    Problem with the positioning of the mirror modules. Cut from the top
    4 Posts 2 Posters 990 Views 3 Watching
      majdzik84
      Hi. please help.
      I lost my SD card and moved the installation to the SSD. Everything is ok except one thing.
      In the lower part of the mirror I have the MMM-iFrame module, I throw off the dasboard from Home assistant.
      Unfortunately, when starting / restarting the mirror, as you can see in the screenshot, the whole thing moves up and the upper modules are cut off.
      Interestingly, it sometimes loads correctly.
      When I remove the iframe module it loads as it should.
      Any suggestions on how I can fix this?
      • BKeyportB Offline
        BKeyport Module Developer @majdzik84
        Couple of things you can do.
        1- Check where your modules are positioned, they should bounce out of the way if they are in a different position than the iFrame module. (iframe should be bottom_something, and other modules be top_something)
        2- Add css to custom.css to use the entire monitor space to give you a bit more room:
        body {
        	margin: 0px;
        	height: 100vh;
        	width: 100vw;
        3- it does appear your iframe module is a bit too tall - if you’re using MMM-iFrame - change your “height” to be a few less pixels to lower it’s chances. (30 or so should do it)
          majdzik84 @BKeyport
          @BKeyport Thank you for your willingness to help.
          Unfortunately, I tried all the advice but nothing has changed :(
          It loads ok once in a few tries, but in most cases the whole screen is moved up.
          https://www.dropbox.com/s/ftc0abrnntcz9i0/VID_20210226_095022.mp4?dl=0
            module: 'MMM-iFrame',
            position: 'bottom_center', 	// This can be any of the regions.
            disabled: false,
               url: ["http://192.168.2.98:8123/magic-mirror/kamera?kiosk"], // as many URLs you want or you can just ["ENTER IN URL"] if single URL.
               autoRefresh: false,
          	//	updateInterval: 0.5 * 60 * 1000, // rotate URLs every 30 seconds
               width: "1440", // width of iframe
               height: "425", // height of iframe
               frameWidth: "1440", // width of embedded iframe, height is beeing calculated by aspect ratio of iframe
          			module: "alert",
          				effect: "genie",}
          			module: "updatenotification",
          			position: "top_bar"
          			module: "clock",
          			position: "top_left"
          			header: "KALENDARZ",
                          maximumEntries: 7,
                          maximumNumberOfDays: 365,
                          showLocation: false,
                          maxTitleLength: 25,
                          maxLocationTitleLength: 25,
                          wrapEvents: true,
                          wrapLocationEvents: false,
                          maxTitleLines: 3,
                          maxEventTitleLines: 3,
                          animationSpeed: 2000,
                          fade: false,
                          fadePoint: 0.25,
                          displayRepeatingCountTitle: true,
                          dateFormat: "MMM Do HH:mm",
                          dateEndFormat: "MMM Do HH:mm",
                          //showEnd: true,
                          fullyDayEventDateFormat: "MMM D",
                          timeFormat: "absolute",
                          getRelative: 6,
                          urgency: 1,
                          broadcastEvents: true,
                          hidePrivate: false,
                          sliceMultiDayEvents: false,
                          nextDaysRelative: true,
          				colored: true,
          				calendars: [{
          						symbol: "calendar-check-o",
          						url: "https:/basic.ics"
          						symbol: "birthday-cake",
          						color: '#27b7e3',
          						url: "https://calendar.google.com/"
          						symbol: "trash-alt",
          						color: '#ebd234',
          						url: "https://calendar.google.com/.ics"
          						symbol: "calendar-times",
          						color: "#ff3b29",
          						url: "https://www.thunderbird.net/media/caldata/PolishHolidays.ics"
          	module: "MMM-Currentweather-MQTT",
          	disabled: false,
          				locationID: "3094597", //ID from http://bulk.openweathermap.org/sample/city.list.json.gz; unzip the gz file and find your city
          				appid: "xxxx",
          		roundTemp: false,
          		degreeLabel: true,
          		showWindDirection: true,
          		showWindDirectionAsArrow: true,
          		showHumidity: true,
          		showFeelsLike: true,
          		useBeaufort: false,
          		useKMPHwind: true,
          		logging: true,
          		useWildcards: false,
          		showTempMax: true,
          		showTempMin: true,
          		mqttServers: [
          				address: '192.168.2.98',  // Server address or IP address
          				port: '1883',                // Port number if other than default
          				user: 'xxx',
          				password: 'xxx!',
          				subscriptions: [             // for now, all seven values must be
          				                             // specified in the config,
          							     // even if they are not delivered and not displayed.
          						topic: 'mirror/pogoda/temperatura', // Topic to look for
          						suffix: '°C',             // Displayed after the value
          						decimals: 1,              // Round numbers to this number of decimals
          						sortOrder: 10,            // sortOrder 10 has to contain the temperature
          						maxAgeSeconds: 18000,     // take Openweather value if older than 5 hours
          						topic: 'mirror/pogoda/wilgotnosc',
          						suffix: '%',
          						decimals: 0,
          						sortOrder: 20,            // sortOrder 210 has to contain the humidity
          						topic: 'mirror/pogoda/temp_piec',
          						suffix: '°C',
          						decimals: 1,
          						sortOrder: 30,            // sortOrder 30 has to contain the illumination
          						topic: 'mirror/pogoda/wiatr',
          						suffix: '°C',
          						decimals: 1,
          						sortOrder: 40,            // sortOrder 40 has to contain the wind speed
          						topic: 'wetter/act-wind-dir',
          						suffix: '°',
          						decimals: 0,
          						sortOrder: 50,            // sortOrder 50 has to contain the wind direction
          						topic: 'wetter/raining',
          						suffix: '',
          						decimals: 0,
          						sortOrder: 60,            // sortOrder 60 has to contain the boolean if its just raining
          						conversions: [
          							{ from: "true", to: "tak" },
          							{ from: "false", to: "nie" }
          						topic: 'wetter/rain-today',
          						suffix: '',
          						decimals: 1,
          						sortOrder: 70,            // sortOrder 70 has to contain the amount of rain today
          						topic: 'mirror/pogoda/max',
          						label: 'c',
          						suffix: '',
          						decimals: 0,
          						sortOrder: 80,
          						maxAgeSeconds: 180000,
          						topic: 'mirror/pogoda/min',
          						label: 'c',
          						suffix: '',
          						decimals: 0,
          						sortOrder: 90,
          			module: "weatherforecast",
          			disabled: false,
          			header: "Prognoza pogody",
          				lang: "pl",
          				locationID: "xxx", //ID from http://bulk.openweathermap.org/sample/city.list.json.gz; unzip the gz file and find your city
          				appid: "xxxx",
          				maxNumberOfDays: 4,
                                          //colored: "false",
                                          fade: false,
                                          //fadePoint: 1,
                                          showRainAmount: true,
                                          scale: false,
              module: 'MMM-MQTT',
              position: 'top_right',
              header: '',
                  logging: false,
                  mqttServers: [
                          user: 'xxxx',          // Leave out for no user
                          password: 'xxxx!',  // Leave out for no password
                          subscriptions: [
                                  topic: 'mirror/pogoda/powietrze', // Topic to look for
                                  label: 'Powietrze jest', // Displayed in front of value
                                  suffix: '',         // Displayed after the value
                                  maxAgeSeconds: 350,    // Reduce intensity if value is older
                                  topic: 'mirror/pogoda/temp_piec', // Topic to look for
                                  label: 'Temp.ogród: ', // Displayed in front of value
                                  topic: 'mirror/pogoda/co2', // Topic to look for
                                  label: 'CO2 w salonie: ', // Displayed in front of value
                                  suffix: 'ppm',         // Displayed after the value
                                   colors: [             // Value dependent colors
                                      { upTo: 500, value: "green", label: "green", suffix: "green" },
                                      { upTo: 600, label: "yellow", value: "yellow", suffix: "yellow" },
                                      { upTo: 900, label: "#ff4d00", value: "#ff4d00", suffix: "#ff4d00" },
                                      { upTo: 2000, label: "red", value: "red", suffix: "red"  }, // The last one is used for higher values too
            module: "MMM-NowPlayingOnSpotify",
            position: "center",
            disabled: false,
          	showCoverArt: true,
              clientID: "xxx",
              clientSecret: "xxx",
              accessToken: "xxxxx",
              refreshToken: "xxxx-xxxx"
              module: 'MMM-Remote-Control'
              //, position: 'bottom_left'
          • BKeyportB Offline
            @majdzik84 Let’s invoke the CSS gods around here… Hey, @cowboysdude ? You got advice?
            @alberttwong if you’re still around, can you help?
