    Config file Error - 'Split' Property
    12 Posts 2 Posters 2.5k Views 2 Watching
      paulyp2k6
      So, I am not a SW engineering and a code neophyte, so my question may lack some of that clarity or insight. I just added a few new modules to my Config file, went through a round of troubleshooting syntax (e.g., missing commas and braces, etc.), and now I am getting an error that says: “WARNING: Could not load config file. Starting with default configuration. Error found: TypeError: Cannot read propert ‘split’ of undefined.”
      Any ideas of where that error may reside?!
        sdetweil @paulyp2k6
        @paulyp2k6 , no but do
        npm run config:check
        in the mm folder to check syntax.
        disable stuff til u find it
        many times u misspelled something.
        split means array []… so look for stuff like that.
        i admit even as hard as i tried, i missed many opportunities to catch these errors
          paulyp2k6
          Thanks so much, I will give that a try. In my college days the most frequent error was a missing semi-colon. Now it seems to be missing commas. Syntax will always be my downfall. But, thanks for the help.
            sdetweil @paulyp2k6
            @paulyp2k6 javascript is pretty straightforward in data definitions. allows comments, cause its ‘code’, vs json which is not, and very precise
              paulyp2k6 @sdetweil
              @sdetweil So, I ran the Syntax check just now, like you suggested, and the Config file has no Syntax errors.
                sdetweil @paulyp2k6
                @paulyp2k6 ok, then do this
                npm start >somefile
                wait, hit ctrl-c
                and show us somefile
                  paulyp2k6
                  2021-01-27 18:49:34.496] [ERROR] WARNING! Could not load config file. Starting with default configuration. Error found: TypeError: Cannot read property ‘split’ of undefined
                  [2021-01-27 18:49:34.501] [ERROR] App threw an error during load
                  [2021-01-27 18:49:34.502] [ERROR] TypeError: Cannot read property ‘split’ of undefined
                  at loadModule (/home/pi/MagicMirror/js/app.js:115:25)
                  at loadNextModule (/home/pi/MagicMirror/js/app.js:169:5)
                  at /home/pi/MagicMirror/js/app.js:171:6
                  at loadModule (/home/pi/MagicMirror/js/app.js:153:4)
                  at Class.loaded (/home/pi/MagicMirror/js/node_helper.js:18:3)
                  at loadModule (/home/pi/MagicMirror/js/app.js:151:6)
                  [2021-01-27 18:49:34.503] [ERROR] Whoops! There was an uncaught exception…
                  [2021-01-27 18:49:34.504] [ERROR] TypeError: Cannot read property ‘split’ of undefined
                  [2021-01-27 18:49:34.507] [ERROR] MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
                  [2021-01-27 18:49:34.508] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
                    sdetweil @paulyp2k6
                    @paulyp2k6 can u post the config.js?
                      paulyp2k6 @sdetweil
                      /* Magic Mirror Config Sample
                      • By Michael Teeuw https://michaelteeuw.nl
                      • MIT Licensed.
                      • For more information on how you can configure this file
                      • See https://github.com/MichMich/MagicMirror#configuration
                      var config = {
                      // - “0.0.0.0”, “::” to listen on any interface
                      // Default, when address config is left out or empty, is “localhost”
                      port: 8080,
                      basePath: “/”, // The URL path where MagicMirror is hosted. If you are using a Reverse proxy
                      ipWhitelist: [“127.0.0.1”, “::ffff:127.0.0.1”, “::1”], // Set [] to allow all IP addresses
                      // [“127.0.0.1”, “::ffff:127.0.0.1”, “::1”, “::ffff:192.168.1.5”],
                      // [“127.0.0.1”, “::ffff:127.0.0.1”, “::1”, “::ffff:192.168.3.0/28”],
                      language: "en",
                      logLevel: ["INFO", "LOG", "WARN", "ERROR"],
                      timeFormat: 24,
                      units: "metric",
                      		module: "alert"
                      		module: "updatenotification",
                      		position: "top_bar"
                      		module: "clock",
                      		position: "top_left"
                      		module: "compliments",
                      		position: "lower_third",
                      			compliments: {
                      			anytime: [
                      				"Praise God!"
                      			morning: [
                      				"Say your morning offering",
                      				"Live for others",
                      				"Read Psalm 23"
                      			afternoon: [
                      				"Say the Angelus",
                      				"Give Thanks to God",
                      				"Looking good today!"
                      			evening: [
                      				"Do your Daily Examen",
                      				"Have your prayed today?"
                      		    module: 'MMM-OnThisDay',
                      		    position: "top_center"
                      		module: 'MMM-DailyBibleVerse',
                      		position: 'bottom_bar',	// This can be any of the regions. Best result is in the bottom_bar as verses can take multiple lines in a day.
                      			version: 'NIV', // This can be changed to any version you want that is offered by Bible Gateway. For a list, go here: https://www.biblegateway.com/versions/,
                          			size: 'small' // default value is medium, but can be changed.
                      		  module: "MMM-MyScoreboard",
                      		  position: "bottom_right",
                      		  classes: "default everyone",
                      		  header: "My Scoreboard",
                      		    showLeagueSeparators: true,
                      		    colored: true,
                      		    viewStyle: "mediumLogos",
                      		    sports: [
                      			league: "NHL",
                      			groups: ["Atlantic"]
                      			league: "NBA",
                      			teams: ["CHI"]
                      			league: "MLB",
                      			teams: ["CHC"],
                      			groups: ["NL Central"]
                      			league: "NFL",
                      			teams: ["CHI"]
                      			league: "ENGLISH_PREMIERE_LEAGUE"
                      			league: "NCAAM_MM",
                      			label: "March Madness"
                      			league: "NCAAF",
                      			label: "ILL",
                      			groups: "Big Ten"
                      		module: "currentweather",
                      			units: "imperial",
                      			locationID: "4916288", //ID from http://bulk.openweathermap.org/sample/city.list.json.gz; unzip the gz file and find your city
                      			appid: "49865c49c53acd625df34235834afaa0"
                      		module: "weatherforecast",
                      		header: "Weather Forecast",
                      			units: "imperial",
                      		module: "newsfeed",
                      		position: "bottom_bar",
                      			feeds: [
                      					title: "New York Times",
                      					url: "https://rss.nytimes.com/services/xml/rss/nyt/HomePage.xml"
                      			showSourceTitle: true,
                      			showPublishDate: true,
                      			broadcastNewsFeeds: true,
                      			broadcastNewsUpdates: true
                      if (typeof module !== “undefined”) {module.exports = config;}
                        sdetweil @paulyp2k6
                        @paulyp2k6 said in Config file Error - 'Split' Property:
                        module: ‘MMM-OnThisDay’,
                        another modules array in the middle of the modules array?
                        see the two topics in my signature below
                        modules:[ … only once
                        all module defs go in here, one after the other. nowhere else
                          paulyp2k6 @sdetweil
                          @sdetweil Holy smokes!! Thanks so much for your patience with me on this one. I am sorry that took so long. And thanks for the extra training modules.
                            sdetweil @paulyp2k6
                            @paulyp2k6 i didn’t write the others, just reference really good writers
