    Default Clock Module showing wrong Sunrise/Sunset Time
    3 Posts 2 Posters 906 Views 2 Watching
      jamaces
      It is currently showing that the sun will rise at 10:19am and set at 8:30pm. I have set the timezone with “America/Toronto”. When it should be ~7:20am, 5:45pm.
      I have seen some other modules so I might just disable and use those.
        sdetweil @jamaces
        @jamaces did u specify the lat/lng config parms for the clock. to tell it where u are.located?
        https://docs.magicmirror.builders/modules/clock.html#configuration-options
        J 1 Reply Last reply
          jamaces @sdetweil
          Helps to read sometimes. Thank you.
