    MMM-iFrame-Ping - revisited
    8 Posts 3 Posters 2.9k Views 3 Watching
    • ebolisaE
      ebolisa
      I’m streaming video/music from a web but, for some reason, the audio doesn’t go through on a P0 it does on a P4 using the same config, however,
      Youtube and audio tests pass on both pies.
      Is there any reason for that?
      TIA
        sdetweil @ebolisa
        @ebolisa on a pi0 you are running chromium-browser, on a pi4, u are using electron js browser
        i suspect u have to do some setup on chromium
        see the 4th post here
        https://www.raspberrypi.org/forums/viewtopic.php?t=291066
        add the parm to the invocation of chromium in ~/MagicMirror/run-start.sh
        ebolisaE 1 Reply Last reply
        • ebolisaE
          ebolisa @sdetweil
          @sdetweil you mean in line 78?
          chromium-browser -noerrdialogs -kiosk -start_maximized  --disable-features=AudioServiceSandbox --disable-infobars --app=...
          the other way I get an error:
          pi@magicmirror:~/MagicMirror $ chromium-browser --disable-features=AudioServiceSandbox
          [1974:1974:0216/221501.872136:ERROR:browser_main_loop.cc(1432)] Unable to open X display.
            sdetweil @ebolisa
            @ebolisa correct.
            the second way probably fails because u are on an ssh session, and need to define the DISPLAY to use
            export DISPLAY=:0
            KamiSchamiK ebolisaE 2 Replies Last reply
            • KamiSchamiK
              KamiSchami @sdetweil
              I also stream YouTube videos but I don’t !!! want to hear any sound. Does the module regularly play no sound?
              Real programmers never work 9 to 5. If they are around at 9 AM, it’s because they were up all night.
                sdetweil @KamiSchami
                @kamischami according to this,
                https://peter.sh/experiments/chromium-command-line-switches/
                the
                –mute-audio
                parm should mute any audio
                • ebolisaE
                  ebolisa @sdetweil
                  @sdetweil making progress by tweaking a bit the line shown above to
                  chromium-browser --autoplay-policy=no-user-gesture-required --noerrdialogs --incognito --kiosk -start_maximized  --disable-features=AudioServiceSandbox --disable-infobars --app=...
                  However, streaming video on a P0 is not the best way to go so, I decided to just stream audio with this link http://stream-uk1.radioparadise.com/mp3-192. It’s much easer on buffering ;)
                    sdetweil @ebolisa
                    @ebolisa pi 0 is tough to of a lot different things at once
