    Worldclock setup help?
    3 Posts 2 Posters 714 Views 2 Watching
    • N Offline
      negrito Project Sponsor
      Dear MagicMirror enthusiasts, I have a problem with the Worldclock. There are two clocks displayed at the moment, but I just want the clock with the flag. I tried everything and googled an answer, but I couldn’t figure it out. What should I change in the config.js to remove the Undefined UTC +01:00
      See my config.js file here:
        			module: 'worldclock',
        			position: 'top_left',
          			timeFormat: 'hh:mm A',
          			style: 'top',
         			offsetTimezone: null,
          			clocks: [
              		title: "Dominicaanse Republic",
              		timezone: "America/Santo_Domingo",
              		flag: "do",
      Thank you in advance.
      • BKeyportB Offline
        BKeyport Module Developer
        First, the supported module is MMM-Worldclock now. I’ve taken it over, Sean’s left for greener pastures.
        Second, there’s not an option to do that without CSS.
        in your custom.css the following will do it:
        [type] below is whatever style you use in config, in your case, “top”
        .MMM-Worldclock .style-[type] .caption {
         display:none;,
        • N Offline
          Ok, thank you fixed.
          kind regards,
