    Compliments remotefile
    8 Posts 2 Posters 1.3k Views 2 Watching
      alhen18
      Hey, I got some problems with using my remote file for complements. I do now know why i wont load my .json file.
      Here are some of the code used:
      Config.js
          module: 'compliments',
          position: 'buttom',
              updateInterval: 5 * 60 * 100,
              remoteFile: "compliments.json",
      compliments.json
          "anytime" : [
              "Some Text",
              "Another text",
          "morning" : [
              "Morning text",
              "Another Morning text",
      When I open the devoloper console in the MagicMirror application, I get this text out and I do not see where my code should make the issue.
      I do hope that someone can help me, since I do not know where the issue happens.
        sdetweil @alhen18
        @alhen18 the remotefile is supposed to start
        “compliments”:{
        use one of the online json validators to make sure its valid
          alhen18 @sdetweil
          @sdetweil Thanks, for the respons, I do not have any problem getting a remote .json file to work, I have tried with yours : https://raw.githubusercontent.com/sdetweil/testcompliments/main/mycompliments.json
          I think that I will just post mine on GitHub and there by also making it easier to edit in it at a later time :)
            sdetweil @alhen18
            @alhen18 then what was the problem u reported?
              alhen18
              The real problem is that i cant get it to load from a local folder
                sdetweil @alhen18
                @alhen18 local folder has to.be in modules tree
                http://localhost:8080/modules/???/whatever.json
                  alhen18
                  @sdetweil It is also places under /modules/default/compliments/file.json
                  And the .json file is build as i would construct a .json fil at any other given point
                    sdetweil @alhen18
                    @alhen18 i dont understand. you say it doesnt work, but then describe how to make it work
