
                    self.browser
                    var self = this;
                    var url = self.setURL();
                    request({
                        url: url,
                        method: 'GET'
                        if (!error) {
                            var result = JSON.parse(body);
                            var contentData = result.items[0].content;
                            var $ = cheerio.load(contentData);
                            //console.log("cheerio:  ", $.html());
                            var header = $('html>body>header>h2').text();
                            var title = $('p').first().text();
                            var textData = $('p').first().next().text().replace(/(\r\n|\n|\r)/gm, "");
                            var recivedData = {
                                header,
                                title,
                                textData
                            //console.log(recivedData);
                        if (error) {
                            console.log(error);
                setURL: function () {
                    console.log("ur old: ", ur);
                    var utc = new Date().toJSON().slice(0, 10).replace(/-/g, '/');
                    var newURL = ur.concat("/").concat(utc);
                    return newURL
                    var self = this;
                        self.getData();
              Amoniak @lolo
              @lolo
              thank you, I’ll try right now
                Amoniak
                @lolo there it is.
                many, many, many thanks. and thanks for adding explanations
                • L Offline
                  lolo @Amoniak
                  @Amoniak you’re welcome.
                  Just delete the second appendChild in MMM-Dnevni_citat.js
                              table.appendChild(title);        // delete this one
                  I added twice,my mistake.
                  • E Offline
                    e199504 @Amoniak
                    @amoniak how did you fix the black screen? I am getting the same error
                      sdetweil @e199504
                      @e199504 is this after install?
                      did u do the npm install in the module folder?
                      • E Offline
                        e199504 @sdetweil
                        @sdetweil in the reeadme file it did not say to go inside the module and use npm install but once I did it started working.
                        thank you
                          sdetweil @e199504
                          @e199504 yes. it seems many authors forget to write that step.
                          general rule. look for a package.json file.
                          if present, run the npm install
