    ./node_modules/.bin/electron js / electron.js Problem
    23 Posts 2 Posters 6.8k Views 2 Watching
      sdetweil @youssef
      @youssef what processor is this on? I just fixed the install script for 32bit systems
      unamed -m
      output is i686
      Y 2 Replies Last reply
      • Y
        youssef @sdetweil
        @sdetweil said in ./node_modules/.bin/electron js / electron.js Problem:
        unamed -m
        • Y
          youssef @sdetweil
          @sdetweil thanks for your response again
          uname -m give me this result x86_64
            sdetweil @youssef
            @youssef interesting…
            still suggest using my script…
            Y 1 Reply Last reply
            • Y
              youssef @sdetweil
              @sdetweil thanks for responding
              I try with your scrip they give the same error
                sdetweil @youssef
                @youssef can u post ~/install.log
                or send to my email, sdetweil at gmail
                • Y
                  youssef @sdetweil
                  @sdetweil thanx for your response
                  install starting - Tue Mar 2 04:00:50 HST 2021
                  installing on x86_64 processor system
                  the os is Distributor ID: Debian Description: Debian GNU/Linux 10 (buster) Release: 10 Codename: buster
                  Updating packages …
                  Get:1 http://security.debian.org buster/updates InRelease [65.4 kB] Hit:2 http://ftp.debian.org/debian buster InRelease Hit:3 http://archive.raspberrypi.org/debian buster InRelease Get:4 http://packages.microsoft.com/repos/code stable InRelease [10.4 kB] Get:5 http://ftp.debian.org/debian buster-updates InRelease [51.9 kB] Hit:6 https://deb.nodesource.com/node_11.x buster InRelease Get:7 http://packages.microsoft.com/repos/code stable/main arm64 Packages [16.0 kB] Get:8 http://packages.microsoft.com/repos/code stable/main armhf Packages [15.8 kB] Get:9 http://packages.microsoft.com/repos/code stable/main amd64 Packages [15.4 kB] Fetched 175 kB in 2s (72.7 kB/s) Reading package lists…
                  apt-get update completed ok
                  apt-get upgrade started
                  apt upgrade result =rc=0 Reading package lists…
                  Building dependency tree…
                  Reading state information…
                  Calculating upgrade…
                  The following packages have been kept back:
                  linux-headers-amd64:amd64 linux-image-amd64:amd64
                  0 upgraded, 0 newly installed, 0 to remove and 2 not upgraded.
                  Installing helper tools …
                  build-essential is already the newest version (12.6).
                  curl is already the newest version (7.64.0-4+deb10u1).
                  git is already the newest version (1:2.20.1-2+deb10u3).
                  unzip is already the newest version (6.0-23+deb10u2).
                  wget is already the newest version (1.20.1-1.1).
                  wget set to manually installed.
                  Check current Node installation …
                  Minimum Node version: v10.1.0
                  Installed Node version: v10.24.0
                  No Node.js upgrade necessary.
                  Check current NPM installation …
                  Minimum npm version: V6.0.0
                  Installed npm version: V7.6.0
                  No npm upgrade necessary.
                  Cloning MagicMirror …
                  Cloning MagicMirror Done!
                  package.json update for x86 fontface completed ok
                  Installing dependencies …
                  Dependencies installation Done!
                  setting up initial config.js
                  Check plymouth installation …
                  Splashscreen: Checking themes directory.
                  Splashscreen: Create theme directory if not exists.
                  Splashscreen: Changed theme to MagicMirror successfully.
                  install and setup pm2
                  pm2 not installed, installing
                  pm2 install result npm WARN deprecated debug@4.1.1: Debug versions >=3.2.0 <3.2.7 || >=4 <4.3.1 have a low-severity ReDos regression when used in a Node.js environment. It is recommended you upgrade to 3.2.7 or 4.3.1. (https://github.com/visionmedia/debug/issues/797) npm WARN deprecated debug@4.1.1: Debug versions >=3.2.0 <3.2.7 || >=4 <4.3.1 have a low-severity ReDos regression when used in a Node.js environment. It is recommended you upgrade to 3.2.7 or 4.3.1. (https://github.com/visionmedia/debug/issues/797) added 201 packages, and audited 202 packages in 19s 9 packages are looking for funding run npm fund for details found 0 vulnerabilities
                  get the pm2 platform specific startup command
                  startup command = sudo env PATH=$PATH:/usr/bin:/bin /usr/local/lib/node_modules/pm2/bin/pm2 startup systemd -u pi --hp /home/pi
                  /\\\\\\_/\\/\\/\\\\_
                  _/\/////////\_/\\\
                  /\\\/\///////\_
                  /\_
                  /\_/\//\_/\//\_/////\_
                  _/\\\\\\/
                  /\_
                  /\_
                  /\_/\//_____
                  /\_
                  /\_////\_____/\//_____
                  /\_/\_/\_/\/__________
                  /\_/\_/\_/\\\\\\\_
                  _////////////////////////
                                        Runtime Edition
                      PM2 is a Production Process Manager for Node.js applications
                                   with a built-in Load Balancer.
                              Start and Daemonize any application:
                              $ pm2 start app.js
                              Load Balance 4 instances of api.js:
                              $ pm2 start api.js -i 4
                              Monitor in production:
                              $ pm2 monitor
                              Make pm2 auto-boot at server restart:
                              $ pm2 startup
                              To go further checkout:
                              http://pm2.io/
                  [PM2] Init System found: systemd
                  Platform systemd
                  Template
                  [Unit]
                  Description=PM2 process manager
                  Documentation=https://pm2.keymetrics.io/
                  After=network.target
                  [Service]
                  Type=forking
                  User=pi
                  LimitNOFILE=infinity
                  LimitNPROC=infinity
                  LimitCORE=infinity
                  Environment=PATH=$PATH:/usr/bin:/bin:/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin
                  Environment=PM2_HOME=/home/pi/.pm2
                  PIDFile=/home/pi/.pm2/pm2.pid
                  Restart=on-failure
                  ExecStart=/usr/local/lib/node_modules/pm2/bin/pm2 resurrect
                  ExecReload=/usr/local/lib/node_modules/pm2/bin/pm2 reload all
                  ExecStop=/usr/local/lib/node_modules/pm2/bin/pm2 kill
                  [Install]
                  WantedBy=multi-user.target
                  Target path
                  /etc/systemd/system/pm2-pi.service
                  Command list
                  [ ‘systemctl enable pm2-pi’ ]
                  [PM2] Writing init configuration in /etc/systemd/system/pm2-pi.service
                  [PM2] Making script booting at startup…
                  Executing: systemctl enable pm2-pi…
                  [PM2] [v] Command successfully executed.
                  [PM2] Freeze a process list on reboot via:
                  $ pm2 save
                  [PM2] Remove init script via:
                  $ pm2 unstartup systemd
                  pm2 startup command done
                  configure the pm2 config file for MagicMirror
                  start MagicMirror via pm2 now
                  save MagicMirror pm2 config now
                  stop MagicMirror via pm2 now
                  disable screensaver via gsettings was true and uint32 300
                  disable screensaver via lightdm.conf
                  disable screensaver via lxsession
                  We’re ready! Run pm2 start MagicMirror from the ~/MagicMirror directory to start your MagicMirror.
                  install completed - Tue Mar 2 04:04:51 HST 2021
                    sdetweil @youssef
                    @youssef weird…
                    can you do and show output of
                    npm install electron@8.5.3
                    • Y
                      youssef @sdetweil
                      Below you find the result
                      pi@raspberry:~/MagicMirror $ npm install electron@8.5.3
                      npm WARN deprecated request-promise-native@1.0.9: request-promise-native has been deprecated because it extends the now deprecated request package, see https://github.com/request/request/issues/3142
                      npm WARN deprecated urix@0.1.0: Please see https://github.com/lydell/urix#deprecated
                      npm WARN deprecated resolve-url@0.2.1: https://github.com/lydell/resolve-url#deprecated
                      npm WARN deprecated @babel/polyfill@7.12.1: 🚨 This package has been deprecated in favor of separate inclusion of a polyfill and regenerator-runtime (when needed). See the @babel/polyfill docs (https://babeljs.io/docs/en/babel-polyfill) for more information.
                      npm WARN deprecated gitlab@10.2.1: The gitlab package has found a new home in the @gitbeaker organization. For the latest gitlab node library, check out @gitbeaker/node. A full list of the features can be found here: https://github.com/jdalrymple/gitbeaker#readme
                      npm WARN deprecated webdriverio@4.14.4: outdated version, please use @next
                      npm WARN deprecated core-js@2.6.12: core-js@<3 is no longer maintained and not recommended for usage due to the number of issues. Please, upgrade your dependencies to the actual version of core-js@3.
                      added 813 packages, and audited 1112 packages in 20s
                      88 packages are looking for funding
                      5 vulnerabilities (4 low, 1 moderate)
                      To address all issues (including breaking changes), run:
                      npm audit fix --force
                      Run npm audit for details.
                      pi@raspberry:~/MagicMirror $ npm start
                      magicmirror@2.14.0 start
                      sh: 1: ./node_modules/.bin/electron: not found
                        sdetweil @youssef
                        @youssef wow… not even a complaint…
                        ok, try this
                        you’ll get the latest, but it should work…
                        • Y
                          youssef @sdetweil
                          they give the same result ,
                          up to date, audited 1112 packages in 6s
                          ![alt text](image url)
                            sdetweil @youssef
                            @youssef hm… you are running the graphical desktop, right? you must for electron to run
                            if u are running cli mode, then no graphics…
                            only asking cause its not complaining and failing to install…
                            i will recheck on my system as soon as I can … got a big copy going on and am short of disk space at the moment…
                            • Y
                              youssef
                              yes i’m using graphical desktop
                                sdetweil @youssef
                                @youssef on my install I see these messages
                                Official Linux/ia32 support is deprecated.
                                For more info: https://electronjs.org/blog/linux-32bit-support
                                • Y
                                  youssef @sdetweil
                                  @sdetweil thanks for your support
                                  can i install mm on debian 64 bit ?
                                    sdetweil @youssef
                                    @youssef should be able to… please wait, I am fixing install and run scripts…
                                    testing now…
                                    • Y
                                      youssef
                                      testing now…
                                      thanx i wait four your order to test the script …
                                        sdetweil @youssef
                                        @youssef ok, remove the MM folder and redo the install script… should set it up properly now…
                                        for some reason the electron test for this OS returns 32 bit, but the OS says 64…
                                        weird…
                                        • Y
                                          youssef
                                          weir
                                          it’s work, thank you for your support can you please explain to me what was the isssue.
                                            sdetweil @youssef
                                            @youssef for some reason the electron installer (not our code) has decided this is a 32 bit machine. and there is no 32bit electron available for intel.
                                            I think I will open an issue over there.
                                            my previous install worked fine…
