    Cached pictures in iFrame
    11 Posts 3 Posters 3.6k Views 3 Watching
    • BKeyportB Offline
      BKeyport Module Developer
      Here’s the situation. I’m using MMM-iFrame currently (Tried others, same result) to display a PHP generated image. The data behind the image is refreshed approximately every 3-4 hours.
      The two urls I’m using is http://www.hamqsl.com/solarpich.php & http://www.hamqsl.com/solarsystem.php.
      for whatever reason, the images generated within electron on my pi are from the 25th of Feb, which is the first time I used the modules. On other systems, the current image is used which is 28 Feb 2021, 2248GMT.
      Is there any way to turn off the caching, or do whatever I need to do to get a fresh image every time?
        Mykle1 Project Sponsor Module Developer @BKeyport
        @bkeyport
        @bkeyport said in Cached pictures in iFrame:
        Sounds like a similar issue I had a while back. Perhaps this is the same issue. The DOM has to change in order for it to refresh. Sean and Strawberry taught me this. The solution is simple.
        Set up a time stamp var and add it to the end of your img source.
        var getTimeStamp = new Date().getTime();
        img.src = "http://api.usno.navy.mil/imagery/earth.png?view=rise&seed=" + getTimeStamp;
        If yours is the same issue then this will work.
        Hope it helps.
        Peace!
        BKeyportB 1 Reply Last reply Reply Quote 1
        • BKeyportB Offline
          BKeyport Module Developer @Mykle1
          @mykle1 The problem is that it’s not my images. The images are provided by a 3rd party. Any changes would have to be on the MM.
            @bkeyport the server side doesn’t know you sent this extra parm but it makes the url unique, so fetch thinks it has to get it
            • BKeyportB Offline
              @sdetweil Oh, so I’d be modifying the code to mmm-iframe to add the timestamp?
              S Mykle1M 2 Replies Last reply Reply Quote 0
                sdetweil @BKeyport
                @bkeyport the url into the iframe, where ever the things is would want to change
                url http://someserver/somepath/somefile.img
                over and over the browser say,s OH thats the same, no need to load it, got a copy
                url http://someserver/somepath/somefile.img?time=1
                url http://someserver/somepath/somefile.img?time=2
                url http://someserver/somepath/somefile.img?time=3
                url http://someserver/somepath/somefile.img?time=4
                they are all different, so the browser reloads… the web server gets the extra parm, but doesn’t use it.
                  I thought I said that. :-)
                    I gave you an example bro. :-/
                    • BKeyportB Offline
                      @mykle1 I’m trying to understand how to use the example, bro. 😉
                      Not so good with partial code.
                      BKeyportB Mykle1M 2 Replies Last reply Reply Quote 0
                      • BKeyportB Offline
                        Got it working guys, thanks for your help, I’ve created a merge request with Mr. Wong as well.
                        If anyone else runs across the thread, and it’s still not merged, my code mods are:
                        https://github.com/BKeyport/MMM-iFrame
                          Been there. I only knew because I came across the same issue and didn’t know what to do, too. You’ll notice that I stated that Sean and Strawberry taught me the solution.
                          Anyway, it looks like you worked it out.
                          Good on ya, mate! :thumbsup:
