Compliments remotefile
Hey, I got some problems with using my remote file for complements. I do now know why i wont load my .json file.
Here are some of the code used:Config.js ... { module: 'compliments', position: 'buttom', config: { updateInterval: 5 * 60 * 100, remoteFile: "compliments.json", } }, ...compliments.json { "anytime" : [ "Some Text", "Another text", ], "morning" : [ "Morning text", "Another Morning text", ], ... }When I open the devoloper console in the MagicMirror application, I get this text out and I do not see where my code should make the issue.
I do hope that someone can help me, since I do not know where the issue happens.
@alhen18 the remotefile is supposed to start
“compliments”:{
}use one of the online json validators to make sure its valid
@sdetweil Thanks, for the respons, I do not have any problem getting a remote .json file to work, I have tried with yours : https://raw.githubusercontent.com/sdetweil/testcompliments/main/mycompliments.json
I think that I will just post mine on GitHub and there by also making it easier to edit in it at a later time :)
@alhen18 then what was the problem u reported?
The real problem is that i cant get it to load from a local folder
@alhen18 local folder has to.be in modules tree
http://localhost:8080/modules/???/whatever.json
@sdetweil It is also places under /modules/default/compliments/file.json
And the .json file is build as i would construct a .json fil at any other given point
@alhen18 i dont understand. you say it doesnt work, but then describe how to make it work
