    MMM-Stock Cannot read property 'toLowerCase'
    34 Posts 2 Posters 14.8k Views 2 Watching
      brendan_c23 @sdetweil
      @sdetweil //if another currency is required - usd is default
      var differentCurrency = false;
      if(that.config.currency.toLowerCase() != “usd”){
      differentCurrency = true;
      var requiredCurrency = this.config.currency.toUpperCase();
      	for (var key in data) {
      		if (!data.hasOwnProperty(key)) {continue;}
      		var symbol = key;
      		var obj = data[key];
      		var current = obj[0];
      		var prev = obj[1];
      		var price = current["4. close"];
      		var change = prev["4. close"] - current["4. close"];
      		var html = "";
      		var priceClass = "greentext", priceIcon="up_green";
      		if(change < 0) {
      			priceClass = "redtext";
      			priceIcon="down_red";
        sdetweil @brendan_c23
        @brendan_c23 no, these, around line 90
        	scheduleUpdate: function(delay) {
        		var loadTime = this.config.updateInterval;
        		if (typeof delay !== "undefined" && delay >= 0) {
        			loadTime = delay;
        		var that = this;
        		setInterval(function() {
        			that.getStocks();
        			if(that.config.currency.toLowerCase() != "usd"){ // line 90 changed
        				that.getExchangeRate();
        		}, loadTime);
          @sdetweil Ok, I changed the ‘this’ to ‘that’ some lines above! not on those lines, going to try running it after changing the line you just sent
            @brendan_c23 just the ONE line, line 90…
              brendan_c23
              @sdetweil still waiting to see if it will display, theres a big delay, but no errors have popped up yet
              if (typeof delay !== “undefined” && delay >= 0) {
              loadTime = delay;
              	var that = this;
              		that.getStocks();
              	}, loadTime);
                @sdetweil No errors have come up, but it also has not displayed, have been waiting for around 10 minutes
                  @brendan_c23 did u change the other lines back?
                  open the developers window ctrl-shift-i, console tab, ‘stock’ in the filter field (no quotes)
                    @sdetweil They should be, but just in case Im missing something…
                    Module.register(“MMM-Stock”, {
                    result: {},
                    defaults: {
                    updateInterval: 60000,
                    fadeSpeed: 1000,
                    companies: [“GOOGL”, “YHOO”],
                    currency: “usd”,
                    baseURL: “https://www.alphavantage.co/”,
                    apikey: “IPWULBT54Y3LHJME”
                    getStyles: function() {
                    	return ["MMM-Stock.css"];
                    getTranslations: function() {
                    	return false;
                    start: function() {
                    	this.getStocks();
                    	if(this.config.currency.toLowerCase() != "usd"){
                    		this.getExchangeRate();
                    	this.scheduleUpdate();
                    getDom: function() {
                    	wrapper.className = "quotes";
                    	var list = document.createElement("ul");
                    	var data = this.result;
                    	// the data is not ready
                    	if(Object.keys(data).length === 0 && data.constructor === Object){
                    		return wrapper;
                    		var symbol = key;
                    		var prev = obj[1];
                    		var html = "";
                    		if(change < 0) {
                    		html = html + "<span class='" + priceClass + "'>";
                    		html = html + "<span class='quote'> (" + symbol + ")</span> ";
                    		html = html + parseFloat(price).toFixed(2) + " USD";
                    		html = html + "<span class='" + priceIcon + "'></span>" + parseFloat(Math.abs(change)).toFixed(2);
                    		var stock = document.createElement("span");
                    		stock.className = "stockTicker";
                    		stock.innerHTML = html;
                    		var listItem = document.createElement("li");
                    		listItem.innerHTML = html;
                    		list.appendChild(listItem);
                    	wrapper.appendChild(list);
                    	return wrapper;
                    		loadTime = delay;
                    	var that = this;
                    		that.getStocks();
                    	}, loadTime);
                    getStocks: function () {
                    	var allCompanies = this.config.companies;
                    	var urls = [];
                    	for(var company in allCompanies){
                    		var url = this.config.baseURL + "query?function=TIME_SERIES_DAILY&outputsize=compact&symbol=" + allCompanies[company] + "&apikey=" + this.config.apikey;
                    		urls.push(url);
                    	this.sendSocketNotification("GET_STOCKS", urls);
                    getExchangeRate: function () {
                    	var url = this.config.baseURL + "?q=select%20*%20from%20yahoo.finance.xchange%20where%20pair%20in%20('USD" + this.config.currency + "')&format=json&diagnostics=true&env=store%3A%2F%2Fdatatables.org%2Falltableswithkeys&callback="
                    	this.sendSocketNotification("GET_EXCHANGE_RATE", url);
                    	if (notification === "STOCK_RESULT") {
                    		this.result = payload;
                    		this.updateDom(self.config.fadeSpeed);
                    	} else if(notification === "EXCHANGE_RATE"){
                    		this.rate = payload;
                      @sdetweil Load script: modules/MMM-Stock//MMM-Stock.js
                      module.js:517 Module registered: MMM-Stock
                      loader.js:148 Bootstrapping module: MMM-Stock
                      loader.js:153 Scripts loaded for: MMM-Stock
                      loader.js:195 Load stylesheet: modules/MMM-Stock/MMM-Stock.css
                      loader.js:155 Styles loaded for: MMM-Stock
                      loader.js:157 Translations loaded for: MMM-Stock
                        @brendan_c23 so, no errors
                        does the config entry have a position:
                        if not the content is thrown away
                          @sdetweil yes, and I remember there being a delay before when it worked (around 5 mins) , but never this long as I am yet to see it, but here is the config
                          module: “MMM-Stock”,
                          position: “bottom_right”,
                          companies: [“SPY”, “GME”, “AMC”, “NOK”, “BB”]
                            brendan_c23 @brendan_c23
                            @sdetweil Could you try running it with both my config entry and MMM-stock.js entry I’ve posted and let me know if it works for you?
                              @brendan_c23 I have been doing that… it worked before, and doesn’t work now…
                              the node_helper request for the stock info says that the response isn’t right…
                                @sdetweil What do you think it could be? I am going to try copying original .js from hakanmhmd and make sure I didnt make any small changes I wasnt aware of , or maybe just delete and try to re download it
                                S B 2 Replies Last reply Reply Quote 0
                                  @brendan_c23
                                  [06.03.2021 12:14.17.736] [LOG]   stock processing request urls=["https://www.alphavantage.co/query?function=TIME_SERIES_DAILY&outputsize=compact&symbol=MSFT&apikey=xxxxxxxxxxxxxxxxx","https://www.alphavantage.co/query?function=TIME_SERIES_DAILY&outputsize=compact&symbol=GOOG&apikey=xxxxxxxxxxxxxxxxx","https://www.alphavantage.co/query?function=TIME_SERIES_DAILY&outputsize=compact&symbol=ORCL&apikey=xxxxxxxxxxxxxxxxx","https://www.alphavantage.co/query?function=TIME_SERIES_DAILY&outputsize=compact&symbol=FB&apikey=xxxxxxxxxxxxxxxxx","https://www.alphavantage.co/query?function=TIME_SERIES_DAILY&outputsize=compact&symbol=AAPL&apikey=xxxxxxxxxxxxxxxxx"]
                                  [06.03.2021 12:14.17.828] [LOG]   stock received request response
                                  [06.03.2021 12:14.17.828] [LOG]   stock request response no meta info
                                  the api is not returning the data expected… it was working for before with that one little change…
                                  I have tried all kinds of updates, but nothing resolves this issue…
                                  the module sent the request to the node helper, the helper is working thru the list, but never gets a good response
                                    @brendan_c23 Not completely sure on how to delete a module though, my Pi4 doesnt give me the option when right-clicking on the folder
                                      @brendan_c23 from the MagicMirror/modules folder
                                      rm -rf module_folder_name
                                      careful, rf - recursive force… get the wrong folder and there is no recovery
                                        @sdetweil Do you think I should delete it then redownload? Might be the companies… although they have worked before
                                          @brendan_c23 I changed companies too no difference…
                                          i think the api source
                                          is broken
                                          altho their status page says no, thru yesterday
                                          https://www.saashub.com/alpha-vantage-status
                                            @sdetweil What do you think we could do?
